Is freon green? Strange leak
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ailll1, Sep 27, 2014.
  1. Sep 27, 2014 at 2:58 PM
    ailll1
    ailll1 [OP] Well-Known Member
    Alex
    Québec, Canada
    2016 Tacoma Trd Sport Double cab
    I have found a strange looking green leak at the bottom of my A/C rad. I thought freon was clear.Maybe dye?
    My A\C is still cold but I guess not for so long.
    Anyone ever see something like this?
  2. Sep 27, 2014 at 3:03 PM
    05taco2.7
    05taco2.7 Well-Known Member
    JIMSTER
    omaha nebraska
    Soon to come
    Thats ac dye looks like that fitting or the condenser is leaking
  3. Sep 27, 2014 at 3:22 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    Yep, that's what a A/C freon leak looks like.
    You could attempt to tighten it and add more r143a+ but it will probably still leak a little. The R134A+ is supposed to have a leak sealer but usually doesn't work perfectly.
    Best bet is to go to a mechanic for all A/C issues.
  4. Sep 27, 2014 at 4:16 PM
    ailll1
    Alex
    Québec, Canada
    Thanks guys!
    I'm still under extended warranty so I might as well use it and bring it to toyota.
  5. Sep 27, 2014 at 4:46 PM
    reece13
    reece13 Well-Known Member
    North Carolina
    2010 TRD sport, 6spd, 4wd
    Toytec Coilovers, Total Chaos uca's, Wheelers aal+Bilstein 5160's. 285/70/17's, Method Double Standards. Magnaflow exhaust, GrilleCraft grille, Allpro bumper,diff breather relocate, yellow wire mod, oil catch can, weathertechs.
    Yup. Looks like the condenser is busted or the o-ring between the a/c line and condenser is shot. If it's under warranty, take it to Toyota.
  6. Sep 27, 2014 at 5:09 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    It's the PAG oil that's green yes it is a leak.
  7. Sep 27, 2014 at 5:41 PM
    ntilehman
    ntilehman Well-Known Member
    Seth
    Charlotte, NC
    09 Prerunner Off Road
    Rock Sliders Front Light Bar +1.5" Front Arms with Ext. Kings
    You definitely have a leak. The refrigerant carries the oil and the dye in the oil in what you see. Take it to a mech and have the a/c system properly evac'd and the seal replaced and recharged.
  8. Sep 27, 2014 at 8:12 PM
    Idaholandho
    Idaholandho The other white meat
    3 Now - 2022 Trail Edition, 2015 TRD 4x4 and a 2006 SR5 4x4
    2015 Tacoma, Magnuson Supercharger, Bully Dog Flash and GT, Safari Snorkel, Toytec BOSS 2.5 Coil Over Front, Toytec BOSS Aluma 2.5 Rear, Toytec 10 Leaf Pack, Stainless Brake Lines, Icon UCA's, CBI Reverse Adj Shackle Mounts, CBI Ubolt Flip Kit, Timbren Bump Stops, CBI Bushmaster 2.0 Front Bumper w/ Warn M8000S Winch and SR2 Rigid Flood Lights, CBI Bushmaster 2.0 Rear Swingout Bumper, Rigid SR2 backup lights and Dual RotopaX / Fuel/First Aid Pack, CBI Rock Sliders, CBI Full Skids and CBI Rear Diff Armor, BAMF LCA Skids, FrontRunner Outfitters Slimline II Roof Rack w/ Rigid SR2 40" Combo Light Bar, Rock lights, Rigid pods in Bed Rack, Intelligent Battery System w/ Dual NorthStar batteries, Spod Power Distribution, illuminated switch panel in sunglasses holder, Viar Extreme Duty On-Board Air w/ 2.5 Gallon Tank under bed, Air 2 Air Sys, Magnaflow Exhaust, Fuel Off Road Trophy Wheels, 285/75/17 Toyo Open Country R/T, Diff breather mod, FX-R BHLM Demon Eye headlights, Esuse LED Fog Kit, Pelfreybilt Camera Relocation mount, Pelfreybilt ax/shovel bed mount, Debadged, tint, a 2006 Tacoma SR5 and a 2022 Trail Edition
    ^ Best and only advice.
  9. Jan 21, 2017 at 12:41 PM
    forealz
    forealz Active Member
    Los Angeles
    07 PreRunner OffRoad TRD 33k
    Apologies for the necro, but the stealership wants $1050 to fix this one on my 2007 TRD OF with 33k miles. Sigh. I hate the moment I walk into the dealership.
  10. Jan 21, 2017 at 1:34 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    Any Harvard Business Professor will scold you for considering the dealership to fix that.
    Take it to a local small shop. You'll be pleasantly surprised at their quote.
  11. Jan 21, 2017 at 2:52 PM
    JeffreyB
    JeffreyB Well-Known Member
    Jeff
    2015 Access Cab 2.7 5 Speed 4X4
    What he said. You should only use the dealership mechanics for warranty work.
  12. Jan 21, 2017 at 3:04 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Even if you need a condenser and dryer, the cost of those parts is less than $200.
  13. Jan 22, 2017 at 3:06 AM
    Boomkanani
    Boomkanani Well-Known Member
    Goldsboro, NC
    2009 TRD OffRoad DCSB - 6 Speed
    Some stuffz
    i just changed out my AC compressor not long ago. Autozone has most of the specialty tools needed in their loan-a-tool program. Only thing that isn't really DIY is evacuating the system before loosening any connections...just had a local shop do it. They shouldn't charge much because they can reuse the refrigerant. Don't put any of that stop leak crap in the system though
  14. Jan 22, 2017 at 3:11 AM
    Boomkanani
    Goldsboro, NC
    Some stuffz
    why..?
  15. Jan 22, 2017 at 3:36 AM
    Boomkanani
    Goldsboro, NC
    Some stuffz
    isn't that the point of a vacuum pump and pressure test before refilling?
  16. Jan 22, 2017 at 4:05 AM
    Boomkanani
    Goldsboro, NC
    Some stuffz
    yes i understand. shop's call
  17. Feb 1, 2017 at 6:01 PM
    forealz
    Los Angeles
    Sorry for the delay in my response.
    As always, you guys are amazing.
    I'll look for a good shop in Los Angeles.
  18. Feb 1, 2017 at 6:50 PM
    Old_Skool
    Old_Skool Well-Known Member
    Rich
    Maine
    2017 Subaru WRX, Crystal Black Silica
    Would everyone stop calling it Freon. Freon was the trademark by the Chemours Co. for R12 refrigerant. R134A is simply called R134A.
    Also, when a shop evacuates an AC system the refrigerant is run through a dissectant filter that removes moisture. It's an acceptable practice to reuse that same refrigerant. A tech will either fill a measured amount of liquid refrigerant into a charging cylinder, or program the recycling/charging machine to fill the system. Head pressure should be bled from the recycling machine tank on a regular basis.
    JTM1, Sterdog and koditten like this.
  19. Feb 1, 2017 at 9:59 PM
    koditten
    Kirk
    Central Michigan
    I was gonna mention this earlier, too. I just gave up worrying about correct vernacular. I'm happy that people want to learn about refrigeration.
    PottMatter and Old_Skool like this.
  20. May 9, 2017 at 8:38 AM
    meafordmike
    meafordmike Well-Known Member
    New Brunswick Canada
    08 Tacoma 4X4/ 4Dr 6 speed, Sport/ Towing
    Devil Horns, Wet Okoles, WeatherTechs, Radflo Coilovers, OME Dakar's, FJC Gun metal rims, 265/75/16 BFG All Terrain TA/KO, Rear Diff breather Mod,
    Just noticed mine is leaking in the same spot. I was hoping to try to tighten or put some stop leak in it? I am sure some Teflon tape would work if I had it evacuated first.
