Is a camshaft swap worth it?
Discussion in 'Performance and Tuning' started by saltus25, Jul 2, 2013.
  1. Jul 2, 2013 at 12:41 PM
    saltus25
    saltus25 [OP] Well-Known Member
    Graydon
    Angleton,TX
    Flowmaster American Thunder Exhaust, K&N intake, OME 3" lift, Pro Comp Extreme MT2 tires, Mickey Thompson Classic II Wheels, Spidertrax 1.25" wheel spacers, URD short throw shifter, KC 100 watt lights, custom steel mesh grill, halo headlights, Rigid Industries Dully's, SOS Offroad Concepts front bumper, SOS Offroad Concepts custom rear bumper, All Pro and BAMF skids
    Does anyone have any experience with a cam swap on the 2nd generation tacos? Its just a thought for now but i want to see what everyone has to say.
  2. Jul 2, 2013 at 12:50 PM
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    When mine gets older it's part of the plan (not under warranty). If you can get more duration on the intake and exhaust, than you've increased the amount of air and fuel you're sucking in. If you combine that with larger valves and a nice port and polish you're creating reliable power.
  3. Jul 2, 2013 at 12:52 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    URD put together a naturally aspirated kit for the 2nd Gen Tacoma that looked pretty promising. I believe it included a replacement cam in the kit but it looked pretty promising. Wasn't cheap though... Depending on the cost, forced induction should be considered.
  4. Jul 2, 2013 at 12:55 PM
    YOTA LOVER
    NH
    Yes, there's that.
    These are stupid expensive: http://ttcperformanceproducts.com/1g4ca.html
    I'd call LC Engineering to see what they offer. They have a robust shop and do a lot of machining in-house to save on cost. They are the Toyota power gurus.
  5. Jul 2, 2013 at 3:08 PM
    Super Werty
    Super Werty Sleeper 4x4
    Arizona
    07 TRD Tacoma
    air and fuel
    it's cam gears that come with the UCON EMS which is included in that N/A set up URD sells now
  6. Jul 2, 2013 at 3:12 PM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    LCE makes em for Pickups. I would assume they might for Tacomas as well. Give them a call. The gains you see depends on what you're willing to pay/do. If you just swap a cam vs. porting and tuning things up, who knows. Cam's part of the plan with the Pickup, among other things.
  7. Jul 2, 2013 at 3:57 PM
    YOTA LOVER
    NH
    LCE anything...
    :drool:
  8. Jul 2, 2013 at 4:31 PM
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    Cut from my To Do list in my build thread :D
    To Do Later:
    -LCE Performance Intake Performance Package (Big bore intake manifold and throttle body, and fuel injectors)
    -Mass Airflow conversion kit from late model Tacoma
    -Pro Cylinder Head
    -Pro EFI Camshaft
  9. Jul 2, 2013 at 5:13 PM
    YOTA LOVER
    NH
    It's tough when you get into the motor. Not enough money on my money tree!
  10. Jul 3, 2013 at 5:33 AM
    saltus25
    Graydon
    Angleton,TX
    Well thanks for the input. I wasnt sure if this was something i could do on my own and of course money is always the issue. Maybe someday.
  11. Jul 3, 2013 at 5:35 AM
    Pugga
    Massachusetts
    Ah, thanks. I guess I was not recalling correctly :eek: Still a nice package that URD made up, just $$$$
  12. Jul 3, 2013 at 7:11 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    This. :thumbsup:
    Dezod.com has actually started selling as much or more for the 1GR than LCE, lately. Worked quite a bit with them, as well as some others, to make this possible.
    They are currently building a 1GR with rods, pistons, head gaskets, and head studs. Also have another getting ready to be Darton MID sleeved, Brian Crower stroker kit, and other similarities to mine.
    The cams will cost between $1600-1800 and take around 2 weeks to have made. Once you send YOUR cams in. You can send another set in, but it would require you to carefully check and possibly install new shim buckets.
    Installing intake cams requires the removal of the timing cover. Unless you are Gene Grey.
    Rumors are that you can increase up to 30 hp N/A. Those are rumors though, as I have never seen a dyno chart for N/A or F/I.
  13. Jul 3, 2013 at 9:10 PM
    YOTA LOVER
    NH
    Nobody is as extreme as you bro, but we can all dream! No doubt in my mind that a proper top end build will yield 30+ on our motors. Cost is the killer.
