Installing Carpet on Cap/Shell - Any Suggestions ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Will.Climbs, Sep 10, 2019.
  1. Sep 10, 2019 at 7:14 AM
    Will.Climbs
    Will.Climbs [OP] Well-Known Member
    Will
    Looking to install carpet on the inside of my fiberglass shell. Any suggestions as to which type of carpet , which type of glue, or the process ?
    I've done a search that didn't turn much up! Any advice is appreciated!
  2. Sep 10, 2019 at 3:31 PM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    Shag, the answer is definitely shag. :drevil: Just kidding, don't do that. I helped pull some out of a shell my brother picked up for free once- it was pretty gross (the Dodge he had at the time and the free shell). Look for some of the indoor/outdoor stuff like the manufactures use, it's going to be subject to humidity changes, especially if you sleep in the back (we give off lots of moisture via respiration), and you want it to not hold much dust and dirt if possible.
    I've used that gray, short-nap nylon stuff that Lowe's sells in several vehicles and on several projects and it's held up well- inexpensive too. I glue it down using the carpet glue but I've also used 3M 77 with decent results. Pretty sure this is it: https://www.lowes.com/pd/Home-Office-Stock-Carpet-6-ft-Needlebond-Interior-Exterior-Carpet/4740900
    Old Marine Cal likes this.
  3. Sep 21, 2019 at 1:36 PM
    Will.Climbs
    Will
    Thanks for the suggestions! Doing this project tomorrow!
  4. Sep 22, 2019 at 12:26 PM
    GTOJim
    GTOJim Well-Known Member
    Jim
    SF Bay Area
    2013 PreRunner TRD OffRoad V6
    Another possible option is carpet tape. It's double sided. If it gets hot where you live not sure how it will work. I have used 3M 77 many times, again I'm not sure about it holding up in very hot weather.
    Over spray from 3M 77 is very sticky. If the shell is mounted on the truck, it's something to be aware of.
  5. Sep 22, 2019 at 1:29 PM
    Will.Climbs
    Will
    Went to two hardware stores today and was unable to find the correct carpet / material.
    Thinking about ordering some online. Does anyone have any links?
    Also any alternatives to stronger than 3M 77 or carpet tape? It can get hot in the summer..
  6. Sep 22, 2019 at 1:51 PM
    Killowatt
    Killowatt Well-Known Member
    Citrus County Florida
    2013 4x4 TRD OFF ROAD
    Call the topper manufacture and ask them, they might have carpet already cut, and tell you what type of glue to use.
  7. Sep 22, 2019 at 1:54 PM
    Old Marine Cal
    Old Marine Cal Well-Known Member
    2015 MGM DBLCAB
    Where are you located?
    That might help someone help you.
    And it gets to 119 in the summer here in the deset of SO cal, and I use 3m 77 adhesive all the time.
  8. Sep 22, 2019 at 1:59 PM
    Will.Climbs
    Will
    Located eastern Canada.
    Good idea about calling the manufacturer. Will do.
  9. Sep 22, 2019 at 2:01 PM
    Old Marine Cal
    2015 MGM DBLCAB
    In Canada, I would be more concerned about the impacts of COLD weather on the adhesive...…………...
  10. Sep 22, 2019 at 4:34 PM
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    Something stronger than 3M 77? Try 3M 99.
    I used 77 on the carpet for my plywood platform. Holding fine so far but of course that isn't on the ceiling and I folded the carpet over the edges and stapled them.
  11. Sep 23, 2019 at 5:00 AM
    Scrat
    Scrat GRYLNG
    Jacob
    Woodland Park
    V6 SR5 '15
    ARE CX Topper, Yakima rails with various accessories, Bilstein 5100, Icon RXT, OME 886 coils, Firestone Ride-Rite, 265/75/16 KO2, Mobtown Offroad Rear Bumper., Diode Dynamic map and dome lights, headlight harness, Cali-raised bed stiffeners, Cali Raised accessory bed mount, Cobra 75wx st, Leixen VV898e, Safari Snorkel, SOS Sliders, CBI Full skids pack, and more coming!
    My shell came with it as a free upgrade. It is a marine-grade carpet. As for installation, I won't be able to help answer that. West Marine should have a variety.
  12. Sep 25, 2019 at 5:23 PM
    No Shoes Nation
    No Shoes Nation Well-Known Member
    2008 Taco SR5 Access Cab 4.0 4x4
    Hmm . . . none as yet, that's why i'm here . . .
    indoor/outdoor carpet. 3M upholstery glue.
  13. Sep 25, 2019 at 5:33 PM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    Weldwood Contact Cement (red can) solvent based. Use a respirator.
  14. Sep 26, 2019 at 11:22 AM
    Steve_P
    Steve_P Well-Known Member
    TN
    09 Tacoma SR5 4WD 4cyl
    I would use something other than the 3M 77. It is pretty good, but it's expensive - and you'll need several cans. Go to an upholstery shop and try and buy a gallon of the glue they use for headliner replacement from them. They get it in 5 gallon buckets and it's relatively cheap. Bring clean containers and a funnel. You can spray it with a cheap spray gun or brush it on. This will be way cheaper, and better, than anything in a spray can, as it's much thicker. I've had great results with it.
    The carpet in my ARE shell looks just like the gray indoor/outdoor carpet that Home Depot, etc sells.
