Installing brake control in 2014 with tow package?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CJP2x4x2, Jan 8, 2022.
  1. Jan 8, 2022 at 2:53 PM
    CJP2x4x2
    CJP2x4x2 [OP] Member
    2014 Spruce PreRunner & 2012 4x2 beater
    I'm trying to set myself up for towing a Escape 19. A lighter weight "Egg" Fiberglass trailer(3250# dry weight). The tow vehicle is a 2014 PreRunner, SR5 with tow package. I want to put in a Tekonsha Prodigy P3. I thought I read somewhere that the tow package has already installed 7 pin plug with the brake wire running up to & under dash somewhere for with some kind plug ready for the controller? I have the 7 pin plug under bumper. No need to running a whole new wire? I have nerve damage right hand, & using hand tools & fishing around in tight places is hard for me. Any photos of what I would be looking for, if there is a plug end? Thanks
    jpereira2 likes this.
  2. Jan 8, 2022 at 2:57 PM
    AJKlug1
    AJKlug1 Well-Known Member
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Full sound system, 3rd gen OR suspension, pro headlights & more
    I put one in my 2010 with TP. It is under the dash up above the parking brake pedal. Your truck should have come with the other end of the plug that goes to bare wire for installation. Depending on what control you have there could be a quick connect harness like with the Curt one I installed.
    CJP2x4x2[OP], drewnali and jpereira2 like this.
  3. Jan 8, 2022 at 3:49 PM
    badzook
    badzook Member
    East Coast
    Off Road
    I Have a 2014 and same for mine. Plug is up above the E Brake pedal. The mating wire came in the glove box when I bought the truck new. Just pinned out the diagram and wired to the controller. Mounted it above my right knee. Took about an hour. Works great and I tow with it alot.
  4. Jan 8, 2022 at 6:10 PM
    AJKlug1
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    I riveted mine to the change tray by our right knees. Nice because you can see the lights through the steering wheel!
    CJP2x4x2[OP] likes this.
  5. Jan 8, 2022 at 6:47 PM
    TacoTuesday1
    FL
    It may be behind easy to remove interior panels in the left footwell area. Unless I was looking at the wrong connector.
  6. Jan 8, 2022 at 7:40 PM
    Bluenoser009
    Bluenoser009 Well-Known Member
    Alberta
    06 Tacoma (A-cab/TRD/SR5/OFF-ROAD/6 spd)
    Mine wasn’t too hard to find in my ‘06, but finding the wiring in my wife’s Audi Q7 was way tougher! So keep looking and you should find it. I have a cheap Quest controller on my Tacoma, which gets the job done. But the Tekonsha in her vehicle is awesome. So good choice
  7. Jan 8, 2022 at 8:11 PM
    Bluenoser009
    Alberta
    Oh and Welcome to TW! Just saw you joined today, OP.
    Maybe you were like me and lurked the threads long before joining. If not, you’ll find tons of help on here. And I’m sure you’ll hand some out too
  8. Jan 9, 2022 at 11:17 AM
    CJP2x4x2
    Well I went digging into the bottom of the glove box. I haven't had the truck that long. I found out I have the navigation system!? Which I'll never figure out, or trust. I had Garmen, it went totally OUT, in the middle of NOWHERE, on a heavy cloudy day(couldn't tell which direction was what!), no maps. Also I'm someone who is Still on Windows 7, & uses only a clamshell cell. I found some kind of wiring for the back-up camera, & this bundle of wiring with a "heavy red" wire, looks promising, like I don't have to order one. [​IMG] Now to read the manual I guess.
  9. Jan 9, 2022 at 11:32 AM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    Gotta remove the drivers side plastic door sill, then remove the plastic foot step, and then remove left panel by the parking brake. Then the plug is wrapped around other wires up towards the parking brake. Your going to have to feel for it.
  10. Jan 9, 2022 at 11:48 AM
    Bluenoser009
    Alberta
  11. Jan 9, 2022 at 12:20 PM
    CJP2x4x2
  12. Jan 9, 2022 at 12:26 PM
    Bluenoser009
    Alberta
    hahah fair point! Not a fun job but maybe this will help it not suck as much??
    :censored:
    CJP2x4x2[QUOTED][OP] likes this.
