Installing rear wiper on a topper?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Madjik_Man, Nov 4, 2011.
  1. Nov 4, 2011 at 10:53 AM
    Madjik_Man
    Madjik_Man [OP] The Rembrandt of Rattle Can
    Colorado Front Range
    I searched and only got one result (someone's build thread) that had nothing to do with what I'm asking.
    Has anyone installed a rear wiper on a topper? Replete with a reservoir for wiper fluid?
    There are times I really wish I had this.
  2. Nov 4, 2011 at 10:55 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    :popcorn:
    Sounds like a lot of work, I'm interested to see if this has been done. I'm currently looking for a defroster system I could throw on there but this would be cool too!
  3. Nov 4, 2011 at 11:22 AM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    I would LOVE either/both of these mods... sub'd for answers!!
  4. Nov 4, 2011 at 11:24 AM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    sub. and just wondering why this is in 1st gen? seams to me like both 1st and 2nd gen taco’s could benefit from it. or is that just my thinking?
  5. Nov 4, 2011 at 11:27 AM
    Pugga
    Massachusetts
  6. Nov 4, 2011 at 11:36 AM
    TIPICOTACO
    Tyler
    nw nj
  7. Nov 4, 2011 at 11:38 AM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    wouldnt be to difficult. ony issue i forsee is mounting the motor for the wiper assembly, as for a resi for washer fluid you can pick up many generic setups from your local auto parts stores. Id imagine if you run down to your local junk yard and find one from the rear it would do what you want, but like i said, motor mount would be the difficult part.
  8. Nov 4, 2011 at 11:39 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    I don't look through the windows of my topper. That's what back up cameras are for. Thanks Toyota.
  9. Nov 4, 2011 at 11:40 AM
    Pugga
    Massachusetts
    Have you done this? I'm hesitant because the topper rear window is not glass. Any heat issues with the plastic?
  10. Nov 4, 2011 at 1:03 PM
    TIPICOTACO
    Tyler
    nw nj
    NO, I havn't done it but seems like it would work just fine for my set-up. I do have a glass rear window. Maybe contact the company and see if it can be used w/ plastic windows..
    what type of topper do you have? Plastic windows??
  11. Nov 4, 2011 at 1:12 PM
    TIPICOTACO
    Tyler
    nw nj
    Reading the FAQ, it says window tint can be installed over the Clear View defroster. It doesn't specify what type of tint, but if its OK w/ the plastic tint film, I don't see why it wouldn't work on a plastic window also.
    Over time it may dis-color the plastic which would be counter-productive
  12. Nov 4, 2011 at 1:22 PM
    Pugga
    Massachusetts
    Mine's an ARE. I don't know if it's plastic, maybe some sort of polycarbonate type stuff, but definitely not glass.
    Thanks for the info though, I might have to give this a go!
    OP, sorry for the thread jack, wasn't trying to de-rail your thread :eek:
  13. Nov 4, 2011 at 1:50 PM
    TIPICOTACO
    Tyler
    nw nj
    I have an ARE also an older one, mine is def tempered glass. Let me know if you try this, looks cool.
    Sorry for the hi-jack OP :eek:
    In regards to the rear wiper; I just looked at my set-up and the hinged window seems like it would be hard to work around. Like Greensystemsgo stated, the motor mount will be the issue
    How are rear wipers set-up on 4Runners/Highlanders in general?? IIRC the motors are commonly installed into the bottom portion of the rear "hatch" with the wiper extending upward; so w/ our tailgates we lose that option. idk, just thinkin out loud
  14. Nov 4, 2011 at 1:57 PM
    Pugga
    Massachusetts
    Will do!
    I'm guessing you could retrofit a wiper system from something like a Rav-$ or Highlander. Whatever SUV has the wiper at the top of the window. The issue would be mounting, the wiper arm and motor would have to be mounted to the glass itself, or you'd have to custom make a piece of glass, notch it and fill it with metal or something strong that could support the torque of the motor and extra weight. Here's a cut of a wiper arm mount. You could drill out the topper window and maybe put a stronger support on the inside, maybe a 1/8" steel back plate for rigidity. The wiper fluid would be the easier part since it can be located anywhere as long as you can route a hose to the wiper. It of course would mean another hole in the rear topper window though.
  15. Nov 4, 2011 at 2:12 PM
    99yodataco
    99yodataco Little Taco that could
    Chad
    New Mexico, it's just a little bit fresher.
    MGM 21 TRD OR 6sp MT
    Soon...
    I would suggest looking into a Jeep hardtop rear wiper setup. I have a YJ with a hardtop and the rear wiper is a hinged setup.
    Interior mounting
  16. Nov 4, 2011 at 2:49 PM
    TIPICOTACO
    Tyler
    nw nj
    ^that looks pretty doable!
    However it wouldn't work for someone w/ a 3rd brake light like I have on my cap. You would want the wiper centered and that is exaclty where the light is :(
    Pugga - that pic shows a rear defroster too ;) lol
  17. Nov 4, 2011 at 2:51 PM
    Pugga
    Massachusetts
    Hell yes!
    I'll probably do the defroster, not the wiper. I want it to defrost in the morning because I have to back out onto a busy street but I grew up driving dump bodies so it doesn't bother me not being able to see out the back once I'm driving.
  18. Nov 4, 2011 at 2:57 PM
    TIPICOTACO
    Tyler
    nw nj
  19. Nov 4, 2011 at 2:59 PM
    Pugga
    Massachusetts
  20. Nov 4, 2011 at 4:18 PM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    you could do bottom mounting, generally the motor is simply a splined stud you could simply move the wiper arm.
