Ipad mount?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ayeele, May 21, 2019.
  1. May 21, 2019 at 1:20 PM
    Ayeele
    Ayeele [OP] Well-Known Member
    Houston, Tx
    18 TRD Pro, 04 DCSB 4x4
    i know alot of you guys run ipads for navigation. How are you guys mounting them? I have a hondo garage vent mount but i dont trust it to hold a 2018 ipad pro 11in with a case. Thanks
  2. May 21, 2019 at 1:25 PM
    max_o
    max_o Well-Known Member
    Colorado
    2018 Silver Sky DCSB OR
    Expedition Essentials TPAM with a RAM mount and a Hondo Garage Big Squeeze.
    mtip, Tigerian and Ayeele[OP] like this.
  3. May 21, 2019 at 1:28 PM
    Ayeele
    Houston, Tx
    Thanks man. Ill look it up
  4. May 21, 2019 at 1:32 PM
    Abelgonz
    Abelgonz Well-Known Member
    Abel
    Arizona
    2017 Barcelona Red Tacoma TRD OR
    The Dashtop Multi-Mount (DMM). They offer a TW discount.
  5. May 21, 2019 at 1:34 PM
    Shellshock
    Iowa
    Tigerian, Ayeele[OP] and Gunshot-6A like this.
  6. May 21, 2019 at 1:35 PM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    That's been a solid addition to me. Holds up well over all the Utah gnar I can throw at it!
  7. May 21, 2019 at 1:36 PM
    timlovestacos
    timlovestacos Well-Known Member
    Tim
    Orange County, CA
    2018 TRD 4x4 OR Silver
    Second vote for DMM. Plus he’s an all around good guy! Check out and he does offer TW discounts.
    mtip and Ayeele[QUOTED][OP] like this.
  8. May 21, 2019 at 1:40 PM
    Ayeele
    Houston, Tx
    Wow that’s interesting for sure. Quite simple as well. Wish theres more installed pics for this
  9. May 21, 2019 at 1:47 PM
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
    I run my iPad on the Hondo Garage mount an have had zero issues. I have one of their mounts on both center vents. Phone on one iPad on the other.
    sgtshtstrm likes this.
  10. May 21, 2019 at 1:48 PM
    Ayeele
    Houston, Tx
    What size ipad? My ipad pro with case weighs maybe 3lbs
  11. May 21, 2019 at 1:54 PM
    RedBeard1
    Red
    11” iPad Pro and my wife’s iPad Air at times.
    Edit: Mistook one iPad for the other I have both the 11” pro and a 10.5”. I am using my 10.5” pro in the truck. It does fit the big squeeze mount.
    Ayeele[QUOTED][OP] likes this.
  12. May 21, 2019 at 2:54 PM
    Hstone556
    Hstone556 Ain’ters gonna ain’t
    Hunter
    Austin
    2019 Ram 2500 Laramie
    Raceline 17" Gauge's 37x12.50 Toyo's RT, Carli King 2.5s
    I run a IPad Pro 9.7” in a zagg rugged case using a ram 6” arm and ram cradle. No issues after 1.5 years.
    Ayeele[OP] likes this.
  13. May 21, 2019 at 2:59 PM
    Toki
    Toki Don’t get killed by Theta.
    Jon
    San Jose, Ca
    2018 Tacoma 4x4
    Little bit of this and a little bit of that but stock af.
    Damn 3 pounds?
  14. May 21, 2019 at 10:39 PM
    Ayeele
    Houston, Tx
    I could be wrong but the ipad pro11 is like .5 lbs and the unicorn beetle case is like 1.5 lbs at least lol
  15. May 21, 2019 at 10:40 PM
    Ayeele
    Houston, Tx
    What holder are you using again? Hondo garage says their big squeeze only holds up to an 8in tablet
  16. May 21, 2019 at 11:09 PM
    RedBeard1
    Red
    I just double checked my iPad I keep in the truck is the 10.5 pro in A survivor case. I do have the big squeeze. Sorry for earlier misinformation on the iPad size. Will correct.
  17. May 22, 2019 at 6:40 AM
    timlovestacos
    Tim
    Orange County, CA
    @FreshMexicanTaco can you jump in and help with his tablet question? Your DMM is ideal for what he’s looking for!
  18. May 22, 2019 at 8:32 AM
    FreshMexicanTaco
    FreshMexicanTaco The Taco Garage
    AJ
    San Diego
    2019 spiced up Taco with guac, no onions.
    Dashtop Multi-Mount!, Pro grille, snug top, Kings BFGs, Front and rear view camera anytime, CMC, prinsu and more to come!
    I was using the old 9.7 iPad from a couple years ago, that was a heavy one. More so than the newer 10.5 or 11 in iPads, the DMM held it perfectly. No sacrificed vents. Now I use a mini because that’s a better size I believe but the DMM WILL absolutely hold the iPad you want to use, I would recommend a shorter arm to minimize load multiplication and I do sell a large tablet mount but any 1” ball compatible mount with work with the DMM, including the perfect squeeze and ram mounts...
    If you don’t like it I’ll take back
  19. May 22, 2019 at 11:39 AM
    Ayeele
    Houston, Tx
    Awesome. I'll check your site out. I use my ipad for flight so i would love to use it for nav
