Is freon green? Strange leak
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ailll1, Sep 27, 2014.
  1. May 9, 2017 at 8:57 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Do not use stop leak! Repair the leak via replacing the bad part or tightening the fitting.
  2. May 9, 2017 at 8:58 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Not to cut hairs, but "A/C Freon" is R12. No longer used in the mfg. of today's vehicles
  3. May 9, 2017 at 9:11 AM
    Dragons Taco
    Dragons Taco Well-Known Member
    Derek
    Cary/Raleigh NC
    06 Black TRD-S 4WD 4D 6SPD and MINE!
    Can ya spell Tonneau
    Wow!
    There are some pretty smart fella's here.
    As long as we are getting into the weeds with details, OP's question was "is freon green?" The answer is no, it's clear.
    While it may not be official trade name, 134a refrigerant is still universally called "Freon" among laymen and professionals alike. Think Xerox, which became a noun and a verb.
    :nerd:
    CurtB and PottMatter like this.
  4. May 9, 2017 at 10:31 AM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    ^this
    and... how many bullets does your clip hold? :bananadance:
  5. May 9, 2017 at 11:20 AM
    Boomkanani
    Boomkanani Well-Known Member
    Goldsboro, NC
    2009 TRD OffRoad DCSB - 6 Speed
    Some stuffz
    Freon is not green...however it normally gets mixed with a green/yellowish UV dye to detect leaks easier. So if it's leaking...it probably looks green/yellow or I've seen purple UV dye too
  6. May 9, 2017 at 1:19 PM
    koditten
    Kirk
    Central Michigan
    Don't agree with comment about pros calling it Freon. I don't know any that do this. If speaking general, they all refer to it as refrigerant.
    Lester Lugnut likes this.
  7. May 9, 2017 at 1:22 PM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    people still ask me for a Kleenex even if its a scotts tissue, powder puff rag, puff plus, etc yadda yadda
    so call it Freon if you want, we smaht peeps know what it really iz
    CurtB likes this.
  8. Jul 10, 2017 at 11:52 AM
    forealz
    forealz Active Member
    Los Angeles
    07 PreRunner OffRoad TRD 33k
    Welp Stealership wants $1050 and LexTech in SoCal wants about $850. Anyone else in SoCal had this fixed for cheaper?
    AC is officially dead as a of this morning. Just blowing hot air.
  9. Jul 10, 2017 at 12:06 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    For what it's worth, my girlfriend had a shop here in Los Angeles replace her AC compressor on her '04 Honda Accord and it was a $900 job, we called around quite a bit and the only place that was a little cheaper had terrible reviews. The parts weren't that expensive but the labor was what ran it up so high. LA isn't a very cheap place to get work done on your car/truck.
  10. Jul 10, 2017 at 2:56 PM
    Boomkanani
    Goldsboro, NC
    Some stuffz
    I still say do it yourself...AC work is not cheap because of the labor. 1. Its working with hazardous material 2. People will pay a lot for AC in warm places.
  11. Jul 10, 2017 at 3:01 PM
    koditten
    Kirk
    Central Michigan
    Fix it yourself. You can find all the information you need pretty easy.
    You can buy a vacuum pump and manifold gauges from HF for around $100. The condenser is around $50. Refrigerant with be around $20.
  12. Jul 10, 2017 at 3:19 PM
    Snotrocket
    Snotrocket Well-Known Member
    Maine
    2022 TRD OR DCLB
    Looks like it's just leaking at the seal at that joint. Cheap and easy fix.
