Installing SumoSprings
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Furball, Jun 29, 2022.
  1. Jun 29, 2022 at 8:52 AM
    Furball
    Furball [OP] Well-Known Member
    Minnesota
    2017 TRD Off Road
    Hey y'all I'm about to install a set of SumoSprings and have a quick question.
    My driveway isn't flat and the truck will be facing downhill a little bit not much maybe 5-10 degree slope.
    When I loosen the u-bolt bolts the axle won't end up moving around on me because I'm not on a flat surface right? Like there is a pin or something on the axle that the leaf pack sits on holding it in place right? Just want to make sure I'm ok to do it in my sloped driveway if not I'll have to find somewhere that's perfectly level
  2. Jun 29, 2022 at 9:00 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    There is a pin/bolt holding the leaf springs together.
    Furball[OP] likes this.
  3. Jun 29, 2022 at 9:03 AM
    Furball
    Minnesota
    2017 TRD Off Road
    Ok cool, then that pin sits on the axle holding it from moving right? Just don't want the leaf pack to move on the axle after I loosen it on my sloped driveway. Thank you
  4. Jun 29, 2022 at 11:09 AM
    rnish
    Tacoma 2nd gen
    Yes the pin gos into the axel leaf spring mount. The pin may come out. Not sure if you have to (are) removing the U bolts to install the Sumo’s.
    Furball[QUOTED][OP] likes this.
  5. Jun 29, 2022 at 11:12 AM
    Furball
    Minnesota
    2017 TRD Off Road
    Ok thank you I should be fine then. Don't have to remove the ubolts just loosen them in order to free the stock bump stop and slide the sumo in then tighten it back up
  6. Jun 29, 2022 at 11:30 AM
    Browner
    Browner Well-Known Member
    Shawn
    Central Iowa
    2020 TRD OR
    Prinsu Rack, CBI Sliders, UpTop Truss Rack, Softtopper, TRD OEM 2" Lift, SCS Rims, Wildpeak tires, OVS RTT and 270 Awning, Off-Grid Engineering Dual Battery tray, Red-arc BCDC, Switch Pros Controller, cheap Amazon lights.
    Chock your front wheels and you should be good. I also put it in 4H before turning it off. Not sure if that helps, but I felt like it should. :crazy:
    Late Camaro and Furball[OP] like this.
  7. Jun 29, 2022 at 1:29 PM
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    all you do is loosen the U-bolts and slide the old stops out and install the new SS's, it took me 10 minutes a side.
  8. Jun 29, 2022 at 5:25 PM
    JoshG
    JoshG Well-Known Member
    Florida
    2022 TRD Pro ELM
    OME HD Springs (3” total lift) Rough Country 2” from spacers Tailgate lock Bed lights BFG KO2 265 75/R16
    Same here. I just did one side at a time and it was fine. Just be sure to chock the wheels.
    kgilly[QUOTED] and Furball[OP] like this.
  9. Jun 30, 2022 at 6:53 AM
    kgilly
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    and retorque the u-bolts about 100-150 miles later
    Greg-tacoma and Furball[OP] like this.
  10. Jul 1, 2022 at 10:41 AM
    forana
    forana Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    did you get them installed?
    How do you folks like sumos?
  11. Jul 1, 2022 at 10:57 AM
    Furball
    Minnesota
    2017 TRD Off Road
    I had a break in the rain yesterday and was setting up to install them then realized I didn't have a 19mm deep socket in 5/8 drive for my torque wrench. My impact is in 1/2 drive so I'm glad I checked before I started haha
  12. Jul 2, 2022 at 6:07 PM
    Furball
    Minnesota
    2017 TRD Off Road
    Got the sumosprings in easy peasy. From setup to cleanup I was done in 90 minutes.
