Irregular ticking noise from engine - 2023 TRD Sport
Discussion in '3rd Gen. Tacomas (2016-2023)' started by camaro322hp, Sep 19, 2023.
  1. Sep 19, 2023 at 7:00 PM
    camaro322hp
    camaro322hp [OP] Active Member
    Tigard, OR
    2023 TRD Sport M6 // 1999 Z28 M6 // 2007 GSX-R750
    Fjbrad and winmgmg like this.
  2. Sep 20, 2023 at 6:46 AM
    aarcarr
    aarcarr Well-Known Member
    Arizona
    23 Tacoma TE | 18 4Runner SR5
    08 4Runner SR5 sold 03 Tacoma TRD sold
    I’ve noticed this irregular tapping on mine too, 2023 SR5. I’ve seen a few other threads/ videos with the same but nothing explaining the noise
    Fjbrad and Gfenza89 like this.
  3. Sep 20, 2023 at 6:48 AM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    it's the fuel injector cleaning cycle. sounds really strange especially when you are idling next to a wall like in drive-thru. if it goes away when you rev the engine up, it's normal.
  4. Sep 20, 2023 at 7:07 AM
    22Coma6MT
    22Coma6MT Well-Known Member
    2022 TRD Sport AC 6MT
    it does not sound normal to me but i am not a mechanic. i park inside a metal outbuilding and my truck does not make that intermittent ticking noise.
    the sound in this video is similar to another TW member that has his truck at the dealer. they took the motor apart and are waiting on parts. according to a post, it was suspected there was debris of some type in the engine from assembly.
    my $.02.
  5. Sep 20, 2023 at 7:31 AM
    Soulfighterninja
    Soulfighterninja Active Member
    Dave
    NYC
    2020 Tacoma TRD OR 6MT Supercharged
    Foam Cell Pro Stage 2.5 Lift Kit. 17 in Method Wheels 33in Maxxis Razr AT 811s Explore Overland Rock Sliders RCI Skid Plates Airaid Snorkel Magnuson Supercharger
    Mine does that. I have been told its normal, however it still freaks me out.
    For reference my truck is a 2020 with just over 30k miles.
    PopishMetalFab likes this.
  6. Sep 20, 2023 at 7:33 AM
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    it doesn't do it all the time. and they all seem to sound a bit different for whatever reason.
  7. Sep 20, 2023 at 7:33 AM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    Completely normal. The D4-S fuel system uses both direct and port fuel injectors. It will use each set of injectors based on RPM and load. At idle it will trigger the port injectors and increase fuel pressure to pressure wash the intake ports of oil build up common from direct injection fuel delivery. This is random and can last seconds to several minutes.
  8. Sep 20, 2023 at 7:36 AM
    aarcarr
    Arizona
    That video and post about the tear down is how I came onto this. I’ve heard it before but didn’t think much about it until that tear down. I’ve found several other videos and posts with the irregular tapping though
  9. Sep 20, 2023 at 8:03 AM
    turkeyslayer66
    turkeyslayer66 Well-Known Member
    mike
    22 AG Trd Sport
    Mine clatters worse than my Freightliner at work. From what I understand it is pretty normal due to the way it is setup to operate. Still under warranty so I'm not worried.Once I hit 60,001 miles, then I'm going to freak out.....
  10. Sep 20, 2023 at 8:29 AM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    The cleaning cycle cleans the direct injector; not the intake port.
  11. Sep 20, 2023 at 9:37 AM
    camaro322hp
    Tigard, OR
    Interesting, thanks for the feedback everyone. Sounds like it's generally considered normal, so I won't worry about it.
    bulalo likes this.
  12. Apr 22, 2024 at 6:52 PM
    Marc46
    Marc46 Member
    2020 SR5
    23 tacoma sr5 v6 4x4 with 4600 miles. Started doing exactly that after I changed the oil. Takin her to the dealer tomorrow just in case. Edit... took the truck in and toyota says all is well. Also have another 1000 miles on it now so, if it was a problem, pretty sure something would've happened
  13. Apr 23, 2024 at 3:41 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Your truck is transgender. It leaves it’s a diesel at idle.
  14. Aug 13, 2024 at 4:35 AM
    Fjbrad
    Fjbrad New Member
    2018 Tacoma Sport
    Mines been tapping at idle for past 6 years. I guess being car enthusiasts we are complacent to smooth engine sound at idles however it could be a new technology, definitely hard to digest though...
  15. Aug 13, 2024 at 4:43 AM
    Fjbrad
    Fjbrad New Member
    2018 Tacoma Sport
    Mine too.... been over 6 years that way but goes away at higher RPM then idle.
  16. Oct 25, 2024 at 8:38 AM
    Tylerkxj
    Tylerkxj Member
    Orlando, FL
    2021 TRD Pro
    Mine makes the same noise, except never at idle. It only happens at low speeds when accelerating. It's driving me crazy and I'm not convinced its the injectors.
    https://www.youtube.com/watch?v=LY6ngWDoUw8&t=13s
    Not sure what to make of that
    Slayahvic likes this.
  17. Mar 12, 2025 at 10:01 AM
    K9tacoma
    K9tacoma Well-Known Member
    Austin
    Central Ohio
    2023 Tacoma TRD Off Road - Lunar Rock
  18. Mar 13, 2025 at 10:37 AM
    K9tacoma
    Austin
    Central Ohio
    following up here with a HILARIOUS find, splash guard clip broke so it was no longer holding in the top front splash shield on the drivers side, so the fan/wind was flapping the splash guard and my half broken plastic clip into the fender metal making the tapping noise. Problem solved!
    pdxTacoSR5 likes this.
  19. Mar 13, 2025 at 11:40 AM
    pdxTacoSR5
    pdxTacoSR5 Well-Known Member
    PDX area
    2018 Tacoma SR5, V6 Auto, Access Cab, 4x4, Silver Sky Metallic
    thanks for the update. there have been so many "is this ticking normal" threads lately that responders are probably getting burned out. i wasn't sure i was hearing your noise in the video but your solution a welcome unicorn.
    K9tacoma[QUOTED] likes this.
  20. Apr 5, 2025 at 9:57 PM
    JaxsonPotato
    JaxsonPotato Well-Known Member
    2023 TRD Off Road DCSB Lunar Rock
