Ironman leaf springs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rancherrider199, Oct 29, 2020.
  1. Oct 29, 2020 at 1:10 PM
    rancherrider199
    rancherrider199 [OP] Active Member
    nick
    2010 tacoma reg cab 3" totec boss lift kit rear progressive aal
    I have fox springs up front approx 3” of lift when new I added a winch so say 2.5” now. It was maybe 2” higher in the rear with stock springs and aal. I put Ironman 440 constant load springs in the rear it’s now about 5” higher in the rear!!! I’ve only got 150lbs in it right now but I put a 4 wheeler in the bed it only squat an inch... I don’t mind being an inch or 2 higher in the back but this is crazy supposed to be 2” lift. Will it settle that much?
  2. Oct 30, 2020 at 7:00 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    IMHO, you should've went with the progressive (0-440lbs) leafs versus the constant load leafs, especially if you have a single cab. You can likely remove one of the leafs to lessen the lift but call Ironman to confirm.
    rancherrider199[OP] likes this.
  3. Oct 30, 2020 at 8:48 AM
    ohcaltexscar
    ohcaltexscar Out of Huckleberry Licorice…
    Chas
    El Paso, Texas
    2005 DCLB SR5 Prerunner
    IM4x4 2.5" NitroGas - Coopers
    Sounds like a bouncy ride!
    I have the Ironman (0-440lbs) progressive leaf springs, they will settle, but I don't think the constant load ones will settle enough for what you're wanting.
    I second @Wattapunk and say give Ironman a ring to see if you can pull a leaf. Alternatively you may be able to see about getting them exchanged for the progressive leaf springs, depending on how long you've had them. Worth a shot right?
  4. Oct 31, 2020 at 11:14 AM
    rancherrider199
    nick
    The ride actually isn’t to bad! And I got it for hauling sled I didn’t think of the single cab issue then. I think I just have to take the 2nd overload spring out and it’ll be like a regular pack... but I’ll call them on Monday thank you!
    ohcaltexscar likes this.
  5. Nov 4, 2020 at 5:13 AM
    rancherrider199
    nick
    Ironman said take the 3rd leaf from the top out its much better lowerd it 3/4 of an inch plus it settled 3/4 it’s perfect now I sit 1” high in the back with my atv in the bed. Thank you for the replies
    ohcaltexscar, Wattapunk and dk_crew like this.
  6. Nov 4, 2020 at 5:45 AM
    Wattapunk
    Uncle K
    TX
    2005 DCLB 4WD
    Glad it worked out. I've been quite pleased with my Ironman leaf pack. Rides quite smooth and no squeaks.
  7. Nov 4, 2020 at 9:18 PM
    ohcaltexscar
    Chas
    El Paso, Texas
    Right on man, glad that worked for you!
    I agree, I have been happy with them as well.
