Is the trailer hitch an OK jacking point?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 2020TacomaGuy, Jul 18, 2023.
  1. Jul 18, 2023 at 10:16 AM
    2020TacomaGuy
    2020TacomaGuy [OP] Well-Known Member
    2020 4x4 DCSB SR5
    Just for changing tires. Easier than crawling under truck for rear diff or axle. Thanks
  2. Jul 18, 2023 at 10:18 AM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    Definitely no
    ndoldman59 and TS4x4 like this.
  3. Jul 18, 2023 at 10:19 AM
    10thMTNgrunt
    10thMTNgrunt This is the way, step inside.
    2013 TRD Sport
    I’m not sure but I wouldn’t, seems like the risk exceeds the reward to no end.
    RedWings44, TS4x4 and Chew like this.
  4. Jul 18, 2023 at 10:20 AM
    2020TacomaGuy
    2020 4x4 DCSB SR5
  5. Jul 18, 2023 at 10:20 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    It’s designed for a pulling force, and to have about a 400-500# load, but that force gets multiple by up and down movement (not an engineer).
    I wouldn’t make a regular habit of it, but I’m guessing it’ll be fine in a pinch. Sliding the jack another few feet isn’t an issue for me; risks and rewards
    hiPSI likes this.
  6. Jul 18, 2023 at 10:22 AM
    MR E30
    MR E30 Well-Known Member
    Michael
    Wherever it's parked
    2021 Silver TRD OR DCLB w/ AluCab and All the Mods
    I would use the hitch as a lifting point, in a pinch. Or even not in a pinch.
    Am an engineer, and I see absolutely nothing wrong with using the hitch to lift the truck. It's connection to the frame has all of the characteristics required to handle the forces imparted by loading it vertically.
    Edit: When I originally posted this, the OP was more detailed than it is now. It didn't even mention just lifting to change the tires. I still agree that it's strong enough to use, but I would not use it just to change tires. Get under the truck and use the axle and jack stands. Be safe, always.
    ndoldman59, AusBerg, hiPSI and 5 others like this.
  7. Jul 18, 2023 at 10:32 AM
    cosmic_3000
    cosmic_3000 Well-Known Member
    '17 OR DCLB w/ JBL
    I've done it several times, mainly to unload the rear leafs to lube them. I just put some wooden blocks on the jack and jack it up no problem. That thing is a hefty square tube, and mounts directly to the frame. Never had a problem.
    madcratebuilder likes this.
  8. Jul 18, 2023 at 10:32 AM
    Toolndie7
    Toolndie7 Well-Known Member
    2019 Sport DCSB Cavalry Blue
    So much easier jacking the outboard axle to just change a tire. Only need to lift that axle an inch.
    Jacking the hitch you need to stroke that jack quite a ways up until your leafs pickup the axle, and by then both rear wheels are off the ground an you are teetering on the jack.
  9. Jul 18, 2023 at 10:35 AM
    MR E30
    Michael
    Loads of scenarios where you need the axle to be unloaded/not supporting the vehicle.
    I use my sliders for the jack stands, after jacking under the third member, but some folks don't have sliders.
    I do agree that you are dealing with some serious teetering, and that should definitely be addressed. I personally wouldn't work under the truck with just a hitch support (or any single support, be safe).
    soundman98 likes this.
  10. Jul 18, 2023 at 10:36 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I'll disagree, but for reasons that are entirely different than structural. It is not as stable of a lifting point.
    For changing tire purposes, its best to lift from the unsprung parts - low to the ground, and doesn't have to lift as far. One tire up / three on the ground is preferable unless you are rotating, especially if you need to lift one of the rears. I would lift from the diff only after the front end is physically immobilized with chocks and/or stands. I would definitely not lift from the hitch - that amount of height on an floor jack will be relatively very easy to knock over when tugging on the tires or spinning lugs.
    Structure really doesn't factor - its simply an unsafe practice in my book.
  11. Jul 18, 2023 at 10:38 AM
    MR E30
    Michael
    Agreed completely (I mentioned this in a post I typed while you were probably typing this).
    It is way too unstable for me. But as far it being capable of lifting the truck, it's fine.
    Rock Lobster[QUOTED] likes this.
  12. Jul 18, 2023 at 10:40 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Depends on the jack. The hitch is pretty high up, and you have to raise it another half a foot or more to take up the suspension travel. Jacking from the diff is more stable and in my experience, faster.
  13. Jul 18, 2023 at 11:03 AM
    TXBoss
    TXBoss Well-Known Member
    DFW
    2009 & 2015 TRD Sport
    Word of caution on the hitch... your pivot point / lever arm for using the hitch as a lift point now moves to the front tires. With the relatively short wheelbase of the Tacoma, you're probably fine. But it's a longer bending moment than the frame sees during regular loading.
    I agree with one of the other posters... in a pinch you are probably okay. There is not much weight to lift. But be aware of the different mounting points your suspension has on the frame and how a lift on a hitch isn't the same.
    This really is more of an issue on long wheel base trucks.
    01 dhrracer and ABA180 like this.
  14. Jul 18, 2023 at 11:15 AM
    wrightme43
    wrightme43 Well-Known Member
    Scottsville Kentucky
    17 Double Cab M/T TRD Offroad Blazing Blue Pearl
    Redline custom leather shift and e-brake boot. VFTUNE Super Full Otto cycle, octane learning, premium fuel.
    I do, have for 30 years, and will continue. I do always use jack stands though.
  15. Jul 18, 2023 at 11:16 AM
    Tacospike
    Two Trucks
    So you just raise it, place jack stands and lower it?
    wrightme43[QUOTED] likes this.
  16. Jul 18, 2023 at 11:26 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I tried to use a hi-lift on the hitch receiver when in a pinch. The jack leaned heavily on the tailgate and I aborted out of fear of damaging it. I could have taken the tailgate off I suppose, but I found an alternative.
    I see little reason to use the hitch receiver on a regular basis because it is so high and there are several other better jack points. Also there is no reason to crawl under the truck if you have a full sized floor jack.
    Chew likes this.
  17. Jul 18, 2023 at 11:36 AM
    2020TacomaGuy
    2020 4x4 DCSB SR5
    I would just raise truck then use jack stands. Sorry if I wasn't clear. Thanks for the replies
    wrightme43 and gudujarlson like this.
  18. Jul 18, 2023 at 11:49 AM
    ScrippsRanch67
    ScrippsRanch67 Well-Known Member
    Bob
    06 Tacoma Pre-Runner 2wd Quad Cab short bed
    Fiberglass shell
    How does "tongue weight" rating factor in? A Tacoma rear end is going to weigh a whole lot more than a Travel Trailer nose?!
  19. Jul 18, 2023 at 11:55 AM
    cowfootball
    cowfootball Well-Known Member
    South Lake Tahoe, CA
    2022 TRD OR
    It's strong enough to lift the truck and anyone saying otherwise hasn't seen it done on the regular with a hi-lift offroad. Anyone who is comparing it's weight rating to a trailer tongue hitch doesn't understand physics. (Hint: tongue weight is more about steering and vehicle control than it is your hitch like, bending and snapping off the frame or something.)
    But it's an absolute last resort and the reason you don't do it isn't the weight: it's because it can result in the truck tipping. Lifting from the rear center can cause it to slip left or right off the jack easily. It's pretty dangerous and desperation only, not a convenient jack point.
    soundman98 and gudujarlson like this.
  20. Jul 18, 2023 at 11:56 AM
    mutilatedjak
    mutilatedjak n00b waffle
    WA
    11 DC SB TRD Sport 6spd
    BP-51s, Dakar leafs, ARB bumper, 4xinnovations rear HC, 3x trail camera, pure android, lightforce 170s, Dick Cepek 255 85s extreme terrain.
    Weight/load wise its perfectly fine. Stability...meh
    works fine for me
    AIL4fc-QCY-BrmxrUgJBiKbWaNgIxLS4mf0xtEqO_75b831cb3082166fd6542662d74db5338e64c356.jpg
    wrightme43, andthen, Bertw192 and 6 others like this.
