Is it safe to spray parts with rustoleum?
Discussion in '1st Gen. Tacomas (1995-2004)' started by MacGyvR, Jan 4, 2019.
  1. Jan 4, 2019 at 10:03 AM
    MacGyvR
    MacGyvR [OP] Well-Known Member
    Tom
    Dallas, Texas
    03 Prerunner (5VZ-FE)
    OME 2.5", 881, Dakar, Nitrochargers
    Hello!
    I have some work coming up (all front bushings, new OME suspension, new carrier bearing, etc) where I'll be pulling a lot of parts off the truck. While I'm in there and have pieces off I want to pressure wash them clean. Is it worth it (or safe) to apply a coat of rustoleum or something to extend the life of these components after cleaning them? Specifically I'm thinking of my control arms and maybe the prop shafts.
    I live in AZ so rust isn't a huge concern. But we're considering a move to Texas later this year and I figure it's easier to paint things while they're off the truck. What are your thoughts, TW?
  2. Jan 4, 2019 at 10:15 AM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    Won't hurt a thing. Probably won't help either but won't hurt.
    skeezix likes this.
  3. Jan 4, 2019 at 10:25 AM
    DW85
    DW85 Dude.....
    Daniel
    Kentucky
    2001 XtraCab Tacoma TRD 4x4/2004 SR5 V6 4Runner
    Tacoma: Badlands basher front bumper Trail gear rear bumper Trail gear sliders OME Dakar’s OME 883 Coils Bilstein 5100s front Bilstein 5125s rear SPC Upper Control Arms Wheeler’s Extended brake lines ProComp 51 Series 15x8 3.5” BS 32x11.50x15 BFG KO2’s Honda CR-V windshield washer nozzles Hella 500FF fog lights Energy Suspension power steering rack bushings 4Runner: Hankook DynaPro ATM RF10 265/70r17’s TPMS Bypass mod RCI Skid Plate CBI Ditch light brackets 1.25” Wheel Spacers 2” Front Leveling Kit
    Won’t hurt it but I think por15 would be a better option.
  4. Jan 4, 2019 at 10:32 AM
    TacoGlenn
    TacoGlenn Nobody Makes a Monkey Outta Me!
    PNW
    '13 MGMAC 2.7L SR5
    Hellwig 1251's, Leer 122, Kahtec smart stop delay flashing 3rd brake light, de-chromed, de-badged, WeatherTech mats, WeatherTech side window deflectors,
  5. Jan 4, 2019 at 10:37 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Shouldn't have to worry about rust in Texas either, they don't use road salt there as it doesn't get cold enough. Can get pretty humid but that won't lead to much rust unless you completely neglect the truck. Rustoleom should be fine
  6. Jan 4, 2019 at 12:04 PM
    KSDoubleTaco
    KSDoubleTaco Well-Known Member
    Kansas
    02 DoubleCab
    I second the POR15 recommendation. Rustoleum won’t hurt but isn’t the best solution if you’re going to the trouble of cleaning and painting the parts. As others have said, you should have any trouble in TX.
  7. Jan 4, 2019 at 2:32 PM
    970btu
    970btu Well-Known Member
    Ty
    Las Vegas
    99 Tacoma 3.4 5spd ext limited TRD 55K and counting
    OME, SPC UCA, ARB w/warn 10K winch, TG Rock Defense Rear, Marlin Clutch, Custom hi clearance under bed spare mount. 285/75/16. A ton of repairs done and a list up to come modifications.
    Yes that is a perfect time!
    There are a lot of nook and crannies that you cant get to with the suspension on.
    I like magnet paint better than the POR15. POR 15 is great sticking to rust but not so much already painted surfaces. https://www.amazon.com/Magnet-Paint...ocphy=9030753&hvtargid=pla-570271088760&psc=1
    People say you don't have to worry about rust in Texas but it is a large and diverse state my, home. The east has swamp lands and a lot of moisture in the air. There is the coast that has a lot of salt in the air The pan handle flat and that freezes and gets snow and there is West Texas that is dry as a bone.
    Fins any hole you can get to and use this https://www.eastwood.com/eastwood-i...6hQgnEDvdPPQ2jKC_FwvNxo7yvmZMZ9saAgCFEALw_wcB
    I used cup and wheel wire brushes on a angle grinder, and for a drill
    I welded one of the drill brushes to a long bolt so I could work it in even more spots
    I also welded some small chain to a small bolt and used it on the drill to loosen as much grime as I could in hard spots before painting.
  8. Jan 4, 2019 at 3:26 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    I hit my sliders, skids, and any thing else with a wire brush and a coat of rustoleum for touch ups and it works fine.
  9. Jan 4, 2019 at 3:31 PM
    eon_blue
    Azusa, CA
    This is true, people say us Californian's never have to worry about rust and for the most part it's true, but if you live near the coast or up in the mountains where they do salt the roads, rust is a very real concern
