Installing a rear infant carseat in the middle seat of a doublecab?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoGuaco, Oct 27, 2020.
  1. Oct 27, 2020 at 7:55 AM
    TacoGuaco
    TacoGuaco [OP] Well-Known Member
    I got me a Taco and I'm lovin' it but I'm faced with a challenge that I need some help with. It's related to baby infant seats. I need it to be installed in the middle of the double cab but I am not sure if I did it correctly. Does anyone else have experience installing a rear infant carseat in the middle seat in a doublecab?
    I'm not sure if I need some extra belt/buckles or not. Any help would be appreciated! Thanks y'all.
    TLDR
    I have a double cab taco, need to install rear facing infant seat in the middle seat. How do?
  2. Oct 27, 2020 at 7:59 AM
    Myrtle Beach Taco
    Myrtle Beach Taco Member
    Myrtle Beach
    12 currently stock
    I know around here, in SC. the local fire deparartment will help you with the install of baby seats. They are generally very happy to do so.
  3. Oct 27, 2020 at 8:01 AM
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    Yep, took mine by a fire station. They made a rookie install it and made sure he did it correctly.
    wilcam47 likes this.
  4. Oct 27, 2020 at 8:06 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Yeah, better safe and have the pros show you how at the fire station.
    Chew and Thunder Fist like this.
  5. Oct 27, 2020 at 8:53 AM
    BSFord
    BSFord Well-Known Member
    2018 TRD Sport 4x4
    Clazzio PVC Seat Covers Dashcam install TRD Pro Grill MESO Total Tail Stage 1 Tailgate Lock vled total interior light upgrade TRD Pro Shift knob N2 Designs Autostart w/ smart phone module
    Meh, I dont know if you need the fireman to install it, but I know they do have events where they'll check them. Just read the instructions that came with it. My infant seat has a base it snaps into, and you install that using the seatbelt, pretty simple to do
    dclbYak and 02Duck like this.
  6. Oct 27, 2020 at 8:56 AM
    yoopersteeze
    yoopersteeze Fake it til you make it
    WI
    2017 Magnetic Gray Metallic Tacoma TRD OR MT
    Let me find the one we got. It's snug, but it works. There should actually be more room in the middle I would think. Just pull as hard as you can on the straps until the seat literally does not wobble back and forth.
    BSFord likes this.
  7. Oct 27, 2020 at 8:58 AM
    Natetroknot
    Natetroknot Experiencing TW at several WTFs per thread
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    I never would've thought about the fire station, what a great idea!
    MoneyMan55 likes this.
  8. Oct 27, 2020 at 8:59 AM
    Iwilltaco
    Iwilltaco Well-Known Member
    @kairo’s guest house having a water with @not_nick
    Under development
    Yep, should have a proper angle gauge on the seat, get that good while truck is level, and get it snug. If you can put your weight on it with a knee or something while you pull, all the better.
    The_Airbornefister likes this.
  9. Oct 27, 2020 at 9:01 AM
    yoopersteeze
    WI
    Yeah, we got this one: https://www.amazon.com/Chicco-Conve...-1+Convertible+Car+Seat&qid=1603814371&sr=8-5
    I literally had to crawl in the cab and kneel on it with my 220lb frame which really helped. Really, just make sure it's in the area of being level and it's tight tight tight.
  10. Oct 27, 2020 at 9:03 AM
    yoopersteeze
    WI
    I am not sure if there are the car seat anchors in the middle, but use those. You can try the seat belt through the middle, but I've not found that to work.
  11. Oct 27, 2020 at 10:50 AM
    TacoGuaco
    ok I should've clarified, definitely many different models of car seats. This is the one in question:
    https://www.chiccousa.com/shop-our-products/car-seats/chicco-keyfit-30-infant-car-seat/
    I didn't see any anchor straps, so what I did was I used the middle belt to fasten it, the one where you pull it all the way out till you hear a click.
    Then I used the anchor buckles that was used for the side seats, it was a bit of a stretch but it clicked on each sides. I don't think the middle seat has a click on belt buckle.
    I did think about going to the fire department, but those heroes have enough on their plates right now with the fires and what not.
    Thanks for helping out everyone, good points, keep tossing some tips and thoughts.
  12. Oct 27, 2020 at 10:53 AM
    wrightme43
    wrightme43 Well-Known Member
    Scottsville Kentucky
    17 Double Cab M/T TRD Offroad Blazing Blue Pearl
    Redline custom leather shift and e-brake boot. VFTUNE Super Full Otto cycle, octane learning, premium fuel.
    There are no latch anchor points in the middle of my 2017 double cab.
    Same KeyFit 30 by Chico but behind pass seat using latch anchors.
  13. Oct 27, 2020 at 10:57 AM
    Iwilltaco
    Under development
    Similar to mine, I was able to use the anchors from each side. Was good and tight.
  14. Oct 27, 2020 at 10:59 AM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    Right, make sure you kneel on it to get rid of the slack when you make it tight. You don't want any wobble.
  15. Oct 27, 2020 at 11:00 AM
    CaliKat
    CaliKat Well-Known Member
    That should work fine. It’s a tight fit though, hope you don’t need to sit any adults back there with the seat.
  16. Oct 27, 2020 at 11:10 AM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    Hope u have a second vehicle ...Tacoma is not ideal for kid transport ..really no room back there . Plus then u still have to stow strollers and other baby’s items . No offense worse choice to buy a Tacoma I would of gotten a 4 runner .
  17. Oct 27, 2020 at 11:40 AM
    yoopersteeze
    WI
    Yep. Child transport is not easy with Tacoma. Bed cover works good for storage or strollers / other items. We've not run into any issues yet, other than it's tight. Luckily I'm only 5'9" and my wife is 5'2" so we don't feel crammed in there. We had the same base "KeyFit 30" and it worked without issue behind the passenger seat.
    As long as the middle is secure and the base does not move it will be fine. I personally would not place an infant in the middle, but if that's what you have to do, just drive safe.
  18. Oct 27, 2020 at 11:50 AM
    cgs2k2
    cgs2k2 old man
    Middle is the safest spot for infant seat. Away from airbags and side impacts.
    yoopersteeze[QUOTED] likes this.
  19. Oct 27, 2020 at 11:54 AM
    yoopersteeze
    WI
    You're not wrong.
  20. Oct 27, 2020 at 12:24 PM
    07RedTacoDawg
    07RedTacoDawg Well-Known Member
    Danny
    Jamestown , NC
    07 Red Tacoma
    2 inch lift , tires and wheels
    Make sure its tight. Don't want jr flying around while ur rock crawling
