Is my battery dead or am I going insane?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by riplipper, Dec 14, 2023.
  1. Dec 14, 2023 at 9:22 PM
    riplipper
    riplipper [OP] Well-Known Member
    Hi all,
    Didn’t use my 19 Tacoma (v6 OR, 35k miles) for about a 2 weeks while out of town. Came back to a dead battery. Jumped her and she was fine for a couple days of driving. Didn’t use again for about 5 days. Went to start and battery was dead again.
    Brought the battery to autozone and they tested and said battery was completely fine (12.4 reading). They advised I drive on highway to charge(I live in Portland, OR and most of my day to day driving is in my hood for 10 minute drives). Drove at highway speeds for about an hour that day. Tried starting today 4 days later and it is completely dead.
    When I push start I get a bunch of clicks. It doesn’t seem like alternator but who knows. I’m tempted to just replace battery, but will be bummed if I spend money to replace battery and it doesn’t fix the issue.
    Has anyone experienced these issues and had it be something else other than a battery?
  2. Dec 14, 2023 at 9:31 PM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    2019... probably a 2018 battery. Try a new one, you are gonna need it soon anyway.
  3. Dec 14, 2023 at 9:39 PM
    Gatafly
    Gatafly Well-Known Member
    Shawn
    2020 TRD OR AT V6 MGM
    Sounds like Autozone just metered the battery and didn't load test it. A bad battery can read 12 volts, but as soon as you try to start it the voltage can drop significantly. I am 99% positive you will need a new battery. Also, if you can help it never use your alternator to charge a dead battery as it puts significant wear on it.
  4. Dec 14, 2023 at 9:41 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    You have 3 options.
    1. Check for a parasitic draw.
    2. Remove the battery cable(s) when leaving it for 4-5 days.
    Then hook them up and see if it starts or doesn’t.
    3. Throw a battery at it and hope for the best.
    Travlr, kahanabob, wombatz and 3 others like this.
  5. Dec 14, 2023 at 9:48 PM
    CaptainBart45
    Bart
    Work in progress...
    Not really throwing a battery at it it the current battery is 5 years old. But I get what you are saying... "don't just change parts hoping for the best."
  6. Dec 14, 2023 at 9:53 PM
    TnShooter
    Deogee
    STOCK
    Yeah. But constantly draining a battery isn’t good for it.
    Not on a lead acid. Nor is it good for the alternator.
    I’d make sure I don’t have a problem first.
    Maybe fix the problem, then buy a battery.
  7. Dec 14, 2023 at 9:54 PM
    TnShooter
    Deogee
    STOCK
    BTW, I can somewhat agree on replacing a battery at 5 years.
    Especially on newer vehicles with all the electronics.
  8. Dec 14, 2023 at 9:57 PM
    CaptainBart45
    Bart
    Work in progress...
    Always a spark when hooking up a new battery, tells me that there is always a drain. I am totally with you on don't fix the unbroken part. However, 5 years a battery is a good guess.
  9. Dec 14, 2023 at 9:59 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    5 year old battery, hmmm?
    Kolohe07, JFriday1 and Chew like this.
  10. Dec 14, 2023 at 11:09 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Did autozone give you a printout? They checked my charging system once, and provided a printout of battaery voltage and cca. Might have had other info but that’s what I remember. And how do you know the alternator is ok? Did you have it tested?
  11. Dec 15, 2023 at 12:10 AM
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    Consider that the two stated options are NOT mutually exclusive...
    However, based on the few details provided, I can only address the battery question; It sounds like your battery is kaput.
    Gunshot-6A likes this.
  12. Dec 15, 2023 at 12:16 AM
    TacoTuesday1
    FL
    autozone is not credible
    it's in the engine bay
    TacoSR523 and RugglesTarlek like this.
  13. Dec 15, 2023 at 12:27 AM
    MGMDesertTaco
    Clicking sound means your battery is dead. 12.4v and below causes battery sulfation.
    I recommend the 24F agm from Walmart and a compatible agm battery strap.
  14. Dec 15, 2023 at 12:30 AM
    jassco
    jassco Well-Known Member
    NH
    2023 TRD Offroad
    You need to have a proper scan tool to load test as mentioned. The zone won’t have that, but a shop should. This will also test the alternator load. At this point you’ve eclipsed the cost of a good battery at Walmart.
    Our family has had many vehicles and the most a battery has lasted was us 7 years. I’d expect newer cars drawing more and last even less. 4-5 years is decent.
  15. Dec 15, 2023 at 1:16 AM
    pdxTacoSR5
    pdxTacoSR5 Well-Known Member
    PDX area
    2018 Tacoma SR5, V6 Auto, Access Cab, 4x4, Silver Sky Metallic
    well, we are both entering the brutal winters of portland, OR :D but 5 yrs on a toyota battery is about right.
    i am in same situation and watching battery closely. i carry a jump pack and trickle charge it now and then for a programmed desulfation cycle. i'm really just procrastinating and curious to see how far i can go.
    you might also put a VOM on the cigarette lighter and watch your charging voltage. should be around 13.7 to 14.3...and advice about not jumping a dead battery because it beats the hell out of the alternator...is VERY good advice.
    bottom line you are going to need a new battery anyway, even if that is not the primary problem. dollars to donuts it is the battery...unless you continue with what you are doing and kill the alternator.
    good luck. RIP PDX.
    23MGM likes this.
  16. Dec 15, 2023 at 1:45 AM
    TruckGuy63
    TruckGuy63 Well-Known Member
    Gilbert
    New York
    2019 Barcelona Red Dbl Cab TRD Offroad
    It’s the Battery. Way too much thought here . It’s almost 5 years old
    You did good . Even if it were something else which I doubt . It needs a battery
  17. Dec 15, 2023 at 3:49 AM
    TacoTuesday1
    FL
    A multimeter to watch voltage drop during cranking is $5 at harbor freight
    you can always try putting it on a CTEK overnight
    but modern regular car batteries inside engine bays don’t last above 5yr.
    if you get a new one it will have a warranty. If it quickly goes flat that will tell you the truck has an undiagnosed issue. Or not if it doesn’t.
    this can be an opportunity to upgrade. For example on the 2nd gen stock battery is small. And dealers recommend the bigger one which is a different PN.
  18. Dec 15, 2023 at 4:02 AM
    BlackCat81
    BlackCat81 Well-Known Member
    2023 Ice Cap TRD OR
    its the battery
    Chew likes this.
  19. Dec 15, 2023 at 4:03 AM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    Yo battery is dead.
    CaptainBart45 and Chew like this.
  20. Dec 15, 2023 at 5:25 AM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    Your battery is not fine. It is sitting at less then 80% charge after driving to Autozone. It should be resting at 12.6v+ after sitting approximately 24 hours of rest after a complete charge. You have 5 years out of it. You did better than a lot of others. Replace it and either disconnect or add a battery maintainer for long times no driving.
    I suggest a NOCO maintainer. Excellent product.
    wilcam47 and Chew like this.
