intermediate steering shaft not catching steering column
Discussion in '1st Gen. Tacomas (1995-2004)' started by darth_bronchioles, May 26, 2024.
  1. May 27, 2024 at 10:47 AM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Looks on mine....2rz....its little more safe with that slip being on the top shaft....
    If you have 3rz or 5vz 4x4's.....its very dangerous to jack that rag joint very much....because of the close proximity to that slip fit...
    could in fact be a $500 mistake....
    According to that thread......you're suppose to SEPERATE the rag and slide the top half of the rag up the shaft....not shove the whole shaft up...
    and those lock bolts are keyed to a grove in the shaft.....a lot dont understand you have to take the whole bolt out before it will slide up/down
    that slip shaft is probably little tougher than whats portrayed here....not a super common failure....
    I actually never heard of a lower one fail......its always been the top one like mine......the 4x4 ones may be a little tougher design...
  2. May 27, 2024 at 11:52 AM
    darth_bronchioles
    darth_bronchioles [OP] Well-Known Member
    California Central Coast
    1999 Supercharged Tacoma 4x4 Limited
    TRD Supercharger URD 7th injector kit K&N intake 4Runner Mirrors Dog Light Mod
    Well, mines got that second spacer clamp that shouldn't be there as far as I can tell, and because of that the rag joint wouldn't move up the splines, so when I was hammering it the entire shaft collapsed, which I mistakenly thought is what was supposed to happen.
    Yeah, like I said, mines got what looks like an aftermarket spacer which I didn't recognize. I should have taken that off too, but didn't, which is why the entire shaft collapsed instead of just the rag joint moving.
    ChinoXL[QUOTED] likes this.
  3. May 27, 2024 at 11:57 AM
    O'Silver_Taco
    MD
    Yeah that pinch bolt I thought was missing....that one you said wont budge....probably has to come completely out to free that coupler
  4. May 27, 2024 at 11:59 AM
    darth_bronchioles
    I just had a thought: if I remove the spacer, the shaft should extend again, meaning the spines should catch. Since the shaft is held under tension between two components that are hard mounted, there shouldn't be any risk of it collapsing. Thoughts?
  5. May 27, 2024 at 12:09 PM
    O'Silver_Taco
    MD
    Thats a big risk.....what if you hit a bump/pot hole and lose steering at 55...
    this is like the fuel system......want to give any trouble wide berth.....
    thats reason I pony'd up for the $200 fuel hose.....didnt want it mickey moused....
    I would even worry about a salvage one being compromised from water intrusion..
    I myself would go the tack weld...
    Only problem is you got to be damn sure its set right before the tack..
    would be best to have another to lay side by side....
    aint that a bitch....
  6. May 27, 2024 at 12:13 PM
    darth_bronchioles
    I mean, both the rack and u-joint are hard mounted to the frame or body, not the suspension. There shouldn't be a way for a bump like that to collapse it, right?
  7. May 27, 2024 at 12:15 PM
    O'Silver_Taco
    MD
    Shock to wheels is what Id be worried about....not the chassis
    I guess you're the Canary.....
    .....document everything, so they can figure out what went wrong...
  8. May 27, 2024 at 12:20 PM
    darth_bronchioles
    Ah, so you're saying a hard jolt to the wheels could cause it to skip some teeth? Yeah, I see how that could be an issue then. I'll check out my local junk yards next chance I get then.
  9. May 27, 2024 at 12:22 PM
    O'Silver_Taco
    MD
    You know if you dont pay bills....all they can do is lien....
    If you cause damage to others.....they can take the pictures off the wall and the wall(whole house)
    There are some roads near the warehouse districts, you cant drive without tearing whole truck up...
  10. May 27, 2024 at 12:32 PM
    O'Silver_Taco
    MD
    I would still take the junk one and have it tack welded.....what have you got to lose besides $10 and 20min...
    just make sure that junk one hasn't jumped/slipped......not sure how you'd test that without a significant load on it.....
    Damn you toyota....Im way more concern about causing a wreck or walking, than getting impaled...
    THatt likes this.
  11. May 27, 2024 at 12:40 PM
    darth_bronchioles
    Oh it's definitely slipped. It's spinning freely right now, but once it's extended, I should be able to line everything back up and mark some witness lines for the tack.
    Edit: just realized you meant the junkyard one. Yeah, I'll definitely install it and see how it does with wheels on the ground, but so far as I can tell you shouldn't be able to collapse it by hand, which you can easily do on the one I currently have installed. As long as the junk one doesn't collapse or have any play when I twist it, I'm guessing it'll be in relatively good shape.
  12. May 27, 2024 at 12:44 PM
    O'Silver_Taco
    MD
    Yeah good luck....let us know your final outcome...
    hopefully others will come across this and avoid this pit...
    Others I know would die before a salvage or weld option.....
    business must be good for toyota and its subsidiary's
    All the main components for these are reasonable.....its all this little stuff that'll eat your ass...
    Wonder when Elon is gonna figure out where the real money is at...
  13. May 27, 2024 at 12:50 PM
    darth_bronchioles
    Thanks, I will for sure. And thanks again for all of your advice!
  14. May 27, 2024 at 2:24 PM
    O'Silver_Taco
    MD
    You could always take the old one to a machine shop and have them put a roll pin in.
    I think that would suffice
    On that smaller pic I tried to show where they spot welded right at that dimple.
    that would be great place to put the roll pin....
    darth_bronchioles[OP] likes this.
  15. May 27, 2024 at 5:28 PM
    #35
    patacoman2001
    patacoman2001 Member
    '01 4X4 sr5 Xtra cab
    Sounds like you've got it figured out.
    That extra bracket is a steering shaft extension from a body lift kit.
    Looks like probably a 3"
  16. May 29, 2024 at 3:13 PM
    #36
    darth_bronchioles
    Went to the junkyard this morning and picked up a "new" intermediate shaft here's a quick comparison of it with the old and busted for those interested:
    https://youtu.be/-0nz-INkfnA
    And culprit of the whole problem to begin with:
    I'll update again when the install is complete.
  17. May 29, 2024 at 10:05 PM
    #37
    darth_bronchioles
    Update: wheels on ground and took it for a rest drive. It handles phenomenally and feels like a completely different vehicle. Gonna take it in for an alignment in the morning before work. Thanks again @O'Silver_Taco, I owe you a beer!
    Sklar, The gold standard and THatt like this.
  18. May 30, 2024 at 9:24 AM
    #38
    Burro
    Burro Well-Known Member
    SoCal
    98 v6 4x4 xtracab
    Did you get this out of a 3rd gen 4runner? I have replaced almost everything in my steering other than this piece and can feel a small amount of play when I turn my wheel with the truck off and hold the shaft under the u joints, I've just been dreading buying a new one from Toyota since they want $400 for one. This seems like a great option!
  19. May 30, 2024 at 1:26 PM
    #39
    darth_bronchioles
    Yup! Only cost me $40. It also cleaned up pretty much all of the play in my steering. So definitely do this if you've ruled out the steering column and tilt ball.
    Burro[QUOTED] likes this.
  20. May 30, 2024 at 2:00 PM
    #40
    Burro
    SoCal
    98 v6 4x4 xtracab
    Nice, that's quite the savings. I'm very thankful to Toyota for making so many 2wd 3rd gen runners and sharing so many parts, otherwise I'd never find anything at the junkyard for these trucks!
