Is factory speaker wire sufficient?
Discussion in 'Audio & Video' started by Eastxn, Apr 17, 2022.
  1. Apr 17, 2022 at 7:18 AM
    Eastxn
    Eastxn [OP] Active Member
    2020 4X4 White Tacoma TRD off-road
    Good morning everyone. I tried searching but couldn't find a straight answer for my question. I have a 2020 tacoma with the non JBL 8" entune head unit. I recently upgraded the tweeters to kicker subaru and the front doors to kicker ks series 6x9 3 ways. The sound is much improved.
    What I am wondering is if I decided to add an amp like the audiocontrol 4 channel that is 125wx4 RMS, Can the factory speaker wires handle it as is or do I need to upgrade to a thicker gauge wire? How high can you go before the factory speaker wiring is insufficient?
    Jaredius likes this.
  2. Apr 17, 2022 at 7:45 AM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    Not for that amount of power.
    50w rms is probably about as high as I’d personally go. 75w is probably pushing it
    I will also say, I’m running Kicker KS series in my truck and my amp does 50w RMS. 50% volume makes my ears hurt.
  3. Apr 17, 2022 at 8:35 AM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    once i'm adding an amp, i don't personally re-use the oem speaker wire, regardless of wattage. it's only a little more work to run my own wire, and i've already got the vehicle apart for the amp install.
    Jaredius and GRNT4R like this.
