installing gears
Discussion in '2nd Gen. Tacomas (2005-2015)' started by IndianTaco, Mar 14, 2012.
  1. Mar 14, 2012 at 5:00 PM
    IndianTaco
    IndianTaco [OP] Well-Known Member
    How hard is it? I'm not afraid of turning a few wrenches. I've done motor,tranny t-case swaps just never gears. I'll be getting my gears from east coast gear supply. thanks in advance for the help.
  2. Mar 16, 2012 at 8:54 PM
    IndianTaco
    Anybody install there own gears:confused:
  3. Mar 16, 2012 at 8:57 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Quite a few (like me) pull the third member/front clamshell diff and have the gears done by a diff specialty shop as a bench job.
    Personally, I don't weld and I don't do jobs where the difference between success and failure is measured in thousandths of an inch.
    But over on TTORA there's a thread that describes setting up the gears in the rear third. Not so sure where to find a thread describing a front clamshell setup.
  4. Mar 16, 2012 at 8:59 PM
    Alex88
    Alex88 Well-Known Member
    Alex
    Oakland, CA
    2010 DCLB Sport
    looking for a step by step myself. I have a 2010 sport so there is no LSD per-se, the electrical LSD just applies the brakes making my diff open i guess. anyone have a pictorial? moving up to 285's and 4.10's, and the 1200-1300 dollar price to have a shop doing it is depressing.
  5. Mar 16, 2012 at 9:15 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    It's not terribly difficult but it's complicated and not a job most are able to take on, on their own.
    You can definitely buy everything needed to do it for the cost of labor you'd pay but like I said it's complicated.
    You'll pull everything. Put in new ring gear, with new bolts, and new pinion, also bearings (so you'll need a press). Then you'll need to set bearing pre-loads on the carrier and pinion. Then you'll need to set backlash which will require adding/removing shims and then re doing your preloads etc etc.
    That's basically it but ain't quite so simple.
    http://www.4x4wire.com/toyota/4Runner/tech/regear/
    http://www.4x4wire.com/toyota/tech/gear_setup/
    Never done a toyota but from what I've read they're very similar to most semi diffs.
  6. Mar 16, 2012 at 9:25 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Another thing to consider if you fuck up or need to order more parts etc... or if it just takes too long
    is this your daily driver or do you have alternate transport? Can you leave your truck sitting wherever it's at while you work out the problems, for several days?
    If you're determined, might be worth it to buy another 3rd and build that one in your garage or wherever and then once you're sure it's correct just swap them.
  7. Mar 16, 2012 at 9:26 PM
    Underdog777
    Underdog777 Well-Known Member
    Gilberz
    '06 Stuckrunner
    Camburg LT.
    I meant to do a write up when I did mine (twice). It's not hard if you write down your tolerances and have a ton of shims. You might need to put it together/take it apart 2 or 3 times to get your pre load just right. IIRC your pinion pre load will have to be between 9-12ftlbs. Your gears will come with directions as far as proper pre load. As a word of warning you will have to pre load the crush sleeve as well. Not doing so will lead to either a ton of drive line vibration, a leaking pinion seal, or both (which is what I need to fix).
    In all honesty your best bet is to pull the third member yourself and have someone set up the gears for you. The most expensive quote I've ever gotten was $120 bucks to set up a ring/pinion. It is a pretty brainless process to pull it and for me that's saying something because I am NOT a great mekanick. Good luck :thumbsup:
    edit: my third go at re-gearing I chose the option to have someone else do it. They didn't listen to me when I told them to pre load the crush sleeve and that is what lead to my issues. I've gone from 4.10, to 4.88, back to 4.10, and finally got what I wanted with 4.56's. It was a nightmare.
  8. Mar 16, 2012 at 10:01 PM
    badger
    badger Well-Known Member
    07 SR5
    I've done gear set-ups many times on harder units than a Toyota. the first one I ever did took days but came out great. The more you do the better you get. When it came time to do my Toyota I just said screw it and paid to have a good Toyota smart shop set them up.
    There are only two reasons to ever do this work yourself IMO. One is if you just really want to know how things work. The other is if you do not have access to a reliable gear man. This is very much specialty work. With the removable thirds and people like ECGS and JT, you don't have to worry about the limitation of finding a local expert. I don't plan to ever set up gears on my Tacoma.
  9. Mar 17, 2012 at 2:56 AM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    Don't do it yourself!!!! You really have to know your shit with re-gearing and can't just wing it. Pay a specialist to do it and have piece of mind.
  10. Mar 27, 2012 at 8:28 PM
    IndianTaco
    ordered my gears and arb locker last wednesday. the gears are gonna be set up from ecgs and all ill have to do in remove my old 3rd member and install. same with the front clamshell talked with chase about it cost a little more this way but he said its the best way to go.
  11. Mar 27, 2012 at 9:22 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Yep, this is one of those projects you're better off leaving to another.
  12. Mar 27, 2012 at 9:45 PM
    IndianTaco
    ok max you talked my into it
  13. Mar 27, 2012 at 9:53 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    I'm sorry, did I offend you? Did you miss my other two posts? I thought those were pretty helpful and specific to your questions.
    I've set up gears and also had them set up by ECGS. But hey what do I know?
    Or did I read your reply wrong? :/
  14. Mar 27, 2012 at 9:58 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
  15. Mar 27, 2012 at 10:13 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    I think he simply meant it was already a done deal?:notsure:
  16. Mar 27, 2012 at 10:14 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    If that's the case my apologies and I mistook his post.
    Edit: Yep, I'm a dick. Sorry, haha.
  17. Mar 27, 2012 at 10:39 PM
    IndianTaco
    no max you didnt offend me. i did read you other 2 posts. i already ordered the stuff from ecgs 4.88's front and rear with a arb air locker in the rear already set up. from what i understand from chase at ecgs is that the set up i ordered is drop in ready.
  18. Mar 27, 2012 at 10:45 PM
    Umrunner
    Umrunner Caltanian
    Around.
    '11 DC OR Timberland Mica. 6 speed.
    Leer 100xr with adventure package, duratrack's, weathertech's, demello sliders, billie 5100's all around, URD short shifter, Diff breather mod. Hiese lightbar. Grillcraft grill. PIAA 520 severere weather driving lights. Other random stuff as well.
    as someone who has just spent the last three months going over the basics and premise of setting up gears as a part of a technical education program, taking it to a shop is the best thing you can do. Backlash, bearing pre-load, shimming, and patterns. All things you need to figure out perfectly, preferably the first time, because pulling things apart sucks.
    The process is not hard. The technique is. That's where the issues lie. But a re-gear is awesome, and well worth it if your trying to make up for tire changes, or hopes of improved economy, at the loss of power.
  19. Mar 27, 2012 at 11:00 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    My mistake I misunderstood your post. My apologies sir. Glad you have it figured out and I think you'll be happy with the new 3rds. Make sure to check out Monkey_Proofs sticky at the top of the 2nd gen forum for an install write up. I also posted a couple links of other write ups in there. :)
