Is the 4.0 Supercharger worth it?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TopDawg1776, Mar 7, 2017.
  1. Mar 7, 2017 at 12:32 PM
    TopDawg1776
    TopDawg1776 [OP] Well-Known Member
    Sam
    Nashville
    2022 Tundra TRD Pro
    I was driving recently in New Orleans east and seemed to notice my truck was a bit gutless. I know its not a V8 and doesn't have any high figures, but was thinking a 4220 pound would have better acceleration. I have the Trd Pro, so maybe it is geared differently? I have read a little on the supercharged and thought about looking for a used one for sale. The biggest problem is the price. Can I get some other engine modifications that can give me a little more HP with out going with a SC or something crazy? For the 4.0 SC owners what PSI do you get, HP, and does this affect MPG? How much did it cost from the dealer and install?
  2. Mar 7, 2017 at 1:12 PM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    I thought used ones still went for like $12k on Ebay if you could find one? Toyota's supercharger at least.
    My vote is turbocharger. I like turbos for trucks.:burnrubber:
  3. Mar 7, 2017 at 1:18 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Magnuson makes them now, comes with external intercooler, combine that with some headers and you're probably quicker than a stock truck with the 4.7L V8 though still don't sounds as good and will need premium gas
  4. Mar 7, 2017 at 1:22 PM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Only choice you have for more power is the SC.
    *I can't spell
    Norton and J'sBeasTRD like this.
  5. Mar 7, 2017 at 1:28 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    wut
  6. Mar 7, 2017 at 1:35 PM
    Lateralus
    Lateralus Senior Member
    Las Vegas
    07 4x4 Off Road
    Too many to list..
    I have the SC with the "Stealth" 2.85" pulley. Plus DTLT and a Magnaflow exhaust. Front and rear plate bumpers and all the armor underneath and 35" tires. I was seeing 13-14 MPG. Boost wise you will only see 7-8psi, Not a whole lot.
    I really didn't feel that much a of difference in the power on city streets. Off road, if i stomped on it the rear tires would break loose.
    In the last month I have gone to 4.88 gears. That made the biggest change. The truck is fast as hell, but my milage got worse. I'm now around the 10-11 MPG (really bad). Now if I stomp on it while rolling at 25mph, the tires will break loose on pavement.
    Price wise, for the charger and my dealer to install, I was at just under $6K. That was 3 years ago.
    BLKSR5TACO, 12TRDTacoma and Glueman like this.
  7. Mar 7, 2017 at 1:38 PM
    TacomaMike37
    13' DCLB MGM
    Yeah I can't spell, corrected
  8. Mar 7, 2017 at 4:28 PM
    bluezzy
    bluezzy Love My SuperCharged 07 Sport!
    Monty
    Eugene, Oregon
    I have never had mine dyno'd or nutin but my 07 Supercharged Taco with the 2.85 pulley poured Woop-Ass on two mustanges so far.
  9. Mar 7, 2017 at 4:32 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Worth it is pretty subjective. I have one with the 2.85 pulley. If you get one the pulley upgrade is a must. The Pro does not have different gearing. The 4.0 is an older designed solid truck motor that has good low end torque and lacks higher HP. The supercharger with the pulley helps a lot.
    For power comparison, if I punch it when it is wet at 60 mph on the highway, the rear end will break free. And I'm on 32s. If you weigh your truck down with larger tires, heavy armor and other modifications that kill performance the SC will have less of an effect. I've lost 1mpg by supercharging, I'm in the mid-17s with mixed city highway. Highest has been 20mpg highway. The difference at the pump is less than $4/tank if you are not completely dry.
    Cost about $4500 without the tuner. It is recommended you get the OEM TRD tune, which is more reliable and available at a dealer for about $100.
    http://urdusa.com/store/Forced-Indu...05-2015-Tacoma-V6-NO-TUNING/product_info.html
    Worth it? Only you can decide that. I really enjoy mine as it makes the truck a ton of fun to drive.
  10. Mar 7, 2017 at 5:07 PM
    TopDawg1776
    Sam
    Nashville
    2022 Tundra TRD Pro
    Your on 32's and it slips? jeez... Ive got a heavy foot so ill be getting a lot of slipping. thanks for the info ill denftly take note.
  11. Mar 7, 2017 at 5:08 PM
    TopDawg1776
    Sam
    Nashville
    2022 Tundra TRD Pro
    I drive around 30-45 min a day for work so i don't know. Im not looking into changing the gearing now if thats gonna be my MPG after this.
  12. Mar 7, 2017 at 5:09 PM
    TopDawg1776
    Sam
    Nashville
    2022 Tundra TRD Pro
    Any suggestions on what ones to buy?
  13. Mar 7, 2017 at 5:11 PM
    TopDawg1776
    Sam
    Nashville
    2022 Tundra TRD Pro
    Will I need premium for the TRD, I would assume so. Problem is premium is so high around here.
  14. Mar 7, 2017 at 5:13 PM
    Frkypunk
    Frkypunk "Death is what you make of it."
    Timmy
    Woods of P.A.
    2010 Tundra limited,2015 Highlander limited, Prius(commuter)
    Got the gas mileage down to 13mpg! Modification complete
    :notsure:Buy a Tundra?
    14TACO4X4, Guat and big_jarv like this.
  15. Mar 7, 2017 at 5:13 PM
    bluezzy
    Monty
    Eugene, Oregon
    I was told to run premium or it would ping, I dont really know, I have never tried to run anything else... Price of Premium? Soooo worth it!! ;)
  16. Mar 7, 2017 at 5:14 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    C-load, so they are lighter which is better for power, mpgs, braking and ride. Unlike many that put heavy E-loads on.
    That is because he has a very heavy truck on 35s plus a regear.
    There is no kit. Turbos are going to be a build it yourself deal. So if you have to ask it probably isn't something you want to tackle.
    Yes. Premium is usually $0.20 over regular. The Tacoma has a 21 gallon tank, meaning if you were completely dry to the point of causing fuel pump damage and not able to start the truck it would cost $4.20 more per tank over regular.
  17. Mar 7, 2017 at 5:18 PM
    JasonU71
    JasonU71 Well-Known Member
    displaced in Southern Maryland
    2015 TRD Sport
    Icon Extended Coilovers, Camburg Ball Joint UCA, Icon 2.0 rears, Wheelers 3 leaf AAL, WeatherTech mats, ARB Front Bumper, IPF Dual Beam lights, JBL amp and speakers
    I'd love to test drive a super charged truck prior to spending the money. $5k is a lot for me to spend, unless I was sure it'worth it.
    big_jarv likes this.
  18. Mar 7, 2017 at 5:56 PM
    Just Dandee
    Just Dandee Well-Known Member
    Dan
    Southwest Idaho
    2015 TRD OR
    Supercharged-2.5 lift-255/85/16
    Click on the video below, make your own decision
    bluezzy likes this.
  19. Mar 7, 2017 at 5:58 PM
    Frkypunk
    Timmy
    Woods of P.A.
    Seems like that guy is trying to kill tires....everyone look out!
  20. Mar 7, 2017 at 5:59 PM
    JasonU71
    2015 TRD Sport
    Wow. You sold me on the idea! I've got to start saving my nickels and dimes.
