Installing a voltmeter gauge
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Izzy_Taco, Feb 1, 2019.
  1. Feb 1, 2019 at 10:57 AM
    Izzy_Taco
    Izzy_Taco [OP] New Member
    Israel
    2019 Gun MetalBlack Tacoma TRD Off-Road 4X4
    I currently installed ditch lights and bar lights on my 2019 Tacoma. I also have things plugged in the usb 100% of the time. I want to keep an eye on the voltage of my battery. Need some guidance on the electrical and wiring part.
    Thanks guys!
  2. Feb 2, 2019 at 4:14 AM
    GulfCoastMike
    GulfCoastMike Co-pilot Angel
    Pascagoula, MS
    2017 MGM AC SR5 3.5L A/T
    Here’s a cheap, simple solution for you. You don’t need anything complicated.
  3. Feb 2, 2019 at 4:17 AM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    You can get a scangauge or something too. It sounds like you dont have enough going on there to worry. I've got a gps, radar, camera, scangauage, CB, fridge, 9" leds, rigid pods, and scene lighting all hard wired. I am running a single battery with no issues.
    Jobr and Izzy_Taco[OP] like this.
  4. Feb 2, 2019 at 4:54 AM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    2016Tacoman likes this.
  5. Feb 2, 2019 at 6:03 AM
    MoneyMan55
    MoneyMan55 Licensed Master Electrician
    Doug
    South Central PA
    2017 DCSB SR5 Blazing Blue Pearl
  6. Feb 2, 2019 at 6:09 AM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
  7. Feb 2, 2019 at 7:27 AM
    Boomer3731
    Boomer3731 Well-Known Member
    2017 DCSB TRD Sport
    The hole needs to be slightly enlarged. You can install it just by removing the head unit and reaching down behind it.
    Fair warning, it is bright.
  8. Feb 2, 2019 at 7:43 AM
    Tcgator
    Tcgator Well-Known Member
    Tyler
    Fernandina beach
    2017 Quicksand TRD Offroad
    Do you have more photos of this on?
  9. Feb 2, 2019 at 8:56 AM
    Boomer3731
    2017 DCSB TRD Sport
  10. Feb 2, 2019 at 9:02 AM
    SpeySquatch
    2016 TRD OR DCSB
    Seems like that would get annoying driving at night...
  11. Feb 2, 2019 at 9:08 AM
    Boomer3731
    2017 DCSB TRD Sport
    It's far enough out of the way that it's not bad. I might open it up and try to swap some of the resistors though, as I've done with my CH4x4 switches.
  12. Feb 2, 2019 at 9:13 AM
    SpeySquatch
    2016 TRD OR DCSB
    Same thing I’m thinking for the empty spot in the bottom right
  13. Feb 2, 2019 at 9:13 AM
    Sixthelement
    Sixthelement Ran over a Yeti once, Texas, never again
    Flagstaff
    24 F150
    Fox 2.0
    Piece of that frosted scotch tape should be a quick solution, in the interim.
    doublethebass likes this.
  14. Feb 2, 2019 at 11:00 AM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
  15. Feb 2, 2019 at 11:57 AM
    MoneyMan55
    Doug
    South Central PA
    Had to file the hole just a tad. Pull the trim around radio and remove radio. Crimp new terminals. That's it. Piece of cake
  16. Feb 2, 2019 at 12:00 PM
    MoneyMan55
    Doug
    South Central PA
    Installed
  17. Feb 2, 2019 at 5:30 PM
    Izzy_Taco
    Israel
    That’s exactly what I’m trying to do. Can you help me with the wiring?
  18. Feb 3, 2019 at 11:25 AM
    Ronzio
    Pennsylvania
    17 DCSB TRDOR
    Sure remove drivers side kick panel attach black wire to ground there is a factory ground spot behind the kick panel...then red wire to a add a fuse use fuse shown in the photo and your done.
  19. Feb 3, 2019 at 12:41 PM
    caribe makaira
    Caribbean, Puerto Rico
    Since the truck has no Sliding "MoonRoof"o_O, use that circuit to tap the add-a-circuit.;)
    beeip and Izzy_Taco[OP] like this.
  20. May 17, 2019 at 5:04 AM
    Banker
    Banker Well-Known Member
    OHio
    2017 Sport TRD DCSB
    Sorry to bring this tread back up. Does't the lighter/round power adapter have power to it now that you can use? Or does it have constant power at all times so you had to wire in power that is keyed on/off? I am also looking into adding a voltmeter gauge.
