Interior Lights Help!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacowheelin22, May 11, 2023.
  1. May 11, 2023 at 7:19 PM
    Tacowheelin22
    Tacowheelin22 [OP] New Member
    2022 Tacoma TRD OFF-ROAD
    I had halogen lights in the interior and left on “Door” position and worked. I just changed all the lights to LED lights and now the lights do not turn on when I open the door. The switch is on the “Door” position. I can turn on each and every light inside manually, via switch or pressing on the light itself and they work perfectly. But when I switch it to the “Door” position it doesn’t turn on. Any suggestions/ideas where to look. I checked the fuse and it was perfectly fine.
  2. May 11, 2023 at 7:21 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Welcome to the forum. Did you disconnect the battery when you changed the lights? It’s possible to fry controls on these trucks by simply changing a bulb.
    RustyGreen, hiPSI and Chew like this.
  3. May 11, 2023 at 7:33 PM
    Tacowheelin22
    No I didn’t disconnect the battery before changing.
  4. May 11, 2023 at 7:39 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    if you put the original bulbs back in will they work ?
  5. May 11, 2023 at 7:40 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Try reversing, I think the polarity matters on LEDs.
    Disconnect battery this time too:D
  6. May 11, 2023 at 7:52 PM
    Captqc
    Tigard, OR
    Here’s the wiring diagram. May have fried R44 controller. Call @caribe makaira the resident electrical expert.
    • 17.pdf
      File size:
      36.4 KB
      12
  7. May 11, 2023 at 8:03 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Welcome to the forum :hattip:
    These trucks have super sensitive electrical systems, always disconnect & isolate the negative battery terminal when doing any electric work.
    You aren't the first person to frost something changing a bulb and won't be the last either.
    shakerhood likes this.
  8. May 11, 2023 at 9:38 PM
    Sierrahunter
    Sierrahunter Well-Known Member
    2022 SR5 Double Cab Long Bed 4x4
    Why change the interior lights anyway?
  9. May 11, 2023 at 9:43 PM
    mrkabc
    mrkabc Mall Crawler with a Locker
    Art
    Corona, CA
    2017 MGM DCSB TRD OR
    Morimoto XB LED Head & Fog Lights, Cali Raised Stealth Light bar, OEM Roof Rack, Homelink Compass Mirror, Power Tailgate Lock, LED bed lights, MESO mirrors, gashole, switch panel & Stage 2 tails, PRO grille. Where's the mall?
    Because incandescent light bulbs suck.
    Kolache007 and Captqc like this.
  10. May 11, 2023 at 10:21 PM
    Sierrahunter
    The stock lighting seem fine to me. Nice warm lighting. And no electrical problems, either. Seems like people just want an excuse to buy something new.
  11. May 11, 2023 at 10:29 PM
    mrkabc
    Art
    Corona, CA
    Nahhh... it's the 21st century, why do automakers insist on using garbage incandescent bulbs that frequently burn out, are too hot for the fixture and warp/degrade the plastic, and are dim??
    (Yes I know the reason is "cost", it's a rhetorical question!)
    Kolache007 likes this.
  12. May 11, 2023 at 11:54 PM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    SE Toyota actually sells an LED interior lighting upgrade as a port installed option (at a very inflated price of course), but when I asked my dealer to do it they said they wouldn't. I'm glad I didn't do it because a short time later I got to see a friend's truck when he changed over to LED on the inside and I thought I was going to need sun glasses....those damn things are BRIGHT! LOL. Between the PITA install on some of the bulbs, the possibility of frying something expensive, and the interrogation room brightness of the interior I think I'll just stick with my crappy dim OEM interior lighting :)
    To the OP, I hope nothing expensive is fried!
    2022mgmtrdsport and Chew like this.
  13. May 12, 2023 at 3:32 AM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    The older you get the more light is required.
    The factory lights allowed me to find the seat but not read anything.
    MESO map lights changed frustration to convenience for a reasonable cost.
    Devious6 and Kolache007 like this.
  14. May 12, 2023 at 3:49 AM
    captainh00k
    captainh00k Well-Known Member
    Pittsburgh, PA
    2023 DCSB
    Exactly! The incandescent bulbs were just too dim to actually see anything in the cab at night.
  15. May 12, 2023 at 7:05 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    You could just wire them directly to the battery and leave them on all the time like a guy did with his bright blue LED interior lights in our town. He runs them 24/7 in his Corolla, even when parked overnight! :rofl:
  16. May 12, 2023 at 8:16 AM
    Sierrahunter
    I see. So the bright blue LED lights are for old people to read in the truck.
    RustyGreen[QUOTED] likes this.
  17. May 12, 2023 at 2:54 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    You got it -- and some day you will get it too. ;);)
    The distance between being a young hooligan and an old guy shouting "get off my lawn" is surprisingly short. :pout:
    BTW, the MESO lights aren't blue, more like a daylight.
  18. May 12, 2023 at 3:27 PM
    MannyS
    MannyS Well-Known Member
    Republic of Texas
    Just the right brightness for map lights and license plates. I do not understand why owners install overly bright bulbs inside or for the plates.
    No frying of electrical components with these bulbs. Make sure all switches are off and you are good. Have used these bulbs on three gen3 Tacomas with good results
