Is it worth getting 17" wheels for 33"s?
Discussion in 'Wheels & Tires' started by UhOhSpaghettios, Feb 8, 2020.
  1. Feb 8, 2020 at 6:09 AM
    UhOhSpaghettios
    UhOhSpaghettios [OP] Very unprofessional sender
    NC
    2016 SR5 ACLB
    3” Toytec lift 16x9 Method 305 285/75-16 Toyo AT3 Custom exhaust Custom retrofits
    I'm looking to throw 33s under the taco but I still have stocks on. Is it wise to get a new set of 33x16s or just save money and upgrade to 17s right off the bat? I do a good bit of on road driving with a bit of mud slinging and trail crawling in between (usually once or twice a week) anything y'all can suggest will help!
  2. Feb 8, 2020 at 7:33 AM
    JL8Jeff
    JL8Jeff Well-Known Member
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    OME 885/nitros, SPC UCA, 305/65/17, AAL
    I think there are more tire options for the 17" wheel around the 33" size. But it might depend on how wide you plan on going. If you want to go wider, you probably need a wheel that is wider than stock. My truck had 285/75/16 tires on 16x8 wheels and I wanted a wider tire so I went for 305/65/17 on 17x8.5 wheels. If you're looking for a skinny tire, then the stock 16" wheels should work fine.
    Mully and UhOhSpaghettios[OP] like this.
  3. Feb 8, 2020 at 8:20 AM
    Hooper89
    Hooper89 Well-Known Member
    2016 White TRD Sport
    Do you have a lift on it? If not check out the 265/75r16 thread that is a good tire size and fits on stock.
    UhOhSpaghettios[OP] likes this.
  4. Feb 8, 2020 at 8:28 AM
    thegerbs
    thegerbs Well-Known Member
    Rex
    2019 Matte Green Tacoma
    i went 17x9 with a 265/70 and it fits well on stock suspension, minor rubbing a little bit of trimming on plastic would fix. but like mentioned above there are a ton more options for tires in the 17 vs 16.
  5. Feb 8, 2020 at 8:30 AM
    UhOhSpaghettios
    NC
    2016 SR5 ACLB
    I'm still deciding that but leaning more towards the wider tires, mainly for the mud.
  6. Feb 8, 2020 at 8:30 AM
    UhOhSpaghettios
    NC
    2016 SR5 ACLB
    I've got a 3" lift on it
  7. Feb 8, 2020 at 8:33 AM
    UhOhSpaghettios
    NC
    2016 SR5 ACLB
    Yeah that's what I've been thinking
    DavesTaco68 likes this.
  8. Feb 8, 2020 at 8:34 AM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    285x70x17 Pirelli Scorpion MT on 17x8.5 Procomp Lapaz. 2.5" Kings lift. Works great, no rubbing at all.
    And yes I did CMC, hammer PWS, plus trimming. Good luck with your truck.
    lynyrd3 and DavesTaco68 like this.
  9. Feb 8, 2020 at 8:36 AM
    UhOhSpaghettios
    NC
    2016 SR5 ACLB
    Truck looks great man! I'm planning on upgrading to Kings down the road. And that's the same size I was looking at
    Mully[QUOTED] likes this.
  10. Feb 8, 2020 at 8:37 AM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
  11. Feb 8, 2020 at 8:47 AM
    Mully
    CA
    Do lots of research, there's alot more to lifting these trucks than just installing a new set of coilovers. If you're looking to seriously wheel, you have to reinforce some stuff or it just gets all bent out of shape and you will have a hell of a time keeping everything aligned.
    lynyrd3 likes this.
  12. Feb 8, 2020 at 9:05 AM
    UhOhSpaghettios
    NC
    2016 SR5 ACLB
    I'm probably won't do any serious wheeling I was just looking for a little better ride quality on the road and on the trails
  13. Feb 8, 2020 at 11:45 AM
    JL8Jeff
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    16" tires will have more sidewall than 17" tires in the same size so 16" will probably be less stiff and better ride quality
  14. Feb 8, 2020 at 11:52 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Skinny tires are better mud tires. Wider tires are for sand and rock crawling.
  15. Feb 8, 2020 at 11:55 AM
    UhOhSpaghettios
    NC
    2016 SR5 ACLB
    Thanks for the advice. I've always been told I'm smarter than I look. I guess not
  16. Feb 8, 2020 at 11:56 AM
    WrecklessAbandon
    WrecklessAbandon They call me skippy
    Travis
    Olympia, WA
    Crocs with socks
    If you air down more sidewall is always better...I know we are only talking 1/2" here but every bit counts.
    If I could run 15" wheels I would
  17. Feb 8, 2020 at 12:03 PM
    Hooper89
    I like the 17” TRD pro wheels you could stick 270 size tires on there and be around 32. There’s a big selection too.
    err 265/70 I think it is
  18. Feb 8, 2020 at 12:16 PM
    Cudgel
    Cudgel “Tonka”
    2017 OR DCLB
    Mud on 17s
    Note some say mud tires should not be too wide, others disagree, others have no opinion, others have both opinions.
  19. Feb 8, 2020 at 12:19 PM
    UhOhSpaghettios
    NC
    2016 SR5 ACLB
    I'm leaning more towards the wider tires, mainly because I'm not always in the mud, and I also like the aggressive look of them. Also how have you liked the Fuel wheels?
  20. Feb 8, 2020 at 12:36 PM
    Cudgel
    Cudgel “Tonka”
    2017 OR DCLB
    I LOVE my setup. It is not exactly what many suggest:
    High end Icon adjustable suspension not set at max load so it works at ideal spec. If your suspension is cranked tires won’t “fix” your ride.
    E-rated BFGs. Yes Es, these are not the softest but I run them at 34 PSI, well below what BFG calculates.
    17s for looks mostly.
    because of the digressive Icons I can drive like a maniac anyway.
