Is it possible to have a tonneau cover that also allows for a cap???
Discussion in '3rd Gen. Tacomas (2016-2023)' started by radchris88, Sep 21, 2015.
  1. Sep 21, 2015 at 4:13 PM
    radchris88
    radchris88 [OP] Well-Known Member
    Christian
    NY
    2016 Tacoma TRD Off-Road MGM DCLB
    I have been asking all my truck owner friends and have come up short. I really like the tonneau covers for the trucks since you can throw groceries etc back there on a daily basis with out obstructing your vision. I also do some camping and love the advantages of a cap while camping, especially for storing extra gear or even sleeping in when it gets real nasty out. However, I do not like daily driving with a cap. I don't like the way it makes the truck look or the blind spots it creates. Has anyone come across a tonneau cover that does not affect the top "rails" of the bed so you can take it off and secure a cap on from time to time?
  2. Sep 21, 2015 at 4:57 PM
    usadaytrader
    usadaytrader Well-Known Member
    <watching>
  3. Sep 22, 2015 at 6:46 AM
    NoDak
    NoDak Well-Known Member
    JR
    Minot, ND
    16 Tacoma TRD Sport 4x4 Blazing Blue
    even if you did find a workable solution, the hassles:
    1. removing the cover (barely 1 person)
    2. putting on a cap (requires at least min. 2 people, prob 3 due to weight)
    3. storage of a cap
    4. if your lucky you have a contraption to raise lower the cap in your garage (rarely see this, usually self made)
    5. could only use 1 or the other, never at the same time
    6. fit would be shoddy as your overlapping mount points on the cap/cover.
    this might be workable with the new oem cover since it wont cover the rails, but IMO its going to look like crap.
  4. Sep 22, 2015 at 6:58 AM
    fragatak
    fragatak New Member
    If you do want a tonneau cover that doesn't effect the bed at all my friend has an extang trifold on his Silverado and that doesn't require any mod to the bed to rails. Check it out. www.extang.com
  5. Sep 22, 2015 at 7:06 AM
    radchris88
    Christian
    NY
    Yeah I know about the cap storage and putting it on and off. My dad has two trucks with caps that I have to help him put on and off regularly. If I had to pick only one, I would probably go with the cap.
  6. Sep 22, 2015 at 7:06 AM
    2016_dbag
    2016_dbag Well-Known Member
    2016 POSTURD
    Just get a cap and be done with it
  7. Sep 22, 2015 at 7:07 AM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    With any tonneau on, even between the rail mount ones you can't mount a cap without removing it because you won't be able to mount the clamps. I think your best bet is to get a tonneau and some kind of soft cap like a bestop or soft topper. Those can go on and off with one person in a few minutes. I do this on my truck and I can leave the tonneau mounts in the rails.
  8. Sep 22, 2015 at 7:10 AM
    radchris88
    Christian
    NY
    Do you know what model it is? They don't have any for the 2016 yet but the 2015 has 9 possible models.
  9. Sep 22, 2015 at 8:18 AM
    fragatak
    fragatak New Member
    I think the version he has is like the Solid Fold 2.0. Here is a link to the install instructions off there site.
    https://www.youtube.com/watch?v=Mpt_RR2Suus
  10. Sep 22, 2015 at 8:47 AM
    radchris88
    Christian
    NY
    I am not trying to use both at the same time. I will be using a tonneau cover 99% of the time and the times that I chose to go camping, I will take the tonneau cover off and put a cap on.
  11. Sep 22, 2015 at 8:50 AM
    radchris88
    Christian
    NY
    I think that will totally work! Simple clamps to secure the tonneau cover with out any permanent mounts. Now to find pricing...
  12. Sep 22, 2015 at 9:27 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    I don't think there is a market for what you are requesting. You couldn't have both covers on at the same time because, well, that makes no sense.
    I would get the Tonneau you want then get something like a Bestop or Soft Topper for the cap. Both easy to put on and take off as you need to.
  13. Sep 22, 2015 at 9:53 AM
    radchris88
    Christian
    NY
    I wouldn't have both of them on at the same time. I would switch them. Most of the tonneau covers I have experience with have permanent rails to mount on the truck so the bed rails are no longer flat making it impossible to use a cap even after you take the cover off. I know the extang will do the trick but they are really expensive. I will keep looking but that might be my choice.
  14. Sep 22, 2015 at 2:29 PM
    Eric5273
    Eric5273 Well-Known Member
    Eric
    New Jersey
    Wow, thanks for that link. I don't really like the look of the factory cover, but I am the least handy person in the world. I also have a bad back, so installing anything that takes more than 5 minutes is a bad idea for me. So I was thinking that I would be stuck with the factory cover. But this looks totally doable! :)
  15. Sep 22, 2015 at 3:05 PM
    radchris88
    Christian
    NY
    Been doing a little research as well now. The gator evo seems to be another good choice, not quite as easy to install, but still incredibly easy. Costs quite a bit less too.
  16. Sep 22, 2015 at 3:19 PM
    radchris88
    Christian
    NY
  17. Sep 22, 2015 at 5:30 PM
    Dagosa
    Dagosa Well-Known Member
    New England
    2015 Taco TRD OR
    Debaged
    Caps can be had with adapters that secure the cap to the rails. Find a cover that does as well.
  18. Sep 22, 2015 at 6:43 PM
    ytmndan
    ytmndan vicarious enthusiast
    Southern Maryland
    Why don't you just get a tonneau for driving and a truck tent for camping? That's my plan.
    Dagosa likes this.
  19. Sep 22, 2015 at 7:15 PM
    radchris88
    Christian
    NY
    I specifically want a separate tent so I can store stuff in the bed of the truck.
