Is Goof Off safe on auto paint?
Discussion in 'Detailing' started by Hook78, Jan 10, 2019.
  1. Jan 10, 2019 at 12:33 PM
    Hook78
    Hook78 [OP] Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    I’d be applying to a rag and using to remove adhesive from a decal. Safe? Thanks.
  2. Jan 10, 2019 at 12:33 PM
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    No. But goo gone is
  3. Jan 10, 2019 at 12:35 PM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    How about WD-40 instead?
  4. Jan 10, 2019 at 12:35 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Goo gone
    NMTrailRider likes this.
  5. Jan 10, 2019 at 12:45 PM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    Ok thanks fellas.
    El Duderino likes this.
  6. Jan 10, 2019 at 3:18 PM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    I think i've used it. BUT, any time i use something like that on paint, i wipe with rubbing alcohol and then water to get it all off asap.
  7. Jan 10, 2019 at 3:37 PM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    I just went back to the hardware store and swapped the Goof Off for Goo Gone. It worked pretty well but it was a huge pain in the butt to get rid of the outline of the TRD decal. It was a hard combination of dirt and adhesive and I had to go after it with my thumbnail.
    Washed the whole area with regular auto soap afterwards and everything turned out ok. Now I can put on the new custom bedside decals.
  8. Jan 11, 2019 at 4:52 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    I would use a tiny bit of heat and watered down isopropyl alcohol.
    Clay bar to get the rest off.
    Don’t scrub and use your nails. I bet your paint is marred up. Since you have white to you probably won’t see it until you get some sun on it. But may want to plan to polish the area now.
  9. Jan 11, 2019 at 5:08 AM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    I initially used heat to take off the decal. It still left behind the outline. I tried clay bar, wouldn't take off the remnants. Afterwards used compound on the whole area, then clayed it fully. Seen it in the sun, looks great.
  10. Jan 24, 2019 at 10:03 PM
    runner05
    runner05 Well-Known Member
    Karl
    Wd40 can remove sticker residue and is safe on paint. You just need to wash and wax your truck after using it.
  11. Jan 25, 2019 at 2:45 AM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    WD40 didn’t do the job, I tried that before going back out for Goof Off.
