Introducing the Hitch Vault
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Edmontontaco, Sep 9, 2018.
  1. Sep 9, 2018 at 10:58 AM
    Edmontontaco
    Edmontontaco [OP] Well-Known Member
    Alberta, Canada
    2016 Black TRD Sport
    Hey everyone,
    I posted this in the 3rd Gen forum, but figured this would be very useful to you guys as well!
    I recently started a company called Hitch Vault, I created an aluminum lockbox that can store your keys securely on the outside of your vehicle. This is useful for anytime that you don’t want to worry about losing your keys while hunting, fishing, or doing anything else outside.
    It is made of 6061 aluminum which is then anodized, the top is milled and has a stainless steel insert. All the tolerances are very precise so the box is water and debris resistant.
    For more info you can check out the website https://hitchvault.ca Or comment below!
    Here are a couple pictures:
    https://imgur.com/a/BS2ZSOS
  2. Sep 9, 2018 at 11:22 AM
    Edmontontaco
    Alberta, Canada
    There’s also free shipping to Canada and USA!
    FrostbitTaco likes this.
  3. Sep 9, 2018 at 11:31 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    That’s a good Idea but I’m afraid I would set that thing on my bumper while hooking up my trailer, then forget about it and drive off. Black things like that sitting on you bumper become invisible.
  4. Sep 9, 2018 at 11:50 AM
    Edmontontaco
    Alberta, Canada
    Yeah true, if you’re going to tow something I would just pull it out and put it in the back seat or something. You can leave it in all the time or just put the vault in when you need it.
    spitdog[QUOTED] likes this.
  5. Sep 9, 2018 at 9:49 PM
    FrostyEldin
    FrostyEldin Well-Known Member
    Austin
    Lewiston, ID
    2008 SR5 Impulse Red
    I have a hitch vault but removed it because it would get caked with mud from offroading and would have to use pliers to rip the thing open.
  6. Sep 9, 2018 at 9:52 PM
    FrostyEldin
    Austin
    Lewiston, ID
    My mistake, it wasn't the exact brand but it was a hitch style lockbox thing with 3 dial numbers and a little tab you push to open it up. That one sucks.
  7. Sep 10, 2018 at 3:01 AM
    Edmontontaco
    Alberta, Canada
    Hey! I think you mean the “hitch safe”. If you’re going to do some wheeling in deep mud I would just take it out quick. It only takes a few seconds, then after just put it back in when you need it.
  8. Sep 10, 2018 at 3:05 AM
    Edmontontaco
    Alberta, Canada
    With the hitch vault there are no mechanical parts to get gunked up, once the pin is removed just slide out the vault.
    It would be nice to do some testing and fully submerge the vault in mud and see how it holds up.
  9. Sep 11, 2018 at 8:34 AM
    holaniloie308
    holaniloie308 Member
    Great and Thanks for sharing this..
  10. Sep 11, 2018 at 8:42 AM
    HawkShot99
    HawkShot99 Well-Known Member
    Kingston, NY
    13' Silver DCLB TRD Sport - Sold
    While I know branding is good for a company, I think your product would be better without the HV on the end. Knowing somebody has spent enough $ to have a small safe outside their truck can make people put in the extra effort to break into it.
    Without the HV it just looks like a hitch plug when not using a hitch.
    Definitely nice having a secured spot to hide your keys on the vehicle though, instead of hiding it on the frame or on top of a tire or something.
  11. Sep 11, 2018 at 9:51 AM
    ncguire
    ncguire Active Member
    Albuquerque, NM
    15 Tacoma TRD Sport DCLB
    It would be cool if there was a version that integrated with a hitch mount/ball. Then you wouldn't need to remove it to tow and it would just look like any other hitch.
    FrostbitTaco and SummitBound like this.
  12. Sep 11, 2018 at 10:04 AM
    Muddinfun
    Muddinfun Well-Known Member
    That was my thought. Make a tube that fits inside the stinger tube. There would need to be some provisions for different wall thickness stingers so that is doesn't rattle.
    As mentioned above, having HV on the plug, just screams, "there's something valuable in here".
  13. Sep 11, 2018 at 10:11 AM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX
    2013 Trd Sport DC, 07 DC sr5, 03 Prerunner
    2003: Stock 2007: Avid Offroad sliders, 30% front tint, bed mat, Truxedo low-pro qt tonneu cover, aero turbine 2525 muffler w/ 8'' tip, AR25 Resonator, 16x8 Dick Cepek DC-1 w/ 265/75 Goodyear Wrangler Duratracs, 2010 headlights, ome 884 coils with .5'' top plate spacer, OME sport front shocks, bilsten 5100s rear, 2'' aal, locking gas cap, LR ucas, Viper 2-way remote start, afe drop in filter, Rocky locking bike mounts, gear chest, scangauge, pop n lock tailgate lock 2013: most things transferred over from my 07, 5100s @ .85 + eibachs and Toytec tps for 3'' front lift, wheelers progressive aal w/ overload; compustar 2-way remote start; Antennex shorty antenna, pop n lock tailgate lock with programmable key, seat covers, Toyota's crappy all-weather floor mats (should have got Husky's or Weathertechs), TRD skid plate, led light pods mounted in front bumper valence w/ Eyourlife wireless harness and remote, led bed lights, light pods mounted in bed, Devil Horns emblem from Diaz Fabrications, rear facing pod lights in bed, under seat lights,
    I like the concept, and as a long distance runner this would be perfect for not having to run for hours holding my keys. What makes this better than the "Hitch Safe," which is half the cost?
  14. Sep 11, 2018 at 1:23 PM
    FrostyEldin
    Austin
    Lewiston, ID
    Send me one and I will do any tests you want :D
  15. Sep 11, 2018 at 2:07 PM
    Edmontontaco
    Alberta, Canada
    Yeah sure! Just pay $100CAD shipping and handling!
  16. Sep 11, 2018 at 2:11 PM
    Edmontontaco
    Alberta, Canada
    I don’t have anything against Hitch safe, I just don’t like how it uses little tabs to hold your keys in there, and it appears to be folded steel. With the Hitch Vault it’s extruded 1/4” aluminum, which won’t corrode either. I also designed this so install and removal is very quick and straight forward, there aren’t a bunch of pieces that can be lost or fail.
    Fluffymonkey[QUOTED] likes this.
  17. Oct 22, 2018 at 2:12 PM
    Edmontontaco
    Alberta, Canada
    Hey if any of you second gen guys are interested in a hitch vault, there’s a thread with a lot of info in the 3rd gen section as well!
  18. Oct 22, 2018 at 3:48 PM
    Dye22
    Dye22 Well-Known Member
    Squamish
    '15 TRDOR ACLB
    JBA UCAs OME 2.5 in lift w/ heavy duty dakars. 33" ko2s tc bed stiffeners firestone airbags w/ ride rites cmc/pinchweld rear flushmount leds amazon ditch lights apex sliders 0 degree w/ kickout Coastal Offroad high clearance front bumper w/ full tubing Coastal Offroad high clearance rear bumper w/ tubing and dual swingout 100 AH LiFePO4 Aux battery blue sea fuse panel for aux battery rear diff mod breather Mountain Hatch tailgate insert Smittybilt x2O 10k winch Anytime Camera Mod Front and Rear GPS locator brick BAMF Hangers w/ custom crossbrace 2lo Mod by up2nogood yakima access cab roof bars thule hyper xl cargo box amazon roof basket ARB 1250 awning WaterPort Meso Dual Color Dome Light Durobump Front Bump stops
    could one not hacksaw the hitch pin and slide it all out?
    or just sit there in the dark and try 9999 different combos, (doesnt take as long as you think).
    not trying to be rude. just curious. seems to me this is just asking for something to get stolen. if it was a bit more discreet i think it would go a long way.
  19. Oct 22, 2018 at 4:05 PM
    Edmontontaco
    Alberta, Canada
    Not rude at all, you’re welcome to buy one and try Haha. The pins are hardened steel and I’m pretty sure a file won’t be able to remove material so you’d need a Zip disk or a carbine blade to get through it. Not an easy job.
    As for trying to guess the combo. How about you buy one and I’ll set a code. If you get into into it in less than 30 min then I’ll give you your money back.
  20. Oct 22, 2018 at 4:19 PM
    Dye22
    Squamish
    '15 TRDOR ACLB
    meh, i am not interested in this type of product in the least but i am fairly certain if you dont have some type of mechanism that keeps you from attempting the code quickly i could pop a randomized code in less that 30 mins. im not going to purchase your product to prove this to you however, and as for the 30 min thing, a thief does not necessarily have that time restriction.
    i like the idea but i think your just asking for problems with this design. as soon as someone knows you have a device used to store "valuables" then its only a matter of time.
