Is a 500 ft-lb rated impact wrench strong enough to loosen all bolts on a 1st gen?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 5efvz, Nov 4, 2022.
  1. Nov 4, 2022 at 11:43 PM
    5efvz
    5efvz [OP] Well-Known Member
    title
  2. Nov 4, 2022 at 11:52 PM
    Yota X
    Yota X Some say dresser, I say dryer.
    NW New Jersey
    1st gen
    ls turbo, tons, 40's and a partidge in a pear tree
    Depends on where you live.
    Green1GT, Abeyancer, Bivouac and 2 others like this.
  3. Nov 4, 2022 at 11:54 PM
    5efvz
    Good question. PNW. The road DO get salt in snow.
  4. Nov 5, 2022 at 12:12 AM
    Yota X
    NW New Jersey
    1st gen
    Most rusty bolts will break or strip w 500 before giving. But if you know they are gonna do that, you hit em w blaster or free all then heat. Then the milwaukee nut buster is the most consistent w out break/stripping for me. Worth the money for sure.
  5. Nov 5, 2022 at 12:15 AM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    Leaf springs and cam shaft bolt would be the only ones you might not get
  6. Nov 5, 2022 at 12:32 AM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    I should hope so. If you need more than that, PB blaster and a sit overnight will do the trick.
  7. Nov 5, 2022 at 1:29 AM
    Nessal
    Nessal Well-Known Member
    Texas/Bay Area
    2003 V6 4X4 TRD DCAB
    500ftlbs sounds like a lot but I don't really believe so in practice. I think you can take care of 95% of stuff but things like crank bolt, axle nut, leaf bolt, etc might give you trouble.
    Hell, I hit the front diff drain plug with a 1,170ftlb impact gun and it didn't move one bit. I'm going to weld a nut on it and try again.
    Kiloyard likes this.
  8. Nov 5, 2022 at 2:00 AM
    tw0leftskis
    tw0leftskis Well-Known Member
    0xApes
    Meta Verse
    Give me a lever long enough and a fulcrum on which to place it, and I shall move the world. Archimedes ·
    garetcurry and Bivouac like this.
  9. Nov 5, 2022 at 3:26 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Some times 2000 foot pounds in reverse is not enough.
    depends on the hardware and the location where the truck lives.
    where the problems start is tightening hardware so easy to snap off bolts.
    TnShooter likes this.
  10. Nov 5, 2022 at 4:04 AM
    5efvz
    I try to avoid tightening with impact driver. I sometimes use it to spin them on most of the way under the "auto" setting where the wrench stops just before the first impact strike.
  11. Nov 5, 2022 at 9:01 PM
    v5ensx
    v5ensx CARB legal is not CALI legal
    M18 ftw
    Abeyancer likes this.
  12. Nov 5, 2022 at 9:13 PM
    Kiloyard
    Kiloyard Road Warrior
    Phoenix, AZ
    1999 3.4L SR5 4X4 405K miles
    Toytec Boss/Eibach Coils & Deaver J59's
    No way. Only good for lug nuts and that's about it.
  13. Nov 5, 2022 at 10:03 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Keep in mind it's impact torque. If the bolt is long or going through a rubber bushing, the flexibility of the parts will absorb a lot of the impact. A common example is leaf spring U-bolts.
    I have an M18 mid-torque that's advertised for 650 ft-lb and validated on Youtube tests, yet it struggles with lugnuts if I use a 3/8" extension. :notsure:
  14. Nov 5, 2022 at 10:05 PM
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    As said above, no. You will likely want more power.
  15. Nov 5, 2022 at 10:05 PM
    Bishop84
    Bishop84 Well-Known Member
    What a lazy post. I'm gonna ignore this guy finally.
    Kwikvette and Bivouac like this.
  16. Nov 5, 2022 at 10:08 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    Valid point. The socket being used also plays a big part. Big heavy impact rated sockets will work better than a regular socket.
    Nessal likes this.
  17. Nov 5, 2022 at 10:11 PM
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    No my guy. For a 1/2 inch you want around 1000 at least or it’s really not worth it.
  18. Nov 5, 2022 at 10:20 PM
    pontoon
    pontoon Well-Known Member
    2000 Tacoma SR5 TRD V6 3.4 5MT
    In CA I can do most bolts on the truck with 240 forward 430 reverse. I have a high torque with 740 forward/1180 reverse but almost never use it because it’s heavy and the others can usually get the bolts.
    my order of most to least used:
    1. Milwaukee 3/8 m12
    2. Tie between makita 1/4 hex impact driver and makita 1/2 compact impact
    3. Makita high torque least used by a lot
    that said, I’m glad I have all of them. If I had to get rid of one it’d be the compact makita 1/2 impact
  19. Nov 6, 2022 at 12:59 AM
    5efvz
    Do it.
    $yoda$ and Kiloyard like this.
  20. Nov 6, 2022 at 8:51 AM
    garetcurry
    garetcurry Well-Known Member
    I like the guy who quoted Archimedes. In physics, if I can remember the subject for which I am weakest, there's something about moments. Expanding on that, a breaker bar, for instance would yield a longer and more sustained moment than shorter bursts from an impact, regardless of it's rated torque spec.
    So "the right tool for the job" is maybe the easier way to describe the solution here. And an impact ain't the right tool all the time, even if it is rated for one billion torques.
    Anyway, that's all you get from me in this... moment. Hahaha.
