Interference or Non-interference
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Phantom_X-SP, Jun 2, 2009.
  1. Jun 2, 2009 at 10:15 AM
    Phantom_X-SP
    Phantom_X-SP [OP] Rude Boy |><|
    High Point, NC
    08 DC Black Sand Pearl X-SP
    I did a quick search and couldn't come up with an answer. Is the 1GR-FE (2nd gen 4.0) an interference or non-interference engine?
    Also while searching around I found this info on Toyota's website:
    http://www.toyota.co.jp/en/tech/environment/powertrain/engine/index.html
    I wonder if this means that a future Tacoma may come with a 2GR-FSE or 2GR-FE engine due to increased fuel efficiency...
    foampile likes this.
  2. Jun 2, 2009 at 10:18 AM
    98tacoma27
    Ben
    Not Beech Creek
    I believe the general consensus is that it is non-interference.
  3. Jun 2, 2009 at 10:21 AM
    98tacoma27
    Ben
    Not Beech Creek
  4. Jun 2, 2009 at 11:12 AM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    I believe the Toyota Venza is now using this engine.
  5. Jun 2, 2009 at 12:03 PM
    j1999t
    j1999t Well-Known Member
    Justin
    Northern Colorado
    traded it in
    an engine is called an interference engine when there is more than 2 valves per cylinder, a non interference engine is only 2 valves per cylinder, the interference is caused by the possibility of 2 or more valves possibly striking one another, which could cause them to bend or break, which in turn could ruin your cylinder head and require an engine rebuild...
    just my 2 cents
  6. Jun 2, 2009 at 12:16 PM
    MassTaco
    MassTaco Well-Known Member
    Massachusetts
    V6 4x4 SR5 DC AT5
    There are such thing interference 2 valve engines and non-interference 4-valve engines. It has to do with the possibility of the piston crown and the valves trying to exist in the same place at the same time in the event that timing is incorrect. I can't think of a situation where intake and exhaust valves could collide because if the timing belt/chain let go, neither would be in motion.
  7. Jun 2, 2009 at 12:47 PM
    Phantom_X-SP
    High Point, NC
    Correct
    2GR-FE:
    2GR-FSE:
  8. Jun 2, 2009 at 12:49 PM
    Phantom_X-SP
    High Point, NC
    X2
  9. Jun 2, 2009 at 12:51 PM
    98tacoma27
    Ben
    Not Beech Creek
    From what I have read is that all of the VVT-I engines are interfernce engines, including the 4.7L in my tundra which happens to be belt driven.
  10. Jun 2, 2009 at 3:42 PM
    Phantom_X-SP
    High Point, NC
    Good find :thumbsup:
    I wasn't concerned really...just curious. I had a conversation recently about a prevoius engine I did work on and wondered about the 1GR-FE.
    What year is your Tundra?
  11. Jun 2, 2009 at 4:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Incorrect. Interferance engines are ones in which the piston takes up the space the valves do when they are open, and the piston is at TDC. When the timming drive system (Belt or chain) breaks, this can lead to damaged pistons and/or bent valves, as well as other damage.
    OP, Toyota does not manufacture an interferance engine. The only ones who do (IIRC) is Honda, Mazda, and a couple of older Nissan engines.
  12. Jun 2, 2009 at 4:24 PM
    JoeSchmuck
    JoeSchmuck Well-Known Member
    Joe
    Virginia
    09 PreRunner SR5 2x4 O.R., Timberline Green
    Pop & Lock, Access LE Rollup Cover, Alpine PDX-5 Amp, Image Dynamics CS-6/CX-6 & 10" Sub
    Um, What? I hope that isn't true, if so I'd love to see the reference.
    Interfere = Valve (intake or exhaust) in fully open position can hit the top of the piston in the fully up positon.
    Non-interefere = Valves fully open cannot hit the top of the piston in the fully up position.
    This is important when a cam shaft belt or chain breaks because the piston will come in contact with any valves in thier opened positions and cause engine damage on an interfering engine. This is why a non-interfereing engine is nice to have. If a timing belt/chain breaks on the non-interfering engine you can make a safe assumption you will not need to replace pistons and valves which get costly.
    Hope this helps.
    Joe
    Fenwick1993 likes this.
  13. Jun 2, 2009 at 5:22 PM
    Phantom_X-SP
    High Point, NC
    So which one is it guys??? Any links to reference??? :notsure:
    cryptolime, SR-71A and doublethebass like this.
  14. Jun 2, 2009 at 5:25 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The only "Link" I have is that I have torn these engines apart, and one of my buddies works only on Toyota engines. otherwise, I have no proof...:(
    Benny123 likes this.
  15. Jun 2, 2009 at 5:30 PM
    Phantom_X-SP
    High Point, NC
    That sounds like a pretty good "link" lol I appreciate the insight Chris :thumbsup:
  16. Jun 2, 2009 at 5:53 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  17. Jun 3, 2009 at 5:37 AM
    98tacoma27
    Ben
    Not Beech Creek
    05 tundy. Some pics in my gallery
  18. Jun 3, 2009 at 7:03 AM
    98tacoma27
    Ben
    Not Beech Creek
    This supports Chris' claim:
    http://www.aa1car.com/library/2003/us70343.htm
    A list of Toyota Interference engines:
    http://www.automotix.net/autorepair/toyota-pickup-engine_repair_guide-1867.html
    SR-71A likes this.
  19. Jun 3, 2009 at 7:09 AM
    98tacoma27
    Ben
    Not Beech Creek
  20. Jun 3, 2009 at 7:38 AM
    Phantom_X-SP
    High Point, NC
