Interior fuse box diagram help
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DustinTG, Feb 17, 2020.
  1. Feb 23, 2020 at 4:51 PM
    redaccount36
    redaccount36 Well-Known Member
    2017 DCSB Silver Limited
    I just ordered the same system. Did you use the P/Outlet No 1 specifically? Also if you use an add a fuse then you obviously can't put the cover back on it. Is that a concern? Is there some sort of extended fuse cover you can buy for it?
    vicali[QUOTED] likes this.
  2. Feb 23, 2020 at 5:10 PM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    MESO Customs had an extended cover, I could never get my hands on one, so I gave up on that. I just keep the stock cover in my glove Box for future reference.
    Edit: After I wrote this I decided to check the website. The covers are available now. 20 bucks.
    https://mesocustoms.com/collections/new-arrivals/products/extended-fuse-cover
  3. Feb 23, 2020 at 6:33 PM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    The install guide says any constant and any switched for the two power sources. It recommends Hzd or door lock as always on.
    The 2nd Gen has no fuse box cover, just hiding behind a dash panel. I also kept the lid as a reference just in case.
  4. Feb 24, 2020 at 8:24 PM
    redaccount36
  5. Feb 24, 2020 at 8:27 PM
    redaccount36
    Is "DOOR F/L" the locks? or "DOOR F/R" or "DOOR R/L"? That's what I'm getting confused on is matching the terminology in the thread to the actual printed terms on the panel. I'm not very experienced with this.
  6. Feb 24, 2020 at 8:45 PM
    Norsemanvike
    Norsemanvike Well-Known Member
    Escondido, CA
    '18 Sport 4x4, DblCb, ShBd, BBP
    If you don't have a sunroof, use the s/roof fuse ( that's what s/roof stands for ).
    shane100700 likes this.
  7. Feb 24, 2020 at 11:18 PM
    caribe makaira
    Caribbean, Puerto Rico
  8. Feb 28, 2020 at 12:40 PM
    DETaco17
    DETaco17 Retired
    2023 MGM Tacoma OR DCSB
    Not too much
    Is that in the cabin fusebox or Engine bay?
  9. Feb 28, 2020 at 2:16 PM
    caribe makaira
    Fourth down on the left...7.5A
    daddy_o likes this.
  10. Feb 28, 2020 at 2:21 PM
    DETaco17
    DETaco17 Retired
    Not too much
    Thanks!!!
  11. Mar 22, 2020 at 7:01 PM
    bhamham
    bhamham Member
    16 TRD OR
    What does AM2 no.2 7.5a fuse do? I'm getting a 500ma draw when the truck is off and pulling this fuse removes the draw. I think I see its connected with the smart key ECU as a power source.
  12. Mar 22, 2020 at 8:55 PM
    caribe makaira
    You think? :smack:
  13. Mar 22, 2020 at 9:18 PM
    bhamham
    bhamham Member
    16 TRD OR
    Yep, thanks for the help.
  14. Nov 9, 2020 at 10:57 AM
    Sac7dseven
    Sac7dseven New Member
    Dan
    2020 Tacoma TRD Offroad
    Not sure if this will be helpful but I just finished hard-wiring a thinkware F70 dashcam in my 2020 tacoma using the 2 empty fuse slots on the interior panel. The lower bottom left was constant 12 (left side) and the empty right upper/middle was switched on 12 v (right side). The fuse taps from the wiring kit fit nice and snug. Just attached a diagram with voltmeter info for each fuse (ignition off). I couldn't get a good reading on the DOOR R/L fuse?
  15. Apr 18, 2021 at 4:50 PM
    #35
    arciuga
    arciuga Member
    Arturas
    Glendale, AZ
    2020 Tacoma trd semi pro
    So what amp fuse did you use at the empty slots?
    In2Ndo likes this.
  16. Apr 19, 2021 at 12:24 PM
    #36
    In2Ndo
    In2Ndo Well-Known Member
    California
    MGM 2021 Tacoma TRD OR
    I would like to know the same thing. going to be having a Thinkware U1000 installed in a few days.
    Guren_Mk.2 likes this.
  17. Apr 20, 2021 at 12:54 PM
    #37
    arciuga
    arciuga Member
    Arturas
    Glendale, AZ
    So i did some research and it said dashcams barely use an amp or under. So it said to go with 2.5
    I didnt have 2.5 so i went with a 5 for now. I thought since its an empty slot i needed only one fuse but it didnt work so i went with 2 5s and its working.
    In2Ndo[QUOTED] likes this.
  18. Sep 10, 2021 at 5:45 PM
    #38
    caribe makaira
    Your vehicle has Jam-Protection windows. Front window fuses are always "hot" (Battery) the rear are ON after IGN.
  19. Sep 18, 2023 at 10:55 AM
    #39
    stftaco
    stftaco Well-Known Member
    22 MGM DCSB Tacoma TRD Sport
    @caribe makaira - I found the post very helpful when working on my 2022.
    I have two questions:
    I think if using an "Add-A-Fuse" the battery side in the fuse diagram posted by Sac7dseven is "R" side of the fuse, correct?
    The other question I have, and others have asked this before, is there a list of what these short-descriptions are for both the fuses in the engine compartment, and also under the dash for GEN3?
    Thx.
  20. Sep 18, 2023 at 11:03 AM
    #40
    caribe makaira
    Post a link to that particular post you are quoting. Easier to answer.
    Toyota info shows all the circuits one particular fuse is related to. Most are "controllers" to various circuits, others are the fused power to one or more circuits.
    I think there is thread on that info...:pccoffee:
