Is an AGM battery worth the cost?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mjbrown210, May 29, 2023.
  1. May 29, 2023 at 11:20 PM
    4-Day-Work-Week
    4-Day-Work-Week Well-Known Member
    2022 OR DCLB Army Green
    I run a group 27 AGM for a fridge that runs 24/7 in my gen 3 for work. I have a Lensun hood solar panel run to a charge controller in the engine compartment that keeps my battery topped off.
    It’s a little more money, but fixes the alternator problem without messing around with too much. The panel keeps the battery well at charge for days without running the truck. I put the fridge in last August and it’s run non stop since then. No issues with the battery, cold water and lunches for work, and cold beer for camping.
  2. May 30, 2023 at 12:28 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    I run 24F AGM as common everywhere due to the vibration, sealed, and heat as they seem to handle it better (in FL).
    Last one ran it for 5 years no issues and no altered charge circuits. Changed out as preventative.
    Cost is only about $25-75 more than the higher end lead acid types but yes much higher than a bottom level one.
    A cheap way to watch the battery is a simple plug in USB charger with a voltage meter on it.
    Many opinions out there on all this. Enjoy.
    4-Day-Work-Week and Revelations like this.
  3. May 30, 2023 at 5:05 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    batteryuniversity.com
  4. May 30, 2023 at 5:13 AM
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    I run a fridge on a separate deep cycle LiFePo4 battery. Running a fridge on your starter battery is a good way to get stranded. Despite the marketing mumbo jumbo, AGM batteries are not deep cycle batteries.
    GilbertOz likes this.
  5. May 30, 2023 at 5:40 AM
    Revelations
    Revelations Well-Known Member
    2014 MGM DCSB
    I had a XS Power AGM battery last me 7 years without any modifications to my charge system. It was a fantastic battery. I only paid $245 shipped for it back in 2015. Unfortunately, the cost has gone up a lot. It's now $400, so I decided to try out an Interstate AGM. It was $350 shipped from Amazon. I don't run any extra accessories. I just have a decent sound system. Everything has been running great as usual.
  6. May 30, 2023 at 6:00 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    AGM battery is sealed so it won't spill acid in hard cornering/braking and off-road. You can usually find equal or better CCA (compared to stock) in a smaller AGM size, saving weight. These are the two main advantages I see that prompted me to change to an Optima Red Top 35.
    The charging voltage is easily increased when flashing an ECM tune on the truck.
    Koolbreeze7 likes this.
  7. May 30, 2023 at 6:00 AM
    TartanEagle
    TartanEagle Well-Known Member
    '17 ACLB 4x4 MT
  8. May 30, 2023 at 9:27 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    I just popped a 24F EVERSTART MAXX AGM in my truck. Flashed a tune for AGM batteries to boost the charging.
    when looking at batteries(everstart Maxx specifically), it was only $40 more to go to AGM. My lead acid EVERSTART Maxx is going on 4 years so I decided to preemptively upgrade the starter battery and I’m now using the lead acid in the toolbox hooked up to a solar controller to run bed accessories and my fridge.
  9. May 30, 2023 at 9:39 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    I use AGM batteries in two vehicles I have no problems going on 5years now.
    Yes I do have a AGM charger the only time i use it is for electrical troubleshooting and one time I left the ignition switch on for a few days.
    At no time did the Deka or Interstate sales people say anything about needing to upgrade the alternator in the vehicle . As a vendor for both companies I never had to deal with any complaints in this area .
    Which would be brought to our sales persons attention.
  10. May 30, 2023 at 9:44 AM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    I upgraded to an AGM on my 1st gen because I was sick of the standard ones corroding everything in sight and never lasting more than 2 summers.
    So far it seems to hold its charge a lot better too.
    shakerhood, Revelations and Bivouac like this.
  11. May 30, 2023 at 11:04 AM
    Brucey
    Brucey Well-Known Member
    Bruce
    2018 DC LB SPORT 4X4
    Ovtuned
    Pay the extra money for a bigger lead acid battery vs agm.
  12. May 30, 2023 at 1:06 PM
    MGMDesertTaco
    FWIW, the 24F AGM Everstart from Wally World is only about 4lbs heavier than stock and still fits in the oem plastic battery tray. Too much weight on the front end and you'll risk damage/cracking the sheet metal.
    shakerhood likes this.
  13. May 30, 2023 at 1:47 PM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    Biggest advantage and reason I run AGM in all my vehicles is they will not dead-cell you and leave you stranded somewhere (or much worse your wife/family). I really don't care about all the other benefits. They work just fine on any healthy stock voltage alternator. I do run one in my tractor for the high vibration benefits though. Well worth the price for that extra insurance.
    muddog321 and TacoTime55 like this.
  14. May 30, 2023 at 2:01 PM
    SpeySquatch
    2016 TRD OR DCSB
    it’s like $20 more at Costco than a normal battery, but you should get the alternator tuned to charge at AGM specs…think I paid $125 for my Interstate AGM H46
  15. May 30, 2023 at 2:08 PM
    #35
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    Are you meaning AGMs aren't as deep a cycle as a Lithium battery? Cause AGMs can come in both starting and deep cycle format. Obviously you can't discharge 100% like a lithium, but you can get many cycles down 50% percent on an Deep Cycle AGM.
    I was actually planning to hop into the convo pointing out not all AGMs are deep cycle, which the OP seems to be more interested in.
    Bivouac likes this.
  16. May 30, 2023 at 2:08 PM
    #36
    Technique
    Alex
    Utah
    That's way cheap! Can't comment on the price for that size battery you listed, but an Interstate AGM Group 24F (stock size) is $180 at Costco. I just went and checked on Saturday to get one...they had none so I went with the Walmart EverStart AGM for the same price.
  17. May 30, 2023 at 2:12 PM
    #37
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    XS Power are very nice quality racing batteries , a friend of mine is running one of their 14 volt batteries in his street / strip bbc chevelle with no issues
  18. May 30, 2023 at 2:14 PM
    #38
    YF_Ryan
    Kent, WA
    Is 3rd Gen the same? I was thinking that only worked on the 2nd gen. It's exactly what I did. Had the Australian voltage booster, and it made a MASSIVE difference on my Yellow Top optima, and my 2x Blue Top house batteries (all wired to my alternator).
    I'm running just the one big X2 Power battery under my hood, since I don't need the house batteries anymore. Love having it though. OEM battery would hardly run my air compressor without the engine running, the X2 (and the optima before that) would run it perfectly fine without the engine running. The test they do at Toyota for CCA when doing their multi point inspection was always funny. CCA is supposed to be like 730 or something, and mine was consistently well over 1100. I always forgot to link my house batteries, woulda been hilarious to see what number would pop up on their test with 3 batteries hooked up.
  19. May 30, 2023 at 2:20 PM
    #39
    Schlucki
    Schlucki Well-Known Member
    Rich
    North Dallas, TX
    2020 DCLB TRD OR 4X4 Cement Taco
    A growing list of stuff
    Absolutely worth it.
    +1 on the Everstart AGM for the great deal that it is. Just check the battery before taking it home with a voltmeter. It should be standing at 13v or so. Sometimes they have some returns or duds on the shelf and don't pull them (happened to me).
    Get a tune and have them raise your charging voltage to 14.5-15v. Messing around with charges to top off is a pain in the ass and doesn't give you the full benefit of the battery.
    Besides, the tune will bring a smile to your face when you drive your truck.
    As soon as you fire up the truck, you will hear how much easier it cranks over with the little extra voltage. That means better starts and less wear and tear on your starter motor and just about anything else in the truck. Bonus as well, normal incandescent lighting will also be brighter.
    I worked on auto electrical and electronics for 30 years if you feel like doubting my observations on this, that is your call.
    Out2gtcha, TacoTime55 and YF_Ryan like this.
  20. May 30, 2023 at 4:07 PM
    #40
    4-Day-Work-Week
    It’s not an issue if you keep the battery topped off. I have no issues, friends of mine have no issues. It all depends on how you use the truck, how you’re set up. I’m stoked to not have the weight of an extra battery, cost of an extra battery, and space for more fun stuff. To each their own, but it’s more than feasible to run off your starter battery if you run your shit right.
