Interior Color ID
Discussion in '1st Gen. Tacomas (1995-2004)' started by twfsa, Jun 5, 2010.
  1. Jun 5, 2010 at 7:02 AM
    twfsa
    twfsa [OP] Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Is there somewhere in the vin #, or else where, that identifies what the color of the interior is officially.
  2. Jun 5, 2010 at 7:34 AM
    twfsa
    Tom
    Omaha Ne
    04 TRD 4X4
    Forget the 1st post as near as I can figure there were only 2 colors available Charcoal and Oak mine is I guess Oak looks tan to me.
  3. Aug 29, 2010 at 8:36 PM
    notslow
    notslow Well-Known Member
    Palm Springs, Ca.
    02 TRD black
    I'm trying to figure this out to. I have an 02 TRD Prerunner with light gray interior, I just ordered gray factory floor mats and they are dark gray (charcoal). I thought the only other color was Oak (tan)? My intereior doesn't look tan, looks like a similar light gray that's in my Tahoe. Is there a color code on the truck or can I search by VIN?
  4. Aug 29, 2010 at 8:52 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    If your truck is black you should have Oak interior.
    You can take your VIN to the dealer & ask them what color comes up.
  5. Aug 29, 2010 at 10:30 PM
    notslow
    Palm Springs, Ca.
    02 TRD black
    Is Oak more of a light gray than a tan? My truck is black.
  6. Aug 29, 2010 at 10:34 PM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    Oak is a definite brown. Cant be confused with gray.
    Running Board Man likes this.
  7. Aug 29, 2010 at 11:20 PM
    scocar
    scocar hypotenoper
    The color codes should be on the driver side door frame sticker, with the VIN and the paint code. Not sure of the number, placement, but it is there, I think. Yeah...um.
  8. Sep 9, 2010 at 6:59 AM
    notslow
    Palm Springs, Ca.
    02 TRD black
    Don't see any sticker that has the interior color on it. Can someone post a pick of the Oak interior on a 2002-2004?
  9. Oct 11, 2010 at 10:21 PM
    BajaLaJolla
    BajaLaJolla Member
    San Diego
    04 Prerunner
    This is a reply to an older thread, but attached is a picture of the door sticker with paint and trim (I think) codes noted:
  10. Oct 11, 2010 at 10:35 PM
    notslow
    Palm Springs, Ca.
    02 TRD black
    Awesome, thanks! I'm going to go look at mine right now :)
  11. Oct 11, 2010 at 10:41 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Impulse Red Pearl is an exterior paint color
    Edit: I see now you are talking about the 2nd code FK45
  12. Oct 11, 2010 at 10:53 PM
    notslow
    Palm Springs, Ca.
    02 TRD black
    My interior color code is FB10 is this considered gray?
  13. Oct 11, 2010 at 11:42 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    I don't think that trim code applies specifically for interior color. If it was, then there would only be two trim codes since interior color is either oak or charcol. There's more trim codes than just two
    My interior is charcol, my trim code is FK10 but I have a doublecab.
    Well I'll be damned, sounds like your interior is charcol gray. I could of sworn I've only seen oak interior for black but maybe that's only on the 5 luggers & the 4x4/prerunners have charcol?
    Look at this link, black extra cab prerunner, trim code FB10, the interior on this truck is charcol: http://www.alltoyotatrucksuvparts.com/new-arrivals/100049.html
    Look at these two, they are oak interior:
    http://www.alltoyotatrucksuvparts.com/new-arrivals/100029.html
    http://www.alltoyotatrucksuvparts.com/new-arrivals/100006.html
    Based on what I see from that site, if trim code is XX1X it's charcol & XX4X is oak.
    I have some floor mats that I bought new 5 years ago. Only used them for a few months & took them out. If I can find them I'll pull them out & see how dark they are compared to my interior. They should still look pretty new since I put them in the boxes for my husky liners.
  14. Oct 12, 2010 at 1:30 AM
    notslow
    Palm Springs, Ca.
    02 TRD black
    Well my interior can't be considered charcoal. It's way too light. My friend has a 4runner with charcoal and it's alot darker. I got floor mats for my truck online. I ordered gray and the ones they sent are the color of his 4runner and don't match my truck at all. They are a dark charcoal gray and the correct part, but not the correct color. Did they put the dark gray in some of these trucks and no one knows about it? My truck is more of a light or medium gray. The link to the 2004 TRD prerunner is just like my truck, same color and interior.
  15. Oct 12, 2010 at 2:42 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Charcoal is what they call the light gray on these models. If you have the wrong color mats why don't you return them? Post a pic.
  16. Oct 12, 2010 at 5:29 AM
    clarkie152
    clarkie152 Well-Known Member
    MA
    2016 4Runner Trail
    LED light swap, TRD wheels, KO2s, C4Fab lo-pro
    @notslow
    heres a pic of my charcoal interior. use it for reference?
  17. Oct 12, 2010 at 3:15 PM
    notslow
    Palm Springs, Ca.
    02 TRD black
    Yeah, that's what I have. It's strange because the 4runners have an actual charcoal interior.
  18. Oct 28, 2010 at 1:22 PM
    notslow
    Palm Springs, Ca.
    02 TRD black
    Thought I'd give an update. The dealer looked up another lighter gray interior color. They are going to compare it and let me know. Here is a side by side comparison of the charcoal mat they sent me next to my stock gray mat.
  19. Nov 12, 2010 at 11:41 AM
    OmahaStylee
    OmahaStylee Beating Anorexia since 1976
    Omaha, NE
    01 DC TRD
    FRONT: Toytec CO's & diff drop BACK: AllPro standard leaf kit with Bilsteins and axle shims
    notslow...
    that darker one looks like it would match my interior ('96)
    I'm guessing they lightened up the interior colors at some point - don't know when exactly but I'd be willing to bet it was [95-00] *change* [01-04]
  20. Nov 12, 2010 at 2:45 PM
    notslow
    Palm Springs, Ca.
    02 TRD black
    That would explain it. Because according to everything I've read there is only one color of gray in the 01-04 tacomas.
    I wish the darker color was available. I like it much better.
    They're sending me the right color mats.
