Is a 1.5 ton jack enough?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AutoTaco, Nov 25, 2020.
  1. Nov 25, 2020 at 2:04 PM
    AutoTaco
    AutoTaco [OP] Well-Known Member
    Jay
    Pittsburgh, PA
    2021 Lunar Rock TRD Pro
    Calliraised Sliders, Diamondback HD, 265/75 Wildpeaks
    I'm in the market for a new jack that will work well in the truck, and around the house. Due to the size and weight of 1.5 ton jacks relative to larger 2 ton + jacks, I am considering a 1.5 ton.
    Does anyone know if a 1.5 ton is enough? Or does anyone know a light weight 2 ton option?
    I like the pro eagle 1.5 off road setup with the large wheels and ability to mount on the bedrails. But I am open to suggestions.
  2. Nov 25, 2020 at 2:06 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Too low capacity.
    I have a 2 ton. It struggles.
    I'd like to have a 3 ton with high lift.
  3. Nov 25, 2020 at 2:06 PM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    1.5 for roadside / trail use? Absolutely. Plus you can make a HF 1.5t jack work with proeagle accessories and mount bedside with a little modification.
    1.5 as your main garage jack? Hell nah, 3 ton minimum. HF Low pro long reach for the win.
    vicali and 09 Redneck like this.
  4. Nov 25, 2020 at 2:20 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Jack a single corner to change a tire 1.5-2 will do, but not if you planning to lift the front/rear. Get 3 ton
    Look for lift height as well, especially if you have a lifted truck
    Gunshot-6A likes this.
