Is a full size spare worth it?
Discussion in 'Wheels & Tires' started by IronCladTRD, Dec 31, 2012.
  1. Dec 31, 2012 at 5:36 PM
    IronCladTRD
    IronCladTRD [OP] Consistently Irregular
    Corbin
    Hotel California
    2003 4x4 Manual V6 3.4L
    5100s/Eibach 3" lift, All-Pro Expo rear leafs, Elite front bumper & sliders, Smittybilt XRC8 winch, 33x10.5r15 BFG All terrains, Ultra Rogue 15x8 rims, homemade bed rack, Midland 1001z CB radio Deckplate mod, Century shell, train horn, debadged
    I recently upgraded to a larger size of tire (33" BFG T/A KO's). I still have a stock size spare. If I were to have a flat, I would only put the spare on to get me off the trail and/or to the nearest tire shop. Would running one tire of different size screw up my gearing, diffs, or anything like that?
  2. Dec 31, 2012 at 5:39 PM
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Anderson, SC
    2015 DCSB 4x4 trd offroad
    Ome 887s, dakars, lr uca,sliders, konig countersteer,
    yea it would screw up your trannny rotation ratio..... if you are into reall hard off-road or anything like that its worth the investment..
  3. Dec 31, 2012 at 5:42 PM
    zeekevin
    zeekevin Well-Known Member
    San Diego
    I would upgrade to full size spare . If you are on a budget I would find a used tire place that has your size or get a cheap brand spare in your size
  4. Dec 31, 2012 at 5:48 PM
    jandrews
    '09 FourDubDee TRD OR
    Using 4x4 with mismatched tire sizes is ill advised.
  5. Jan 1, 2013 at 9:57 AM
    IronCladTRD
    Corbin
    Hotel California
    Well unfortunately 33x10.5r15 is only made by BFG. I guess my next question is: Would there be any problems with using a spare on a 16" rim vs. all my other tires being on 15's? I know the tires would end up being the same diameter, but I imagine there'd be something of a weight difference...?
  6. Jan 1, 2013 at 9:59 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I'd think as long as the tire sizes match that you would be fine and that weight wouldnt be an issue especially if you arent going to be running the spare for very long until you got your other tire fixed.
  7. Jan 1, 2013 at 10:03 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I believe with a mismatched spare it's best to use it on the front and in 2wd for as short a distance as possible.
  8. Jan 1, 2013 at 10:07 AM
    FOUR X FOUR DUDE.
    FOUR X FOUR DUDE. Well-Known Member
    Barry
    Mountain Center, Ca.
    Tacoma 4x4
    TRD wheels, BFG tires, factory installed option.
    What about your normal passenger car with the small donut spare ? I don't think running down the highway in a sane manner (in 4x2 mode) will hurt anything such as gearing. I have big tires from the factory with a normal spare, there's no mention not to use the normal spare if I had to. Of course, you want to get it back to normal ASAP.
  9. Jan 1, 2013 at 10:19 AM
    IronCladTRD
    Corbin
    Hotel California
    I guess it would make sense for it to work on the front in RWD... Just trying to doublecheck. As it turns out, they don't make 33x10.5r16 tires so I'd probably end up having to get a wheel and tire identical to the ones I've got on now. That's going to be like a $300 investment. On the other hand, that much could buy me a skidplate.
    abhamber likes this.
  10. Jan 1, 2013 at 10:24 AM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    You really should try to match the diameter of the spare to the other tires as close as possible. you can get a skinnier tire on another size wheel. For example, you could get a 255/85/16 spare to closely match your 33-10.5-15. The diameter is almost the same and with a little trimming to the mount, it will tuck up under the bed nicely.
  11. Jan 1, 2013 at 10:27 AM
    IronCladTRD
    Corbin
    Hotel California
    I've got 33's. And I'm not worried about it fitting under the bed, that's where I keep my onboard air. The spare's been living in my bed until I can get a rear bumper with a swingout.
  12. Jan 1, 2013 at 10:34 AM
    JDMcQ
    sorry, that was a typo. The 255-85-16 is pretty much the same diameter as a 33.
  13. Jan 1, 2013 at 10:45 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Call your local tire shops or junkyards, 4WD shops, etc and ask if they have any used tires in the size you need. 33" might be hard to come-by, but you might get lucky. Tire shops usually have a used inventory to-be-trashed or recycled that you may be able to get one.
  14. Jan 1, 2013 at 10:46 AM
    fireroad
    fireroad Well-Known Member
    McCall, ID
    This ^^^^^
    I don't see a problem with that. Weight is not as important a factor as tire height considering the temporary nature of spare tire usage (ie the doughnut spare on cars). BFG makes a 285/75/R16 that will get you very close (both height and width)to what you have now.
    Not sure I agree, primarily based on most car manufacturers advice against putting the doughnut spare on the front. I would want the most balance up front for safe(er) steering.
  15. Jan 1, 2013 at 10:53 AM
    Nickel
    Nickel Well-Known Member
    Diego
    Rio Rancho New Mexico
    2013 T/X TRD
    does turning tires to black wall out count? How bout added snug top rebel.
    This is one of those arguments that I've had with my Dad.
    You can only run a tire of unequal diameters on wheels that are not driven by the powertrain. Just like previous post, it is ok to place a donut or small tire on the front axle if you are in two wheel or rear wheel drive, likewise you can mount donut on rear axle if you have a front wheel drive.
    If you mount donut on driven wheel, your differential has to make up the difference in diameter, one tire turns 1 time on one side of differential, other tire turns 1.3 times over same distance. For a very short time your differential will slip, thinking you're turning, and allow the tires to turn at separate RPMs, but it will constantly be trying to force both tires to turn at same RPM. Something will give!! Usually it's the differential!
    Last week a Subaru driver got a flat tire before work, 45 mile one way commute, went to discount to get repaired, discount couldn't repair tire, guy didn't want to buy all four new tires to replace the bad one( you must replace all four tires at same time on all wheel drive so as to avoid this issue), so discount mounted his donut on passenger rear wheel and guy took off late to work. About 20 miles into commute his rear differential starts on fire, takes 7 miles for other motorists to get his attention, lucky for him, he pulled over and car burned to the ground! Do you think you should run a full size spare? I think if its under 5 miles, might be ok, anything over that and I would think you could do serious damage.
  16. Jan 1, 2013 at 11:34 AM
    IronCladTRD
    Corbin
    Hotel California
    If I put it on the front and only used RWD, it wouldn't mess up the front diff? I guess it wouldn't be engaged so shouldn't be a problem, right?
  17. Jan 1, 2013 at 11:36 AM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    Nice sig, btw. :cheers:
  18. Jan 1, 2013 at 11:41 AM
    Nickel
    Diego
    2013 T/X TRD
    Exactly, no problems there with gearing or differentials.
  19. Jan 1, 2013 at 12:12 PM
    Nickel
    Diego
    2013 T/X TRD
    Even if you had to use four wheel drive, you would probably be on a surface that would allow the tire to spin before hurting the differential.
  20. Jan 1, 2013 at 12:14 PM
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    Just buy a really cheap used tire for your spare. Doesn't have to be full tread or anything.
