Instrument cluster compatibility
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacoHank1998, May 28, 2018.
  1. May 28, 2018 at 1:43 PM
    TacoHank1998
    TacoHank1998 [OP] Well-Known Member
    Will
    Panama City, FL
    1998 Green Tacoma Base
    I have the base model... hence the 110mph and no tach. I wanted to obtain a cluster with a tach but I noticed all the 98-00 clusters with tachs have the digital odometer. My question is what is compatible with the base model? Will a 2.7 mt cluster work? (See example pic)
    Black97v6MT and GQ7227 like this.
  2. May 28, 2018 at 1:46 PM
    TacoHank1998
    Will
    Panama City, FL
    Oh... and given my previous experience with Ford clusters I know some lights might not match up (My air bag light subbed as my check engine when I swapped from a 95 ranger to an 03 sport Trac cluster) that don't bother me... just care about the gauges working.
  3. May 28, 2018 at 11:41 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    It depends if you have a cable driven cluster or not. I know Toyota kept the mechanical odometer after 1998, but switched to a digital VSS and just converted it back to mechanical to drive the odometer. That’s at least what I can figure out by seeing the base cluster.
    The RPM’s will read differently on different engine displacements. Your Odoneter will also read whatever mileage came from the donor vehicle.
  4. May 29, 2018 at 6:47 AM
    TacoHank1998
    Will
    Panama City, FL
    I just want to know what will work... May not be 100%accurate seeing the 2.4 didn't appear to come with a tach but a .3 liter displacement shouldn' vary too wildly.
    This is why I was looking at getting the pictured tach seeing it came from a 2.7
  5. May 29, 2018 at 9:23 AM
    COMAtized99
    COMAtized99 Well-Known Member
    North Carolina
    99 DCLB v8
    The Bed is stock...ish
    I swapped a tach cluster into my 96 Tacoma. Get one from a truck with the same style engine (I4 or v6) and cable or electronic VSS. Should be plug and play.
    Tach signal is not based on displacement, it's based of number of cyl. Using one from a 4cyl on a v6 will be off 20-30%.
    Toyota 4cyl and v8 make the same tach signal btw
    98-00 and 01-04 clusters are interchangeable also. Only thing being v6 vs I4
    ControlCar likes this.
  6. May 29, 2018 at 3:15 PM
    TacoHank1998
    Will
    Panama City, FL
    Great info... now does atx/mtx matter? I mean aside from the fact atx clusters have the lights obviously but will it effect functionality in an mtx?
  7. May 29, 2018 at 3:53 PM
    COMAtized99
    North Carolina
    99 DCLB v8
    That, I'm not sure of. Personally, I've not seen where it would. I've bought and used parts from different yrucks, never caring about transmission type. Personally, I've never seen a 1st gen tacomTthat I can think of that has gear indicator lights. One possible exception I can think of is the column shift transmissions. But they where kinda rare, and only in 5 lugs models? I'm completely guessing on that part. If your truck doesn't have gear indicator lights in the cluster, I wouldn't worry about it.
    As far as the manual transmission, it's not going to care one bit about the cluster.
  8. May 29, 2018 at 4:16 PM
    COMAtized99
    North Carolina
    99 DCLB v8
    Also, there are ways to move the mileage over. The digital ODO are a little more involved and require you to desolder a chip (e-prom I think it's called) from the old cluster and resoldering it into the donor cluster.
    The mechanical clusters are easier, but take some mechanical ability on the part of the person doing the work.
    I swapped the mileage from my old 96 non tach cluster to the "new" tach cluster. If I'm not mistaken, I moved the mileage part over and reused the trip roller numbers and the actual housing fir the speedo.
    Hopefully that makes sense. There are videos on YouTube on how to move the chip. I personally have not done it .
  9. May 29, 2018 at 4:37 PM
    TacoHank1998
    Will
    Panama City, FL
    I'm not worried about the mileage difference... Hank's gonna die in my care. I just plan to write the mileage of the old cluster and start with the mileage of the new cluster and go from there. Same thing I did when I swapped clusters in the Ranger.
    GQ7227 and COMAtized99 like this.
  10. Sep 13, 2023 at 4:13 PM
    csrf
    csrf Active Member
    sorry for the big thread bump, but I've got kind of a side question...
    When you say that the 98-00 clusters are compatible with the 01-04's, does that mean that physically they are identical? Will the cover glass from an 01-04 fit on a 98-00 cluster?
  11. Sep 13, 2023 at 6:25 PM
    TacoHank1998
    Will
    Panama City, FL
    The only difference is the face. 98-00 are black faced and 01-04 have white face orange lighting. My 98 5 lugger currently sports a cluster out of an 02 2.7l. Peep the link in my signature for more info.
    csrf likes this.
  12. Sep 16, 2023 at 12:44 AM
    csrf
    csrf Active Member
    Thanks man...
    I'm trying to figure out if I can use just the glass cover from an 01-04 (part# should be 83852-04140 for these models). It's just the clear plastic 'lens' with the black backing that has holes for the gauges & lights, so it doesn't actually include the gauges. So, I'd be using the glass cover for an 01-04 but with the instrument cluster 'body' from a 98. I just need to know if the gauge holes & the tabs that clip into the instrument cluster around the edges all line up
  13. Sep 16, 2023 at 3:20 PM
    TacoHank1998
    Will
    Panama City, FL
    It'll definitely work. The glass same size 95.5-04
    csrf likes this.
  14. Apr 19, 2024 at 8:07 PM
    SpeedHarrop
    SpeedHarrop Member
    Wayne (Speed)
    1998 Tacoma 5 speed 4 cyl. 2WD
    10' stake bed (with frame stretch) which includes true 1998 Toyota full floating axle dually including seven dually wheels and front hub adapters (5 lug to dually 6 lug). Power windows, keyless access, rear camera and windshield mounted mirror/monitor. Overhead aftermarket console holding Bluetooth microphone, police style map light plus two dome lights and glasses case and garage remote. Automatic antenna with defeat switch. Dash mounted switches to turn on radio without key in ignition, switch to turn on LED strip lighting in foot wells, glove box and behind seat. Complete coverage of sound deadening of cab. Component speaker system with 'mechless' Kenwood double din Bluetooth radio . Unusual tweeter positioning on either side of steering wheel.
    Isn't someone on this forum able to make a 1998 v6 Speedo/Tach work on a 1998 base Non-tach truck? I can provide the VINs of the donor and the target with the engine trans ratios. I remember someone saying they do it but I lost the thread and now I'm ready.
  15. Dec 24, 2024 at 6:55 AM
    ruffles917
    ruffles917 New Member
    1997 toyota tacoma
    Does someone know if a 3rd gen 4Runner instrument cluster lens fit on a 1st gen Tacoma instrument cluster? I’d greatly appreciate it thanks
