Is it fine to replace fuel filter while gas tank is full?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Marick cucinella, Jun 25, 2021.
  1. Jun 25, 2021 at 11:58 AM
    Marick cucinella
    Marick cucinella [OP] Member
    Marick
    03 tacoma 4x4 double cab
    Knn intake
    So I'm changing my fuel filter and I thought to myself wouldn't it be better when the fuel is low. anyone know? I seen one thing saying you should, thankyou
  2. Jun 25, 2021 at 12:03 PM
    Marick cucinella
    Marick
    Knn intake
    I'm still getting familiar with working on my truck what do you mean by pulling the bed off
    1997tacomav6[QUOTED] likes this.
  3. Jun 25, 2021 at 12:04 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Fuel level in tank doesn't make any difference when the in tank fuel pump isn't on.
    Nessal likes this.
  4. Jun 25, 2021 at 12:05 PM
    Madjik_Man
    Colorado Front Range
    You have to depressure the system before removing the fuel lines.
    The less fuel the better but if you remove the fuel pump relay and crank the truck over until it dies, the system won’t be pressurized anymore.
  5. Jun 25, 2021 at 12:05 PM
    Glamisman
    Glamisman Well-Known Member
    the best advice I can give is take the fuel cap off to relieve any pressure and put it back on, wrap a rag around your wrist and use quality flare/line wrenchs. If you round off the captured fitting, you are screwed. If you think you can tough out gasoline on your body then you havent had it leak into your arm pit... it burns and burns, jumping up and down and cussing type burn.
    MalinoisDad and TWJLee like this.
  6. Jun 25, 2021 at 12:20 PM
    1997tacomav6
    Denver
    My mistake, I was thinking fuel pump, :),
    Just MAKE SURE you use a line wrench
    MalinoisDad likes this.
  7. Jun 25, 2021 at 12:23 PM
    Marick cucinella
    Marick
    Knn intake
    Alrighty I'll go get some of those wrenches and get to it I appreciate yall
    1997tacomav6 likes this.
  8. Jun 25, 2021 at 12:26 PM
    1997tacomav6
    Denver
    You just need one,
    Get a good maker wrench because those line nuts will want to slip and round the edges in the wrench
  9. Jun 25, 2021 at 12:28 PM
    1997tacomav6
    Denver
    And have a 5 gallon bucket available because the fuel will want to drain all over the place after you break the lines loose, have your eyes protected if the pressure of gas hits you in the face.
  10. Jun 25, 2021 at 12:38 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Or keep a bolt handy and plug the hose
  11. Jun 25, 2021 at 1:06 PM
    Nessal
    Nessal Well-Known Member
    Texas/Bay Area
    2003 V6 4X4 TRD DCAB
    I take the gas cap off and leave it overnight to depressurize and I get minimal gas coming out.
  12. Jun 25, 2021 at 1:14 PM
    1997tacomav6
    Denver
    I’ve replaced my filter many many times, never had an issue.
    The last time for whatever reason the pressure was still there after my cap was off, probably from the engine side and I got sprayed down with gasoline when the nut came loose , uggg
  13. Jun 25, 2021 at 5:05 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I crack the line let it drain I never get much fuel what ever is in the lines .
    Arm pits must be sensitive It never bothered me on my hands and arms most often it drips off my elbow.
  14. Jun 25, 2021 at 6:26 PM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    A lot of good advice already about de-pressurizing the line, and using line wrenches.
    I'd also say, if you are in the rust belt and the fittings are rusted and the corners of the joint are looking weak, be prepared to abandon the line wrenches and go to vise grips. Don't completely round them off before making the switch. You want some flat area left on the fittings to get a good grip.
  15. Jun 25, 2021 at 7:09 PM
    MalinoisDad
    MalinoisDad Misanthropic dog person
    Michael
    01 TRD PreRunner 5VZ
    5100s w/ 881s, JBA UCAs, J59s, other stuff and things
    Totally agreed. The proper tools can save you a bunch of downtime. A bought a line wrench just for this job and I’m glad I did.
    Going off memory I think it’s a 14mm
  16. Jun 25, 2021 at 7:11 PM
    MGMDesertTaco
    Be super careful with the excess gas and fumes. I like to wash up before starting up the vehicle or re-connecting the battery.
  17. Jun 26, 2021 at 10:22 AM
    Marick cucinella
    Marick
    Knn intake
    Are they pretty durable I know I sound paranoid but I dropped the box it was in only from a couple feet on carpet it should be good right?
  18. Jun 26, 2021 at 10:28 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    If you are working on your back......suggest a pair of ear plugs.
    I was changing the fuel filter on our '02 Chevy Trailblazer. Easy task, the filter is under the driver's side just in front of the fuel tank. As I was releasing the pressure, the gas was squirting into a container. But some had to drip onto my arm, run down my arm, onto my face then into my right ear..........AAAAAAGGGGGGGGHHHHHHH!!!!!!!! :bananadead::bananadead::bananadead::eek::eek::eek::eek: Spent the next 30 minutes flushing my ear with a syringe. My ear hurt for 2 days.
    A set of ear plugs would have avoided this trauma.
    Madjik_Man likes this.
  19. Jun 26, 2021 at 3:15 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Only if your luck is like mine and it landed just the right way to impact one of the threaded holes enough to egg shape things.
    That is about all you might damage.
