Interior fuse box diagram help
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DustinTG, Feb 17, 2020.
  1. Feb 17, 2020 at 9:10 AM
    DustinTG
    DustinTG [OP] Member
    2019 Toyota Tacoma TRD Sport
    What do these mean? I’m not understanding what some of the acronyms mean. I’m trying to hardwire a dash cam that requires a constant 12v power source even when the truck is off and an accessory source only giving power when the truck is started. Help?
  2. Feb 17, 2020 at 9:35 AM
    danwray
    danwray Traitor
    Dan
    Kentucky
    2021 Ford F150 XL 4x4 2.7 ecoboost
    On my 18, that blank space on the bottom left was powered all the time. I used an add-a-fuse there to tap into it, but I only needed the one fuse since it was empty in the first place.
    Big tall dave and daddy_o like this.
  3. Feb 17, 2020 at 9:42 AM
    shane100700
    shane100700 Bed, Bath & Beyond Crawler
    Montana
    2019 DCSB, OR
    Rocket Boosters
    I believe both door fuses should be constant. If you have a test light or multimeter, you can test it pretty easy. Then use a fuse tap.
  4. Feb 17, 2020 at 9:47 AM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    Empty space always hot, Poutlet1 key on power.
    shane100700 likes this.
  5. Feb 17, 2020 at 9:49 AM
    shane100700
    Montana
    2019 DCSB, OR
    Rocket Boosters
    I was thinking the AM1 was also, but couldn’t remember for sure. Good to know :thumbsup:
    The p/outlet “might” be too. Been a few since I wired my stuff up.
  6. Feb 17, 2020 at 9:50 AM
    LTG4087
    LTG4087 Well-Known Member
    LT
    DFW
    2019 TRD Off Road
    If you don't have a sun roof, that's a good one for switched power... or the washer. For constant power the blank one bottom left or the dome.
    monoman and shane100700 like this.
  7. Feb 17, 2020 at 9:52 AM
    Braves95
    Braves95 Go Clemson Tigers
    David
    Central PA
    17 MGM TRD Off Road DCSB P&T 6MT
    Fab Fours Bumper Block Heater Dual Exhaust Flow Master Smittybilt 12k Winch Synthetic Rope Bed Mat Roof Rack Puddle Lights 17" Rockstar Wheels NittoTerra Grapplers Power TailGate Lock Tonneau Cover w/lights Mobtown sliders MT Remote Start Tinted Windows Front And Rear Camera BRC Competition Diff Breather Bed Step Weather tech Floor Mats TRD Pro Tail lights TRD MT Shift Knob ARB dual compressor URD short shifter Kings 2.5 OEM W/remote resi. Click adjuster.
    15A Hazard lights will be your constant power
    3rd from the bottom right.
    20A Sunroof for ACC. POWER. 5TH from the bottom left.
    Use a add a fuse on both and match the fuse the hot. And 5 amps lower for the acc power.
  8. Feb 17, 2020 at 9:53 AM
    daddy_o
    Bossier City, La
    I have a tap on P outlet 1 and it cycles on/off with ignition.
    shane100700[QUOTED] likes this.
  9. Feb 17, 2020 at 10:13 AM
    caribe makaira
    Caribbean, Puerto Rico
    Sliding Roof 20A is always "hot"...
    GarlicFarts and shane100700 like this.
  10. Feb 17, 2020 at 10:16 AM
    caribe makaira
    2017 Sliding Roof 20A is ACC?
  11. Feb 17, 2020 at 10:41 AM
    Braves95
    David
    Central PA
    Should be as it wont open when the key is off.
  12. Feb 17, 2020 at 10:43 AM
    caribe makaira
    Ah..the mystical "should". It does not open due to getting a signal from another location and fuse...but the fuse itself is always hot...
    musicisevil, stftaco, oconnor and 3 others like this.
  13. Feb 17, 2020 at 10:45 AM
    Braves95
    David
    Central PA
    On both sides? Let me go and see. But hey I've been wrong before.
  14. Feb 17, 2020 at 10:48 AM
    shane100700
    Montana
    2019 DCSB, OR
    Rocket Boosters
    While you’re out there, we need a write up with you testing every fuse (individual pics) for constant vs acc power. Do it for the TW community and science. :rofl:
  15. Feb 17, 2020 at 4:00 PM
    CanesFan95
    CanesFan95 Well-Known Member
    Florida
    Currently Shopping...
    This is something I'm also wondering. Is there a chart or diagram or something that tells when each fuse is hot or not? Depending on the ignition mode, a given fuse may be live or not. And some may be always on. I wish there was a list...
  16. Feb 17, 2020 at 4:05 PM
    CanesFan95
    Florida
    You're sure the dash cam must be running 24/7? One of the weakest links with dash cams is the memory card. They have a failure rate, even if you spend the high dollar $$$ on the good brands. But much more so if you're recording 24/7 because the card is constantly being written to and that wears it out faster.
    And hopefully you're using a hardwire power supply block that knows to automatically shut down if the truck battery gets below a certain voltage.
  17. Feb 17, 2020 at 4:27 PM
    shane100700
    Montana
    2019 DCSB, OR
    Rocket Boosters
    Some (like mine) have impact features so it records/saves when hit. Also most the hard wire kits come with a power cord that stops drawing if the battery reaches a certain voltage.
    stftaco likes this.
  18. Feb 17, 2020 at 6:41 PM
    LTG4087
    LT
    DFW
    2019 TRD Off Road
    Parking mode in most dashcams don't record continuously. Only when movement is detected. Of course if you're parked on a busy street or parking garage with a lot of in and outs you're going to see a lot of recording. FWIW, I've had a 128 card in mine for over a year and it's still going strong without errors. The women's voice hiding in there is supposed to let me know if she encounters any recording errors. So far just "shutting down" or Blackview for your safe driving"
    vicali and shane100700 like this.
  19. Feb 18, 2020 at 2:42 AM
    Braves95
    David
    Central PA
    Here is the cover from a 19 4runner. Should be the same. If you look the Mark's on cover are ACC. And yes the sunroof is Constant power.Screenshot_20200218-053851_Gallery.jpg
  20. Feb 18, 2020 at 8:33 AM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    Blackvue Power Magic Pro install guide recommends HAZ for constant and POutlet for switched.
    Works great, lasts about 10 hours from shutdown with my DR590-2CH.
