Is dexron vi okay for ATF fluid?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Cbirzes, Mar 20, 2024.
  1. Mar 20, 2024 at 4:34 PM
    Cbirzes
    Cbirzes [OP] Well-Known Member
    Colin
    2010 Tacoma 4x4 base
    Had my trans fluid changed about 500 miles ago. Mechanic used Dexron vi, should I change the fluid? I changed my radiator a few weeks ago and topped it off(yes I used the at oil temp/obd connecter) I’m getting some slips going down hills but that’s about it. Runs well otherwise
  2. Mar 20, 2024 at 4:40 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    What are you feeling exactly? Usually the term slip means it's struggling to apply/hold a specific gear going uphill, not downhill
    Any check engine light or warning lights?
  3. Mar 20, 2024 at 4:43 PM
    Cbirzes
    Colin
    No lights. Rpms are shooting up when I go down hills
  4. Mar 20, 2024 at 4:43 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Sounds like engine braking. Sounds normal
    Are you in D? Or are you manually shifting down to 4 or 3 at times?
  5. Mar 20, 2024 at 4:47 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    A slip feeling coming to a stop can mean you are low on fluid.
    As for Dex-VI being compatible.....
    Walmart SuperTech says it is, but I'd want to stick with WS or Valvoline MaxLife myself.
    Chuy likes this.
  6. Mar 20, 2024 at 4:52 PM
    Cbirzes
    Colin
    In drive
  7. Mar 20, 2024 at 4:55 PM
    Cbirzes
    Colin
    I was thinking of draining and swapping in max life. It’s valvoline dex 6 in there right now.
    Also don’t think he filled it correctly considering it took me well over a quart to top it off after I changed my rad out. Wish I knew about this forum before I had him do it:D
  8. Mar 20, 2024 at 4:55 PM
    TnShooter
    Deogee
    STOCK
    Foot on or off break?
  9. Mar 20, 2024 at 5:00 PM
    Cbirzes
    Colin
    Off sir
  10. Mar 20, 2024 at 6:30 PM
    TnShooter
    Deogee
    STOCK
    That doesn’t sound normal.
    Mine only engine brakes if I’m on the brake.
    Try checking the level and maybe switching to MaxLife or WS.
  11. Mar 20, 2024 at 8:05 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    If you have a V6, your Taco takes ATF WS. If you have the 4 cyl, it takes ATF T-IV.
    The data sheet on Valvoline’s website does not show that Dexron VI is compatible with either one. Their MaxLife is compatible with both. That is what I and many others use. If switching over, do a flush to remove as much as the Dexron as possible.
  12. Mar 20, 2024 at 8:17 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    I would not go back to that mechanic, at least for tranny related work.
  13. Mar 20, 2024 at 8:53 PM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
  14. Mar 21, 2024 at 8:06 AM
    tacobp
    tacobp Well-Known Member
    Bob
    North Carolina
    09 Tacoma, 2.7 automatic
    Installed a Pop n Lock,,That's it !..Bone stock
    You really need to replace all of the fluid not just what's in the pan to be on the safe side...
  15. Mar 22, 2024 at 7:26 PM
    Cbirzes
    Colin
    Chuy likes this.
