is BACK PRESSURE a myth?
Discussion in 'Technical Chat' started by gray223, Jan 6, 2014.
  1. Jan 6, 2014 at 4:58 PM
    gray223
    gray223 [OP] Well-Known Member
    SE Missouri
    2014 Tundra Limited
    After posting about a bad cat and wondering if I should just do a cat delete everyone was saying it will reduce back pressure in the engine. I've seen this "back pressure" discusses on many other threads. But I haven't every heard of a F1 car or NASCAR having any restrictive exhaust.
    I know that modern cats arent very restrictive in the first place though, but people say reduced back pressure will reduce torque. Now I have read that modern engines are designed with back pressure in mind and when its reduced it produces a fuel curve which makes it run more lean and this effect torque.
    Now if this is true would a device like the urd MAF sensor simulator return this fuel curve to normal or adjust for it.
  2. Jan 6, 2014 at 5:02 PM
    drunktaco
    drunktaco Well-Known Member
    Sage
    Southwest Va
    Icon ext travel C/O's, Total Chaos UCA's, King R/R shocks, All-Pro leaf pack, lights, RCI skid, Brute Force sliders, ect.
    Back pressure helps with low end power. NASCAR, F1, ect are running in the higher rpm range. No need for back pressure, less restriction the better to a point.
    As far as the URD thing, I'm not sure.
  3. Jan 6, 2014 at 5:07 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Guess what. If you take out your 02 sensor and put on a back pressure tester, if you have back pressure, that's means your exhaust is restricted. That's bad. It'll run like piss, if at all. You don't want any. There's enough restriction built into the factory exhaust.
  4. Jan 6, 2014 at 5:11 PM
    Frkypunk
    Frkypunk "Death is what you make of it."
    Timmy
    Woods of P.A.
    2010 Tundra limited,2015 Highlander limited, Prius(commuter)
    Got the gas mileage down to 13mpg! Modification complete
    If you have the 2.7 back pressure is probably your friend. I would never throw, say! a 3" exaust on a taco with a 2.7. They paid designers quite a bit of money to come up with this stuff...most of it is good...I would not mess with it.
  5. Jan 6, 2014 at 5:14 PM
    1moonshine2
    1moonshine2 Well-Known Member
    Appalachian Mountains in VA
    Tacoma 4x4, 4cyl, 5spd, reg cab
    It's not really about back pressure. It's about scavenging. Google it and do some reading. Yes, exhaust pipe diameter, and length will have an effect.
  6. Jan 6, 2014 at 8:43 PM
    gray223
    SE Missouri
    2014 Tundra Limited
    I did do some reading and people said that a internal combustion engine does not need back pressure but the designers have to design with back pressure in mind because of mufflers etc. So that's why lack of back pressure causes loss of power because the ecu thinks it needs back pressure because it was designed with it.
  7. Jan 6, 2014 at 8:44 PM
    NewRider
    NewRider Well-Known Member
    Travis
    Charlottesville , Va
    '87 4runner
  8. Jan 6, 2014 at 8:46 PM
    gray223
    SE Missouri
    2014 Tundra Limited
    And what about commercial engines, like none auto mobile engines? If back pressure helps with low end torque then why don't we see cats and mufflers on them?
  9. Jan 6, 2014 at 8:49 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    scavenging...
  10. Jan 6, 2014 at 8:58 PM
    gray223
    SE Missouri
    2014 Tundra Limited
    I'm wondering, has anyone done dyno testing comparing a stock, more restrictive exhaust to a more free flowing exhaust.
  11. Jan 7, 2014 at 6:36 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    There's a post somewhere, I think by chris4x4, that talks through this.
    As posted above, it's not really back pressure that's a problem, as back pressure is nothing more than the measure of restriction. The true issue is exhaust gas velocity through the exhaust system. For low-end, small pipes that keep the gases moving and enable scavenging within the exhaust system that help create some torque. For high-end, larger pipes enable exhaust gases to flow freely out of the system quicker.
    Designers then, have to design to a happy-medium for low-end and high-end use. Modifiers can tweak their own performance for low or high end by optimizing the pipe sizes for their own needs. Keep in mind the bends, lengths, cats, mufflers, connections, etc. all go into the exhaust system, so all changes can have an affect.
  12. Jan 7, 2014 at 8:14 AM
    fyremanpat
    fyremanpat Well-Known Member
    Pat
    757
    2013 DC LB TRD Sport w/Entune
    OME 886x and 5100's all the way around. Toytec AAL. Phillips x-treme vision headlights. 886 reverse lights. Borla exhaust. 20% tint. Hi 6 mod. 285/65/18 Nitto TG on 18" Moto Metal 955's. Airaid intake. Scanguage2.JBA LT's.GC Grill..more to come.
    if you ran at higher rpms all the time then you do not want back pressure....BUT for everyday driving i.e. stop and go traffic...you would want back pressure. Like said before, you will lose low end torque. If you want to get the both of best worlds, then install an exhaust valve. Closed at a stop light (low end torque) open at highway speed (high end torque)... some if not most industrial engines have mufflers but normally that is for sound reduction...which does cause some back pressure BUT in their applications they stay at a steady speed while in use
  13. Jan 7, 2014 at 10:33 PM
    gray223
    SE Missouri
    2014 Tundra Limited
    That makes since. Finally some answers!
