Is a Torque wrench absolutely necessary?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MxRacer190, Apr 29, 2010.
  1. Apr 29, 2010 at 12:44 PM
    MxRacer190
    MxRacer190 [OP] Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    My dad always told me I didn't need a torque wrench, and to just tighten as tight as I can. Now that I've been doing things on my own, I always see "torque this, torque that". Is it really necessary?
    Example: I wan't to put my AAL's on today, but I don't have a torque wrench. . .Should I go buy or rent one?
  2. Apr 29, 2010 at 12:45 PM
    Shack
    Shack Well-Known Member
    Lane
    Chester, VA
    2010 TRD Off Road 4x4
    Bilstein 5100-Front (1.75"), Pop N' Lock Tailgate, Rear Leaf TSB MR. Marv custom box and amp rack, JL 13TW-5, Memphis Audio Amps and Door Speaker, JVC DVD DD HU, Wet Okole, Weathertech Mats, Bed Mat
    Yes.
    wi_taco, Rock Lobster and Cudgel like this.
  3. Apr 29, 2010 at 12:46 PM
    Taco-NB
    Taco-NB MMMMM Taco's
    New Brunswick
    '09 4X4 SR5 Access Cab V6 - Black Sand Pearl
    ^^^ x2
  4. Apr 29, 2010 at 12:48 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Just buy a cheap one from harbor freight, they are $10. Better than guessing if something is tight enough, or over torquing and stripping a nut or bolt.
    davidstacoma likes this.
  5. Apr 29, 2010 at 12:48 PM
    MxRacer190
    Georgia
    06 SR5 4x4 Indigo
    I may sound like a child, but why? What difference does it make? As long as it doesn't come loose.
  6. Apr 29, 2010 at 12:49 PM
    desertdude59
    desertdude59 CRAZY 4WHEELER
    From the Mojave desert now in Wild and Wonderful W
    1991 toyota 4x4 sr5-lost but not forgotten
    4" lift after market front bumper bed mount lightbar/roll bar (4)6" kc's on the roll bar (2) kc flat back bumper mounts f/r gears for the 33's
    Go buy one at an autoparts store. I got a 1/2 drive from autozone. Not the most expensive, but it did the job
  7. Apr 29, 2010 at 12:51 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    I have installed a lot of stuff and most of it I didn't torque. I just made sure everything was still tight 100 miles later.
    But I do have one and try to use it. You can always just guess right now and install them. Then withing the next few days go buy one and check. I got a decent one from autozone for 25 bucks.
  8. Apr 29, 2010 at 12:51 PM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    A torque wrench can be a very important tool to have. Especially when you must torque specific things like wheel hubs or trunion bearings etc.... to the correct pre-load value. Also with alot of things being aluminum on todays engines you had better not just go tightening everything to "as tight as you can".
    usmc2msu likes this.
  9. Apr 29, 2010 at 12:52 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    everything was steel back in the old days, you could torque the hell out of eveything
    Now a days there is alot of aluminum, its a softer metal and can easily be damaged
    like a beer can!
    Climberdimer, Tim v and davidstacoma like this.
  10. Apr 29, 2010 at 12:53 PM
    98tacoma27
    Ben
    Not Beech Creek
    Hardware can only handle so much stress before it is weakened. Over-tightening/torquing is just as dangerous as under-tightening/torquing.
    dtaco10 likes this.
  11. Apr 29, 2010 at 12:54 PM
    SManZ
    SManZ Sold the Taco in June 2020
    Fauquier County, VA
    Current, 2020 Ford Super Duty Tremor, Previously 2010 Supercharged 4x4 Tacoma Sport 6-spd
    TRD Supercharger, King 2.5" extended travel remote-resi coilovers, OME Dakar leaf packs, King 2.5" extended travel rear shocks, Total Chaos UCAs, MBRP turndown exhaust, TRD intake, TRD Quickshifter, Goodridge SS brake lines, EBC Sport Rotors, Hawk HPS pads, TRD FJ Cruiser Special Edition 16" Anthracite Rims, Spidertrax wheel spacers, 265/75R16 A/T, Autometer oil pressure, oil temp gauges, TRD boost gauge, PLX DM-100 OBD II scanner, flexpod mounts, A-pillar gauge pods
    Do you want to be sure you tightened it enough or do you want to find out only when it falls apart?
    Some things aren't meant to be tightened as hard as you can tighten them. Bolts that go through parts that are supposed to move is one example.
  12. Apr 29, 2010 at 12:54 PM
    inlinejohn
    inlinejohn Well-Known Member
    Washington
    08 Tacoma TRD Sport SR5 4WD LB
    3" spacer/AAL lift, Toyo Open Country MT 265/70R17, Kenwood USB, Truxedo LowPro QT, Grillcraft w TOYOTA emblem...coming soon, Avid Offroading Sliders...coming soon.
    Y e s !!!!!
  13. Apr 29, 2010 at 12:55 PM
    TexasTacoma37
    Here's one example: Over-torquing lug nuts is quite common. Not only could you strip the nut by over-torquing, but you can damage your wheels too.
    Think if the nut is just about at it's breaking point when you put it on....a few bumps and it strips off. How many weeks would it take you to realize you are driving around with only 5 lugs?
    Picture the same thing if it were a front or rear shock. Even more of a disaster.
  14. Apr 29, 2010 at 12:55 PM
    desertdude59
    I agree. Aluminum is very fragile. Even with my torque wrench I had problems with my cam bolts. I had to fix the threads. A few stripped out. Imagine if the torque was different on all the bolts. Could have messed up some serious stuff. Well the point of the story is too better be safe than sorry.
  15. Apr 29, 2010 at 12:58 PM
    MxRacer190
    Georgia
    06 SR5 4x4 Indigo
  16. Apr 29, 2010 at 1:01 PM
    desertdude59
  17. Apr 29, 2010 at 1:02 PM
    ryhar85
    ryhar85 Well-Known Member
    W. WA
    05 TRD 3" lift
    3" Trailmaster lift, 18" rockstars blacked out, 275/65/18 sxt mud terrains, more to come.
    I have lifted two jeeps, my tacoma, done an engine transplant, break jobs, and countless other misc. DIY projects, and never once used a torque wrench. Never had a problem with any of the work done. I am a firm believer in 'common sense prevails'. Its as simple as - make it really tight, but not too tight. . . On the other hand, if you doubt yourself, maybe a torque wrench is a good idea. Just because I never use one, does not mean its a bad idea to have one. Just MHO. And good luck with the aal! Post pics when its done. :)
  18. Apr 29, 2010 at 1:04 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    I've got that one. My only complaint is it keeps loosening the adjuster and may change the torque setting on you as you use it. But it works. While you're at it, get a socket for your lug nuts to fit it too and don't ever use the lug nut wrench that came with the truck (store the torque wrench in its place instead). Using the OEM wrench will strip the fake cover off your lug nuts (or warp them).
  19. Apr 29, 2010 at 1:07 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    i have 2 torque wrenchs, a 1/2 and a 3/8 drive and i rarely use them. i can usually judge by feel how much foot pounds im putting on something. i should probably get in the habit of using them more though.
  20. Apr 29, 2010 at 1:08 PM
    MxRacer190
    Georgia
    06 SR5 4x4 Indigo
    Yeh too late for that lol. My lug nuts looks like shit. I have to beat them out of the socket everytime I rotate tires now, beacause they wont fit in the size they're supposed to. :anonymous:
    anyways, I'm heading to Oreilly's now, Ill post pics tonight :) even though I'm only working on the back today, then doing my 5100's up front Sunday. CANT WAIT!
