Installing sway bar end links
Discussion in 'Suspension' started by Fluffymonkey, Mar 20, 2022.
  1. Mar 20, 2022 at 12:43 PM
    Fluffymonkey
    Fluffymonkey [OP] Token
    College Station, TX
    2013 Trd Sport DC, 07 DC sr5, 03 Prerunner
    2003: Stock 2007: Avid Offroad sliders, 30% front tint, bed mat, Truxedo low-pro qt tonneu cover, aero turbine 2525 muffler w/ 8'' tip, AR25 Resonator, 16x8 Dick Cepek DC-1 w/ 265/75 Goodyear Wrangler Duratracs, 2010 headlights, ome 884 coils with .5'' top plate spacer, OME sport front shocks, bilsten 5100s rear, 2'' aal, locking gas cap, LR ucas, Viper 2-way remote start, afe drop in filter, Rocky locking bike mounts, gear chest, scangauge, pop n lock tailgate lock 2013: most things transferred over from my 07, 5100s @ .85 + eibachs and Toytec tps for 3'' front lift, wheelers progressive aal w/ overload; compustar 2-way remote start; Antennex shorty antenna, pop n lock tailgate lock with programmable key, seat covers, Toyota's crappy all-weather floor mats (should have got Husky's or Weathertechs), TRD skid plate, led light pods mounted in front bumper valence w/ Eyourlife wireless harness and remote, led bed lights, light pods mounted in bed, Devil Horns emblem from Diaz Fabrications, rear facing pod lights in bed, under seat lights,
    Hi, all. Have had a clunk, creak, for a bit now, and now a full blown squeak (as of a couple of weeks ago). Crawled underneath and saw that my end links were pretty chewed up. As in fully torn open.20220320_143511.jpg
    I bought some new links. I read in another thread that I can accomplish this swap without jacking the truck off the ground/removing tires, etc. Is this the case? Some people seemed to disagree. I'm a small guy and there seems to be plenty of room to work. Just don't want to run into any potential issues aligning the new ones once the old ones are off. Thanks.
  2. Mar 20, 2022 at 1:43 PM
    2015 TRD Sport
    2015 TRD Sport Well-Known Member
    South Carolina
    2021 TRD Pro
    It's a Lot easier if you do jack it up and remove the wheels, gives you way more room to get to the end links, just be sure to use jack stands.
    Fluffymonkey[OP] likes this.
  3. Mar 20, 2022 at 5:59 PM
    Paxman13
    Paxman13 Member
    06’ Tacoma pre runner
    You will at least need a jack just incase the link doesn’t line up you can jack it up a little bit to get them to go in the correct position.
  4. Mar 21, 2022 at 4:58 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    If you jack it up, jack up both sides equally so that there is no load on the sway bar.
    drizzoh and Fluffymonkey[OP] like this.
  5. Mar 21, 2022 at 7:26 PM
    Fluffymonkey
    College Station, TX
    Thanks, all! Going to try to knock it out soon (we're under softball sized hail and a 7 out of 10 tornado watch right now). Hopefully I even have a truck tomorrow
  6. Mar 24, 2022 at 12:32 PM
    Paxman13
    Paxman13 Member
    I had a squeak in mine and it turned out to be the passenger side upper ball joint needed to have some grease pumped into it. But yea I would jack it up like everyone is saying may need to use the jack under the each lower swing arm to reconnect the lower link to get it to line up when re installing.
  7. Mar 26, 2022 at 2:01 PM
    Fluffymonkey
    College Station, TX
    Thanks, I decided just to pay someone to do the links (it's actually at the shop as I type). If that doesn't fix it, the uppers are definitely next on the list. I'd been meaning to upgrade from SPCs old style uppers to the new ones with the grease fitting anyway.
    Paxman13[QUOTED] likes this.
  8. Mar 26, 2022 at 4:53 PM
    Fluffymonkey
    College Station, TX
    Welp, wasn't the end links. Going to grab a grease needle and pump some grease into the uppers to see if that is the issue.
  9. Mar 30, 2022 at 5:28 AM
    Paxman13
    Paxman13 Member
    From when I did my upper ball joints that bolt is a pita to get out removing a wiring harness clip to get it out the way and bending some sheet metal inside the finder well to get that bolt out if I’m not mistaken it’s about 15” long and has to come out thru the engine bay.
  10. Mar 30, 2022 at 9:59 AM
    Fluffymonkey
    College Station, TX
    Yeah, I remember that being a major pain when I first installed the SPCs. Had to bring out the mallet to bang away at a bunch of sheet metal in the engine bay. I'm almost positive I reinstalled them upside down to make it easier in the future, but I'll have to double-check as that was almost 8 years ago
  11. Mar 31, 2022 at 4:22 AM
    Paxman13
    Paxman13 Member
    Yea I’m fighting my own demons rightnow on my 06 trying to find a noise I can’t pinpoint after replacing all kinds of stuff. So me and my truck have a date Friday.
  12. Mar 31, 2022 at 5:40 PM
    Fluffymonkey
    College Station, TX
    Good luck with your noise hunt! Pumped a bunch of grease into my uppers and the noise didn't change at all, so I'm on to the next thing now :annoyed:
  13. Mar 31, 2022 at 9:51 PM
    Paxman13
    Paxman13 Member
    Yea I’m gonna try to loosen the lowers and re torque before i jack anything up and start looking again.
  14. Apr 5, 2022 at 6:50 PM
    Paxman13
    Paxman13 Member
    I found mine. The sway bar bushings were in backwards and the noise is gone the slot has to face the front greased up with some red and tacky and the sound is gone for now.
  15. Apr 5, 2022 at 7:38 PM
    Fluffymonkey
    College Station, TX
    That's going to be my next move. Hopefully that fixes it, because I'm tired of spending time and money looking for this squeak.
  16. Apr 9, 2022 at 8:22 PM
    ctheulen
    ctheulen Alaskan Assassin
    Glenwood Springs, CO
    2005 Tacoma SR5 4x4 DCLB
    3 inch lift Toytec Ultimate Coilovers Deaver Stage 3 leaf pack Camper shell w/ Prinsu Rack and RTT Maxxis Razr MT 285/75/16
    Any luck? In my own war right now.....
  17. Apr 9, 2022 at 9:21 PM
    Fluffymonkey
    College Station, TX
    Still got the squeak. Ended up just paying a shop to do my sway bar end links. No change in the squeak. Going to do my sway bar bushings next. I washed my truck a few days ago and it was actually quiet for a day, so I'm now starting to think it is a bushing issue. Water got in there and silenced the issue until it dried out again. (hopefully, because I really don't want to mess with ball joints right now)
  18. Apr 9, 2022 at 9:34 PM
    ctheulen
    Get a jar of this stuff.. resists water well
    Energy Suspension 9.11104 8 Oz Tub Of Lubricant https://www.amazon.com/dp/B000MW5SJ4?_encoding=UTF8
  19. Apr 9, 2022 at 9:40 PM
    ctheulen
    btw, have done it all on mine.. links, ends, sway bar bushings, and now LCA’s.. clunk is still there. Starting to think it’s my coilovers with 80k on them.
  20. Apr 10, 2022 at 7:46 PM
    Fluffymonkey
    College Station, TX
