Interior glass cleaner - non streaking
Discussion in 'Detailing' started by BarcelonaTom67, Oct 26, 2021.
  1. Oct 26, 2021 at 9:58 AM
    BarcelonaTom67
    BarcelonaTom67 [OP] Lost in Translation....
    Tom
    Laurel County, Kentucky
    2017 Barcelona Red Off-Road DCSB M/T
    All,
    There are a ton of threads / questions about glass cleaning, but they are basically all about the outside surface, how to remove water spots, wiper blade marks, etc..
    On the inside of the truck cab, I have tried several glass cleaners, but they all leave streaks/smears that are only visible when basically driving directly towards the sun - when you need your windshield to be absolutely clear..... A friend of mine who used to own a local auto glass shop, once explained that newer cars/trucks get film buildup on the inside of the windshield due to outgassing of chemicals in the dash. He had a glass cleaner that he bought wholesale and put his shop's label on, I don't know what the ingredients were, but it worked great. He retired in 2020, closed his shop, and moved several states away :(
    Any suggestions would be greatly appreciated.
    MGMDesertTaco likes this.
  2. Oct 26, 2021 at 10:34 AM
    AMarkham40
    AMarkham40 Well-Known Member
    Roanoke, Virginia
    2014 MGM DCSB TRD O/R
    ace96, TacoFergie, japjoe7 and 2 others like this.
  3. Oct 26, 2021 at 10:37 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    I use 100% (uncut) windshield washer fluid.
  4. Oct 26, 2021 at 10:51 AM
    BarcelonaTom67
    Tom
    I've used newsprint for many years, I'll give a glass towel a try.
    AMarkham40 likes this.
  5. Oct 26, 2021 at 11:02 AM
    crashdb
    crashdb I break chainsaws
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Rollin' hydrocarbons!
    These are all decent suggestions. Invisible Glass is a very good glass cleaner that I've had good luck with. The streaks you're getting may be you just pushing something around that any glass cleaner is going to have a hard time getting off. Try this: Clean with glass cleaner and good microfiber. Then use a claybar and glass cleaner on the glass. Finally, take a razor scraper with glass cleaner and go to town. You're putting very little pressure on the blade. Then use the microfiber and cleaner one last time. I've had some very good luck with this method. I just inherited a 20 year old truck that sat under a tree and wasn't driven much. Once done, the glass looked nice.
  6. Oct 26, 2021 at 11:16 AM
    gorram
    gorram Well-Known Member
    2016 Limited
    I think it's really about the technique more than the spray or the type of rag(s). You need two towels minimum the first to do the bulk of the work cleaning with the product. The next towel to remove the excess moisture and wipe the streaks away. If the second towel becomes too saturated you need another towel. You don't buff glass clean with a damp rag, you just end up chasing the muck around.
    This is of course to maintain it, if there is excess filth by all means saturate it, use abrasives, razorblades whatever to get it to a state that any given glass cleaner and two rags will work.
    Honestly rinseless wash beats any dedicated glass cleaner I've found. For one there's nothing special enough about glass cleaner to have it dedicated on hand. Wolfgang Uber, ONR, Ech2o etc...
  7. Oct 26, 2021 at 11:28 AM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Another vote for Invisible Glass. I have to use it on my rear window anyway because of tint
  8. Oct 26, 2021 at 11:40 AM
    Clearwater Bill
    Billy
    Largo Florida
    Outside, Barkeepers Friend.
    Inside, aerosol Invisible Glass
  9. Oct 26, 2021 at 11:47 AM
    MGMDesertTaco
    I use sprayway glass cleaner as it cuts through grime really well. You can get a 4 pack at Costco for around $12 or buy a can individually at Walmart for a few bucks.
    https://www.homedepot.com/p/Sprayway-23-oz-Glass-Cleaner-SW056R/305667042
    I also recommend the rag company microfiber towels. Either one of these:
    https://theragcompany.com/collections/the-rag-company/products/ftw
    https://theragcompany.com/collections/the-rag-company/products/dry-me-a-river
    I use rags to riches microfiber detergent for the towels. (Wash cold, dry low-medium, no fabric softeners or dryer sheets or they'll streak.)
    https://theragcompany.com/collections/microfiber-care/products/ps-detail-products-rags-to-riches
    I don't use paper towels as they always streak no matter which brand I try. I think it has something to do with the pulp or glue in the paper.
    One trick is to wipe the inside glass vertical and the outside horizontal, so you know which side is dirty.
    cookiedough and stbear like this.
  10. Oct 26, 2021 at 1:57 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    I like Invisible glass since it has a high alcohol content and is tint safe. Get glass towels some for the outside and inside and don’t mix the two. You can also make your own with a 50/50 mix of 80% white alcohol and distilled water. And lastly you get a mini squeegee use that but you have to put a towel on the dash if you don’t want it all wet. Oh one more thing clean the outside and inside in different directions so you can tell which side the streaks are on.
    Taco 422 and AMarkham40 like this.
  11. Oct 28, 2021 at 6:46 AM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    the streaks are caused by the amount of cleaner, the rag you use, and the hand method you use to clean glass.
    ^^ thats the case most of the time
  12. Oct 28, 2021 at 8:25 PM
    pyrite4t3
    pyrite4t3 Well-Known Member
    12 TRD OR AC
    Glass can be an as ass to clean. No two ways about it.
    While there are several ways to handle it, this is what I have found works best; use whatever cleaner(glass specific) that you prefer, then have multiple towels on hand whether they are huck/ surgical, microfiber etc. Once you have those implements in hand it is more about technique than product.
    Apply the cleaner, then let it dwell for a few seconds, use the towel of preference to wipe the window on overlapping wipes. Never allow the section of towel to become wet as that is what essentially creates streaks. If you need multiple towels, then use them, just leave the surface dry and free of contaminants.
    If you need to, start with one heavy application of the cleaner then proceed to a light application. Depending on the level of film or dirt on the window I've even started with a towel soaked in water, dry the window then use a glass cleaner, and dried after that.
    The main point is leave no moisture. The cleaner emulsifies the dirt on the window, but will leave it behind if not completely dried off, hence the streaks.
    I will have to try the 'waterless' products mentioned above. That is a great tip, thank you.
  13. Oct 29, 2021 at 11:17 AM
    gotoman1969
    If vinegar didn’t sink like dirty nasty feet I’d use that.
  14. Oct 31, 2021 at 6:44 PM
    Tacosha
    Tacosha Well-Known Member
    Andy
    Calgary, AB, Canada
    2019 Black Tacoma TRD OR ACLB 6MT
    minor, TRD skid plate, front recovery points, Regken mud flaps, rear diff breather, AC drain pipe extended. Upgraded sound with active sub woofer, tonneau cover, CB radio.
    For last 18 years I using Betaclean GC-800, produced by Du Pont and sold by Crystal Glass shops here in Canada. It has more ammonia (by the smell) than windex e.t.c, but result are perfect -
  15. Nov 6, 2021 at 4:56 PM
    Caslon
    Caslon Well-Known Member
    2003 Base Cab. 2 whl drive. 5 speed
    After using a ceramic spray-on and rinse wax, I forgot to clean my wiper blades, not to mention the spray wax coated the windshield and windows. Talk about a filmy haze…Doh!
  16. Dec 17, 2021 at 6:51 AM
    Venom
    Venom Well-Known Member
    Kevin
    Massachusetts
    Has anyone tried paste glass cleaner?
  17. Dec 23, 2021 at 1:14 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I use an assortment of glass cleaners with a hot micro rag on the inside followed by news paper and then polish away. Pretty much the same on the outside, maybe some 0000 steel wool used first.
  18. Feb 24, 2022 at 12:46 PM
    mkultra007
    mkultra007 Well-Known Member
    Mark
    2021 TRD OR DCLB
    I use the Chemical Guys "GlassOnly" foaming spray cleaner. It's pretty clearly ammonia-based (like old-school Windex). It's really friggin' good.
    One big thing... if you use microfiber or other cloth, make sure when you wash/dry them they don't go into the washer or dryer with a fabric softener or Bounce sheet. You'll just gunk the cloth up with waxy crap that'll smear all over your glass. I do them all separate from regular laundry.
    Also, don't use a cleaner with ammonia on plastic like your instrument cluster.
  19. Mar 18, 2022 at 5:10 PM
    Tobimayne
    Tobimayne Well-Known Member
    2019 Tacoma Sport 4x4
  20. Mar 18, 2022 at 5:11 PM
    Tobimayne
    Look no further OP! :thumbsup: Invisible Glass!
