Is it bad to park with wheels turned?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wiseco68, Jul 22, 2014.
  1. Jul 22, 2014 at 11:15 AM
    wiseco68
    wiseco68 [OP] Member
    Garrett
    Virginia
    2014 TRD Sport
    Are there any steering or suspension components that are strained if I park like in the picture?
    I searched and couldn't find anything about this. It might sound stupid, but it seems that cars park a little farther from my truck when they see the tire sticking out some. So with the sliders and tire poking out I try to keep the soccer moms from beating my paint up. The only reason I think it may be bad for something is that if I let go of the steering wheel when all the way over it wants to straighten out some. Didn't post in suspension section b/c that seems to be more for lifts.
    Thanks.
  2. Jul 22, 2014 at 11:16 AM
    JoeTacoma02
    JoeTacoma02 Well-Known Member
    Doubt it'll hurt anything.
  3. Jul 22, 2014 at 11:20 AM
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    It won't hurt anything from what I know. The steering geometry is designed to lift the vehicle a little when the wheels are turned. That's what causes the truck to want to go in a straight line and why the wheel wants to turn back towards center sometimes.
  4. Jul 22, 2014 at 11:21 AM
    teamcurtis
    teamcurtis Well-Known Member
    Curtis
    San Diego
    2015 DC 4x4 Super white
    285/75/16, snugtop xtravision, pop-lock
    its actually the law when parallel parking on a hill
  5. Jul 22, 2014 at 11:24 AM
    wiseco68
    Garrett
    Virginia
    2014 TRD Sport
    thank you all for putting a newb at ease
  6. Jul 22, 2014 at 11:27 AM
    Square
    Square Well-Known Member
    Brian
    Mission Viejo, CA
    '14 DCSB SR5 4WD MGM
    As long as you don't hold it all the way over on the lock and then turn your truck off, you are fine. By the lock, I mean the point where it is physically impossible to turn anymore because it is at the end.
  7. Jul 22, 2014 at 11:33 AM
    wiseco68
    Garrett
    Virginia
    2014 TRD Sport
    Gotcha. Thanks.
  8. Jul 23, 2014 at 8:21 AM
    wgreenlee1021
    wgreenlee1021 Off the Meds Again...
    It's the law when parking down or up hill and then you have to turn the wheel so they will be stopped by the curb if there is one.
    It's not recommended to park like this on level ground like in the picture.
    You should have all the wheels sitting straight.
    You are going to pull from there straight out so they should be straight.
    If you pull out of there with wheels turned then to truck is under strain until the wheels straighten.
    I always make sure the steering wheels match the rears.
  9. Jul 23, 2014 at 9:07 AM
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    I can honestly say I've never heard this question before. :)
  10. Jul 23, 2014 at 9:08 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Never turn your wheels if your not in motion.
  11. Aug 1, 2014 at 10:02 AM
    wiseco68
    Garrett
    Virginia
    2014 TRD Sport
    I was worried I may be putting a strain on something. Thanks for all the different opinions.
  12. Aug 1, 2014 at 10:26 AM
    XXXX
    sKiP
    05 Prius
    if your a 4x4 it will put stress on one side of the CV boot more than the other. I would not do it all the time.
