Is my rear axle seal leaking?
Discussion in '1st Gen. Tacomas (1995-2004)' started by scaliusmaximus, Jun 11, 2020.
  1. Jun 11, 2020 at 3:53 PM
    scaliusmaximus
    scaliusmaximus [OP] Well-Known Member
    pascal
    Los Angeles
    2001 Tacoma Prerunner XtraCab 3.4l
    none
    Took my truck to mechanic and says my rear axle seal on the passenger side is leaking. Doesn’t look like it’s spraying all over the wheel or tire.
    Do I have time to put it off or should I get it done as soon as a I can?
    I’m strapped for funds after having my driveshaft rebuilt (previous owner butchered it so it cost more than it normally would have).
    wilcam47 likes this.
  2. Jun 11, 2020 at 4:01 PM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    what are the symptoms? where is it leaking? You have oil in the brake drum?
    pictures would help too
    Black DOG Lila likes this.
  3. Jun 11, 2020 at 6:51 PM
    scaliusmaximus
    pascal
    Los Angeles
    none
    Sorry thought I uploaded file. Should be there in original post now.
  4. Jun 11, 2020 at 6:55 PM
    maxtherat
    maxtherat Well-Known Member
    Inland Northwest
    2001 Dodge Ram 2500, 1993 Jeep Wrangler
    All the usual diesel truck mods- fuel system upgrade, programmer, CAI, intake manifold, 60MM stealth turbo
    The answer is obvious- fix it and do both sides while you’re at it. Right now it looks like a small leak but sometimes these just puke oil and then you’re brakes are ruined too.
    cruiserguy likes this.
  5. Jun 11, 2020 at 7:04 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Yup, you be leakin.
    It should be fixed as quickly as you can. Oil covered brakes dont work all that well in the best case. Dont work at all or cook and catch fire in the worst.
  6. Jun 11, 2020 at 7:09 PM
    scaliusmaximus
    pascal
    Los Angeles
    none
    How difficult is it to do the work myself? I don’t have a press but can get one if it’s cheaper than taking to a drivetrain shop.
  7. Jun 11, 2020 at 7:10 PM
    scaliusmaximus
    pascal
    Los Angeles
    none
    Also are the rear brakes salvageable or do I need to get need to get new ones?
  8. Jun 11, 2020 at 7:22 PM
    maxtherat
    Inland Northwest
    You’d have to pull drums to see if it’s made it’s way onto the shoes. I’m all about doing work myself- not only to save money but to learn too. Nowadays with the internet and auto parts stores that lend specialty tools it’s a piece of cake.
    suaveflooder likes this.
  9. Jun 11, 2020 at 7:34 PM
    scaliusmaximus
    pascal
    Los Angeles
    none
    Yeah I definitely agree. Does anyone have preferences on where to get parts. I saw low range offroad has a kit for sale. or should I just go oem?
  10. Jun 11, 2020 at 7:48 PM
    maxtherat
    Inland Northwest
    I usually like going with OEM for this type of stuff. Usually if you find online pricing that’s pretty decent you can print it out and take to a local dealer and they’ll likely price match. I would recommend that when you pull the axle you also check the bearing for wear. A lot of times you’ll get a seal leak because the axle besting is worn and then there’s slop. To replace the bearing you’ll need a press but that’s not needed for seal replacement. If your fluid is fairly new and trying to cut cost you can jack up just the 1 side and you’ll loose little to no fluid.
  11. Jun 11, 2020 at 8:21 PM
    scaliusmaximus
    pascal
    Los Angeles
    none
    My truck is non ABS. The kits on ebay by aircabinman and others are only for trucks with ABS.
    I priced out parts from mcgeorge Toyota and it will run me $200 for everything. Then theres this tool recommended from ebay thats about $120 to push out the old bearings. I'd also need to get a press from harbor freight which is around $150
  12. Jun 11, 2020 at 8:23 PM
    scaliusmaximus
    pascal
    Los Angeles
    none
    The bearing I think is original but I'll inspect for wear when I pull the axle. Haven't checked condition of fluid either (only owned the truck 1.5 years.)
    I don't have a press so I'm hoping I don't have to do the bearing otherwise ill have to buy a press/the bearing tool on ebay. Or take the axles to a drivetrain shop.
  13. Jun 11, 2020 at 8:29 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Sounds like you have a solid plan of attack for this. :cool: leaky axle seal be damned:D
  14. Jun 11, 2020 at 8:30 PM
    cruiserguy
    Elijah
    SEKS
    Ouuuuuuuuucccccchhhhhh
  15. Jun 11, 2020 at 8:31 PM
    cruiserguy
    Elijah
    SEKS
    That's jacked up what they did to yours. That's like my biggest fear ever, leaving a vehicle to shop for repair. Hasn't happened for 19 years. :fingerscrossed:
    DJB1 and High Noon like this.
  16. Jun 11, 2020 at 8:35 PM
    cruiserguy
    Elijah
    SEKS
    Oh that's right OH YEAH THAT'S RIGHT.... Anywho, Didn't someone here have a butchered rear axle? Like the shaft had all these gouge marks from trying to press the bearing and stuff...oh man makes me shiver just thinking about it
  17. Jun 11, 2020 at 8:35 PM
    scaliusmaximus
    pascal
    Los Angeles
    none
    My truck is the non TRD model. I've always wanted an Electronic diff locker. Wonder if nows the time to just pull one of those from a donor truck and do the swap. thoughts?
    High Noon and cruiserguy like this.
  18. Jun 11, 2020 at 8:37 PM
    cruiserguy
    Elijah
    SEKS
    If you can find one reasonably priced close to you, why not? Now would definitely be the time:D
    High Noon likes this.
  19. Jun 11, 2020 at 8:44 PM
    cruiserguy
    Elijah
    SEKS
    Oh that was you as well??? What crap luck man, sheesh. Same shop or different place?
  20. Jun 11, 2020 at 9:21 PM
    cruiserguy
    Elijah
    SEKS
    Oh I follow you now
