Instant Sound Improvement for JBL Owners
Discussion in '4th Gen. Tacomas (2024+)' started by KB Voodoo, Jun 12, 2024.
  1. Jun 12, 2024 at 8:50 AM
    KB Voodoo
    KB Voodoo [OP] Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    The silly little JBL Bluetooth speaker in the dash is disproportionately balanced. It seems like the sound level is 10% left, 80% center, 10% right.
    This makes for a terrible sound stage and practically zero stereo separation.
    What's the fix?
    Press the release button on the speaker.
    The sound stage will instantly broaden, and imaging and stereo separation will reappear.
    Until Toyota updates the software and let's us adjust the volume of the center speaker, this is the only solution that I can think of.
    As a bonus, you now can watch the speaker wobble all over the place in unison with the hood, which is apparently made from graham crackers.
  2. Jun 12, 2024 at 8:57 AM
    Gmak621
    Gmak621 Łøādîñg…
    Nørth Çøast
    2024 TRD ØR
    Agreed. I removed mine completely, much better.
    HondaGM and KB Voodoo[OP] like this.
  3. Jun 12, 2024 at 8:57 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Center channel is completely unnecessary in a two channel stereo system.
    Give it a try, yes it sounds completely different, and it is a lot better.
    HondaGM likes this.
  4. Jun 12, 2024 at 9:14 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    I was loosely comparing it to a 2-channel home stereo system, since the truck system is definitely not home theater with surround or anything like that. The rear channels are for the back seat passengers. When you are sitting up front you are basically listening to a 2 channel stereo system (or at least you should be).
    The overwhelming majority of high end 2 channel home systems would never have a center channel.
    As far as I know, there is no way to turn the JBL BT speaker off if it is in the docking station.
    HondaGM likes this.
  5. Jun 12, 2024 at 9:26 AM
    miqie
    miqie Well-Known Member
    The center speaker has volume controls on it for when you're using it off the truck. The best solution, and probably not fixable with a software update, would be for those volume controls to be operable while in the dash.
    HondaGM likes this.
  6. Jun 12, 2024 at 9:33 AM
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    Maybe they’ll dump the portable speaker in 2025 or 2026.
    TacoBuffet and HondaGM like this.
  7. Jun 12, 2024 at 9:38 AM
    Newwt
    Newwt Well-Known Member
    Tampa, FL
    21 SUPER WHITE TRD OR 4X4 , 24 BCM TRD OR
    also, if you use Spotify you can go into your settings in the app and change the playback to "loud". I went from having my volume at 45 to 15
    grizzlyoutlaw and HondaGM like this.
  8. Jun 12, 2024 at 10:19 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Having an empty hole in the dash would send my OCD into overdrive. lol
    The wobble is a reasonable compromise.
    Ultimately I hope they just give us a way to adjust the volume of the center speaker.
    Cows Have Claws and HondaGM like this.
  9. Jun 12, 2024 at 11:13 AM
    545 Well-Known Member
    2015 Access Cab
    Could probably but something over the contacts and reseat it in the dock
  10. Jun 12, 2024 at 11:22 AM
    miqie
    I tried that with the 'sound leveler' control but it had little effect. One issue is that the rear door speakers are down low, firing into the carpet and tight seating back there, so they can't compete with the overpowering dash speaker. One solution..........convert the rear headrests into speaker enclosures.
    Steves104x4 and HondaGM like this.
  11. Jun 12, 2024 at 4:54 PM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    That would defeat the purpose. The objective of this mission is to improve stereo separation and imaging, and to broaden the sound stage.
    Putting the sound behind your head is the exact opposite of that.
    Fish taco4X and HondaGM like this.
  12. Jun 12, 2024 at 5:59 PM
    Fieldsanitation
    Fieldsanitation HPPTMS
    Joey
    Western Loudoun VA
    Bronze Oxide ' 24 Off Road
    I hadn't thought about taking that speaker out. definitely need to try that.
    HondaGM likes this.
  13. Jun 12, 2024 at 6:25 PM
    Jacob06
    Jacob06 Well-Known Member
    Atlanta
    2024 TRDOR 6MT
    How do you listen to the radio without the engine running?
    I can’t figure this out and thought that maybe they just don’t want you to have an accessory feature like most other cars and they put this speaker in there so that you can listen to the radio in the truck without the ignition on.
    Whenever you do the brake peddle twice nonsense before the start button it seems like the ignition is also on and the dash doesn’t look very happy about it.
    Is there an accessory position that will give power to the radio only?
    I thought the center channel was too loud too and adjusted the fade like 2 clicks toward the back
    HondaGM likes this.
  14. Jun 12, 2024 at 10:15 PM
    Gmak621
    Gmak621 Łøādîñg…
    Nørth Çøast
    2024 TRD ØR
    Just hit the start/stop button once without your foot touching the brake pedal. And voilà, you get radio function
  15. Jun 13, 2024 at 9:52 AM
    grizzlyoutlaw
    grizzlyoutlaw Well-Known Member
    Fish taco4X likes this.
  16. Jun 13, 2024 at 1:11 PM
    Bluznvice
    Bluznvice Well-Known Member
    Adjusting the balance to the rear and left worked great for me.
    wastingTime34 likes this.
  17. Jul 7, 2024 at 9:52 AM
    One Shady Taco
    One Shady Taco Member
    Clint
    I put a piece of electrical tape over the portable speaker charging contacts so I can keep it docked without the center channel playing. Sounds much better, lol.
    gargamel05, mello03 and Gmak621 like this.
  18. Jul 8, 2024 at 11:23 AM
    My4thTacoma
    My4thTacoma Pain Don't Hurt
    St Petersburg, FL
    2024 TRD Sport 4x4 (Solar Octane)
    I just removed the Bluetooth speaker and put it in the center console. I agree it sounds much better without it.. but I still miss the old system I just installed in my 2022 Tacoma just prior to it being totaled in an accident. I removed the 10” JBL subwoofer and the Kicker 5 channel amp hoping they might work in the 2024. But haven’t gotten around to researching any of that yet
  19. Jul 8, 2024 at 11:24 AM
    My4thTacoma
    St Petersburg, FL
  20. Jul 8, 2024 at 1:06 PM
    brandused
    brandused Active Member
    I installed the encore and think it was worth the money. The bass was pushed up more and the sound was a lot better. Very simple to install. Only issue I had was the added bass was creating rattles in the door. So had to add sound deadening to the doors to quiet that down. Would recommend it to everyone that has JBL upgraded system. Havent changed the factory JBL speaker but kind of curios what it would sound like with after market speakers.
