Ironman 4x4 Suspension Mega-Thread
Discussion in 'Suspension' started by hyrule_trd, Oct 1, 2021.
  1. Oct 1, 2021 at 7:16 PM
    hyrule_trd
    hyrule_trd [OP] It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    After looking through the Foam Cell Pro 89+ page thread, it was time to make a mega-thread for all of the IM products, reviews, videos and other information and put them in the first page to helps those looking for more information. Don't overlook this kit just because it is not well known in the Tacoma circles. This brand is big with others and so far does have many happy users.
    So, you're looking on information to upgrade your suspension. Fun times! There are lots of great choices and this is one of them. I'll try and put only information here but will link some reviews as well. If you want to know something, you should be able to find it here. I'll be "barrowing" information from the other thread as well.
    Why are you interested in Ironman? Is it the bright green springs? That they have been tested and used for years in Australia? They are competitively priced? That buying a kit can come with everything you need? Lets start there.
    Stage 1 lift, front coil (Springs and Struts assembled or not), rear shocks, full leaf packs, U bolts & leaf eye bushings (not shackle), carrier bearing drop kit, sway bar spacer.
    Stage 2 lift, same as above but with Upper Control Arms.
    If you have them built by IM, the cost includes the price of the top hats. If you get them not assembled, the top hats are not included. You can buy those off of Amazon. **Note, most rental spring compressors will not work on the FCP. There is not enough room between the strut and the spring for the compressor fingers to fit***
    IM offers 2 types of shocks/struts. Traditional Nitrogen filled and then the Foam Cell Pro [FCP]. The FCP are said to be linear valved.
    The FCP is filled with foam in place of the nitrogen. It is supposed to be much better at dissipating heat and does not need an reservoir, like other shocks and struts. I'll post some video links showing the differences below.
    Ok, lets get to the product specs-
    Thank you to @ohcaltexscar for listing these in the other thread:
    Shocks:
    12710GR - Nitro Gas - Front
    Extended: 564mm
    Compressed: 432mm
    12744GR - Nitro Gas - Rear
    Extended: 609mm
    Compressed: 361mm
    45710FE - Foam Cell Pro - Front (Rebuildable)
    Extended: 540mm
    Compressed: 408mm
    45744FE - Foam Cell Pro - Rear
    Extended: 610mm
    Compressed: 379mm
    Front coils:
    TOY065A - Performance Load
    Free Height: 390 mm
    Spring Rate: 720 lb/in
    TOY065B - Performance Load
    Free Height: 382 mm
    Spring Rate: 827 lb/in
    TOY065C - Constant Load
    Free Height: 380 mm
    Spring Rate: 827 mm
    Rear leafs:
    TOY066B - Performance Load
    Spring Rate: 0 - 440 LBS
    TOY066C - Constant Load
    Spring Rate: 440 LBS - GVM
    ISL6010 - Add-A-Leaf
    UCA001FA - UCA with 4 degree built in caster, OEM style ball joint
    45SK7220 - Foam Cell Pro Rebuilt Kit
    IWedge08 - 2 degree leaf spring wedge
    ISHOCKTOOL001 - FCP Adjustment and Rebuild Tool
    Now that you know what is offered, why choose one over the other.
    Foam Cell Pros are adjustable for 0-3'' lift and can be rebuilt
    Nitrogen are non adjustable but you can get them in either 2.5 or 3" lift.
    Truth About Ironman Foam Cell Pro | In-depth Technical Review & Comparison By Tinkerers Adventure
    https://m.youtube.com/watch?v=G12zF12UnB0
    Building the FCP- https://www.youtube.com/watch?v=UrKvX-rHGdo
    Kit Install Video- https://youtu.be/a51Ryojuim0
    Instal guide (Hilux) https://4x4shop.dk/images/17 Toyota Hilux 2015+ Suspension Kit IM.pdf
    Rebuild guide for shocks and struts-
    https://store-pusehjx.mybigcommerce.com/content/Foamcell Pro Service Rebuild IM.pdf
    Spring Height Adjust Sheet
    Different type of shocks- https://www.shocksurplus.com/pages/shock-absorber-design-differences
    Specific IM Video on Nitrogen and Foam Cell- https://www.youtube.com/watch?v=y_B4htm26nc
    I'll go through the other thread and if there is anymore information to add I will. I'm sure I'm missing something that can be added here.
    @Ironman4x4America have anything to add?
    There have been a few reports that the bolt on the drivers leaf spring by the gas tank came from Ironman installed backwards. The bolt head should be on the gas tank side. If the threads and nut are on the tank side, they can rub against the tank. See pics below. Easy fix is to add washers under bolt head if the leaf pack is already on your truck. @Ironman4x4America has reached out to help fix the issue. @LiquidArrogance shows how to flip the bolt around using a floor and bottle jack down a few posts.
  2. Oct 1, 2021 at 7:16 PM
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    Reserved for reviews.
    My Review. Stage 1 FCP with SPC UCA.
    @ohcaltexscar Review. Stage 2 Nitro
    @Boyettexan Review. Stage 2 Nitro
    Thanks @ohcaltexscar for finding these other reviews and threads-
    Haslefre's OG 2012 thread
    https://www.tacomaworld.com/threads/ironman-4x4-2-lift.232763/
    @Haslefre FCP upgrade
    https://www.tacomaworld.com/threads/ironman4x4-foam-cell-pros.367998/#post-10039955
    @wcartee thread
    https://www.tacomaworld.com/threads/ironman-4x4-foam-cell-pros-ucas-coil-overs-leaf-pack.649371/
    @Matchu thread
    https://www.tacomaworld.com/threads/ironman-4x4-lift.624627/
    If anyone sees this and wants to share a review they posted somewhere else, let me know and I’ll add it in here.
  3. Oct 2, 2021 at 4:59 AM
    ohcaltexscar
    ohcaltexscar Out of Huckleberry Licorice…
    Chas
    El Paso, Texas
    2005 DCLB SR5 Prerunner
    IM4x4 2.5" NitroGas - Coopers
    Nice!
    @2013XSPX Do you still deal with the Ironman stuff?
    hyrule_trd[OP] likes this.
  4. Oct 8, 2021 at 6:10 PM
    ohcaltexscar
    Chas
    El Paso, Texas
    Everybody likes pictures right? I’ll leave this one here.
  5. Oct 8, 2021 at 11:38 PM
    the.shelbysaurus
    the.shelbysaurus Well-Known Member
    Colorado Springs, CO
    2019 Cavalry Blue SR5 4x4 ACLB
    Ironman 4x4 Foam Cell Pro, SPC UCAs, 285/70/17 KO2s, 1.25" Spidertrax spacers
    Thanks for putting this together Eric! Looking forward to seeing more reviews here and maybe adding mine in the future.
    @ohcaltexscar would you happen to know how IM differentiates which spring rate you're getting if the 720 and 827 are both identified as "Performance Load"? That's what I selected for my kit, and idk how to tell which one I'll be getting. I think I'd prefer the 720.
    ohcaltexscar and hyrule_trd[OP] like this.
  6. Oct 9, 2021 at 5:48 AM
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    You’re welcome!
    I’ll offer my answer but it’s really only speculation. I think that the 3” will get you the 720# since they are a little bit taller, by about .3”. Though, that does not mean I’m right lol. It might be best to ask their online chat. They really should list the spring you’ll get with each option.
  7. Oct 9, 2021 at 6:33 AM
    ohcaltexscar
    Chas
    El Paso, Texas
    I believe that’s right, @hyrule_trd 's pic-collage from a while back shows all three coil spring options. The TOY065A, TOY065C & TOY065B. That would be my guess as well however, I would still confirm it with their customer service. When I ordered I selected the "performance load 2.5" lift" and got the TOY065A 720# coils.
    Their individual product pages don't mesh with the drop-down menu options on the kit page, none of the coil springs list a 2.5" lift in their specs but the kit page does. I know they've updated the website and the kit selection, they were bullet point selections when I ordered instead of a drop down menu.
  8. Oct 9, 2021 at 9:21 AM
    the.shelbysaurus
    Thanks y'all! I'll be sure to call and verify with them. It would be nice if once you make your selections for the kit, the spec or description section updated to show you part numbers for the springs. Or maybe have part numbers indicated in the drop down menu for selection? I might give them some suggestions when I call :rolleyes:
    hyrule_trd[OP] and ohcaltexscar like this.
  9. Oct 9, 2021 at 9:36 AM
    ohcaltexscar
    Chas
    El Paso, Texas
    That's what I thought too, just adding the part number in the drop down menu would be nice. I like your idea of having it update the included parts list as you make selections.
    Or just clarifying what spring are what with part numbers in the description.
  10. Oct 24, 2021 at 4:37 PM
    ohcaltexscar
    Chas
    El Paso, Texas
    If anyone with a prerunner is looking at the IM kits I should update here as well that I have now swapped coil springs to some with a 586lbs/inch rate and a 14.75” free height.
    I did loose lift height and am sitting about an inch over stock. The coil options with that spring rate are available in many lengths to preserve any lift height you may want though.
    You can check out the post on my swap here
    I just did it yesterday and I still need to get to the alignment shop (which will be open on Monday) so I have not driven it too much yet but what I have does show considerable ride improvement.
  11. Oct 28, 2021 at 5:43 PM
    Lonnie Mac
    Lonnie Mac Member
    TEXAS
    2017 Taco Limited
    WooHoo. Been a LONG time. First post here! Well, I was a member of TW back in the 1900's I think, but that was 3 Taco's ago and I never posted then, and can't remember who I was back then now.
    IM took all my money today. All of it! Just plopped down on a full FCP kit Stage 2 with UCA's. Got the boards for free too! I can't wait! This was the first thread I found and pretty recent too. Should make my 17' limited come to life.
  12. Oct 28, 2021 at 5:45 PM
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    Welcome (back to TW and ) to the club! We’ve tried to get a lot of relevant and current info in here.
  13. Nov 25, 2021 at 11:45 AM
    the.shelbysaurus
    Confirming that if you select the 3" Performance Load when you're building your kit that will get you the 720# springs. Ironman was also happy to swap them for me retroactively when I emailed them before picking up my kit.
  14. Feb 5, 2022 at 9:06 AM
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    Added to main post-
    There have been a few reports that the bolt on the drivers leaf spring by the gas tank came from Ironman installed backwards. The bolt head should be on the gas tank side. If the threads and nut are on the tank side, they can rub against the tank. See pics at the bottom of the first post.
  15. Feb 5, 2022 at 9:07 AM
    LiquidArrogance
    LiquidArrogance Well-Known Member
    Streets of Bakersfield
    2021 SSM Sport 4x4
    *rub :thumbsup:
  16. Feb 5, 2022 at 9:10 AM
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    Thanks and fixed!
  17. Feb 5, 2022 at 9:43 AM
    Lonnie Mac
    Lonnie Mac Member
    TEXAS
    2017 Taco Limited
    Mine's all good. Thanks!
  18. Feb 5, 2022 at 10:17 AM
    LiquidArrogance
    2021 SSM Sport 4x4
    Just gonna throw this up in here also for anyone who does find the tank gouge after kit is installed:
    Easy fix to anyone wanting to remedy. Floor jack on the pumpkin. Factory jack between the frame and leaf pack. (to clear the bolt on the tank so you can slide it out). Don't even need to remove tire. Just flip the bolt around.
    That said: I'm pretty pissed. Part of me feels like IM owes us new gas tanks. How safe is this shit with this gouge on my tank?
  19. Feb 5, 2022 at 2:22 PM
    the.shelbysaurus
    Yeah dude, your gouge is pretty scary lookin'. @hyrule_trd 's is much more minor.
  20. Feb 9, 2022 at 4:25 PM
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    Just a follow up to the incorrectly installed bolt on the drivers side leaf pack saddle, that can gauge the fuel tank. @Ironman4x4America responded in the original Ironman tread, see their post. They’ve reached out to some of the members that have had issues.
    This is not isolated to Ironman Leafs but can happen with any leaf pack, including when someone else disassembles a leaf pack. The bolt can be put in the wrong way. I’ll update post #1 as well.
    Shout out to @Ironman4x4America for reaching out to those impacted. That is great customer support!
    nwAdamR and SpyGoat like this.
