"Interval for Fuel Filter Replacepent"
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaJunkie8691, Mar 14, 2022.
  1. Mar 14, 2022 at 6:50 PM
    TacomaJunkie8691
    TacomaJunkie8691 [OP] 1999WineTacoma
    WA State
    1999 Wine Tacoma SR5 Exta-Cab 4wd V6
    Completely Stock except for Ranch 5000 Shocks and Struts.
    Hey Everybody,
    I hope everybody is doing well.
    What is a good interval to replace the fuel filter on a Toyota 3.4? From what I read in the Haynes Manual, it says once every four years or every 60,000 miles which ever comes first.
    Thank you in advance for all of your replies.
    Take care,
    Paul Muzinich
  2. Mar 14, 2022 at 6:53 PM
    Kleenax
    Kleenax Well-Known Member
    Ray
    Michigan
    2001 SR5 4WD V6 Auto - Mica Green
    New frame & stuff CBI bolt-on Sliders
    I believe that you just answered your own question!
    treyus30, 1997tacomav6 and Kwikvette like this.
  3. Mar 15, 2022 at 9:14 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    It depends where the truck lives after the first time when the lines were seized in the filter and had to be Cut I replace mine every spring .
    Much easier then replacing fuel lines with the filter each time.
    Then the ethanol blends are hard on fuel filters
  4. Mar 15, 2022 at 9:59 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    :boink:
    Toyota labels the filters as lifetime items which don't need to be replaced. I think most folks would disagree, and the Haynes manual suggestions are accurate enough. Timmy the toolman has a great video covering the safety concerns of working with fuel lines. But the main thing is, you need line wrenches. Do not attempt to change the filter with regular open end wrenches- you're gonna have a bad time.
  5. Mar 15, 2022 at 6:39 PM
    Bivouac
    Not sure what you mean I have Full sets of Line Wrenches in both Standard and Metric they sort of are needed when you do lots of Hydraulic service work.
    Changing them every spring works for me as filters even from Toyota are cheap I but 10 at a time .
    If I lived in a nice warm Climate no winter chemicals i would never need to change any fuel filters
    treyus30 likes this.
  6. Mar 15, 2022 at 6:46 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    40-80k sounds good to me
    I changed mine when I bought it around 70k and it was disgusting so..
  7. Mar 20, 2022 at 2:07 AM
    Bivouac
    I guess in theory I would not need to change the filter but when I take the flare nuts loose and move them back to clean and Apply Never Seize May as well put a new filter on.
  8. Mar 20, 2022 at 8:31 PM
    Kiloyard
    Kiloyard Road Warrior
    Phoenix, AZ
    1999 3.4L SR5 4X4 405K miles
    Toytec Boss/Eibach Coils & Deaver J59's
    Back when I took my truck into the dealership for service they would change the fuel filter as part of their EFI Service package along with new spark plugs every 30,000 I think. It probably was a bit overkill. 60,000 sounds about right to me.
