Installed: Firestone Ride Rite Air Bags
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DocsTacoma, Apr 15, 2013.
  1. Nov 4, 2013 at 7:50 AM
    #141
    talisker
    talisker Well-Known Member
    Scott
    Vermont
    06 TRD Off Road SR-5 W/1 Ton wood pellets
    Firestone Ride Rite airbags
    Hmm... I didn't know anything about having to replace u bolts after loosening them! That's what I did. I wasn't about to sit there hacking through bump stops when it was so easy to just loosen the U bolts and remove them entirely. Done in like one minute per side. I just retightened them.
  2. Nov 4, 2013 at 7:55 AM
    #142
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    Sawzall FTW
  3. Nov 4, 2013 at 8:53 AM
    #143
    Partzguy
    Partzguy Well-Known Member
    Don
    North Texas
    2015 DCSB TRD Sport 4x4
    I bought a set of Ride Rites from Amazon 3 months ago, same problem. If I were you I wouldn't count on Amazon solving your problem. I called Firestone, and it ended up taking a week to receive the correct fittings they sent by "snail mail".
    I couldn't wait that long...
    Instead, I went to a local auto parts store and bought brass reducer fittings. Even though using them raised the fitting on top of the airbag higher, there is plenty of room up there and everything worked perfectly!
    Don
    OOPS! Just realized the previous post was 2 months old!
    Maybe my experience will help someone else...
    Taka The Tacoma likes this.
  4. Nov 27, 2013 at 6:24 PM
    #144
    boxxed
    boxxed Well-Known Member
    Denver, CO
    09 Off Road
    I see people are using these:
    http://www.amazon.com/Firestone-W21...sr=1-1&keywords=firestone+2410#productDetails
    Firestone W217602410
    Which is for 2 wheel drive.
    And then they have these:http://www.amazon.com/Firestone-W21...Rite+Kit+for+Toyota+Tacoma+4WD#productDetails
    Firestone W217602407
    for 4 wheel drive.
    Does it really matter? I just ordered the 4 wheel drive ones today. I have a 4 wheel drive and just want to make sure I wasnt missing something. Or does Amazon have the wrong picture?
    Thanks.
  5. Nov 27, 2013 at 8:10 PM
    #145
    Fifthwind
    Fifthwind Master of None
    Murph
    Lehigh Valley, PA
    Scully
    Barcelona Red 09 DCOR- Icon 2.5" ECOs w/CDC - 14" 700lb, ICON 2.0 RR Ext rears, AP EXPO pack, Diff Wedge, Diff and Skid Drop, Discoverer S/T 255/85/16, Ride-Rite Bags w/ Daystars, ARB Bull/winch Bumper, Warn 8k, ARB CMK12, Budbuilt skids, BAMF bolt on sliders BAMF diff diaper, bedlights, hoodlights, BAMF CB, etc.
    I have the W217602407 and the 2366 2" spacers. I needed to get 1/8" npt (http://www.amazon.com/gp/product/B009PT7VF4/ref=oh_details_o09_s00_i00?ie=UTF8&psc=1) fittings as the Amazon package had 1/4" npt fittings. Cut the bumps off with a sawzall. I you have no lift, read the previous note about the psi and the rake your truck will have. Bottoming out the bags will really kill them fast.
  6. Nov 28, 2013 at 8:03 AM
    #146
    boxxed
    Denver, CO
    09 Off Road
    Thanks, I hope I get the right parts. I have very limited time. I do not have a lift. The only thing I had done was TSB for the leaf spring and thats it.
    This might be a hard question, but is there a local store that might have the part if Amazon screwed up?
    Thanks
  7. Nov 28, 2013 at 5:11 PM
    #147
    Fifthwind
    Murph
    Lehigh Valley, PA
    Scully
    When I said lift I should have said lift kit. I have the Toytec Ultimate 3". I used the factory jack and wood blocks on a driveway, took a few hours. As for fittings you might try a NAPA or other parts store. If you venture down the adapter road via a home depot (1/8 to 1/4 adapter and close nipple in brass) use lots of the blue thread tape and tighten it to ridunk before putting the bag in place.
  8. Nov 30, 2013 at 5:23 PM
    #148
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    The only thing I have seen people talk about being screwed up is the air fitting. Mine was fine. But you could hit up a truck stop if you have any problems. They are common air fittings.
  9. Nov 30, 2013 at 5:53 PM
    #149
    boxxed
    Denver, CO
    09 Off Road
    I got it on Friday. I was missing 3 of the 4 zinc coated bolts. (I think they are zinc) I just went to Home Depot and got what I needed.
    Other then that the install went pretty smooth. It really was pretty easy to do.
    I have a tandem trailer that was loaded. I went and got it weight and it was 4680# The Tacoma did not do to well before the Firestones. Now it has no problem pulling that load.
  10. Nov 30, 2013 at 5:55 PM
    #150
    acdronin
    acdronin Well-Known Member
    Whoo hoo, so ya like the bags?
  11. Nov 30, 2013 at 6:05 PM
    #151
    boxxed
    Denver, CO
    09 Off Road
    All most as much as my girls fun bags...
    KeystoneGoodie likes this.
  12. Nov 30, 2013 at 6:37 PM
    #152
    acdronin
    I'll take that as a yes then:p
  13. Dec 5, 2013 at 6:05 AM
    #153
    boxxed
    Denver, CO
    09 Off Road
    I went to get an alignment at the dealer today and they basically told me that because the of the airbags it would make it hard to align. Once I add air and change the height it would throw off what they do. They said that the lift on the back changes the dimensions and angles.
    My alignment is not bad. The truck will start to veer to the left even if I am the right side of the road. It does not pull but it will veer.
    So what do you guys do to base your alignment off of?
  14. Dec 5, 2013 at 6:42 AM
    #154
    ajohnson
    Andy
    Charlotte, NC
    Its pretty simple,get it aligned with the bags filled to your preferred pressure/ride height.
  15. Dec 5, 2013 at 8:24 AM
    #155
    boxxed
    Denver, CO
    09 Off Road
    I'm doing that now. It makes me nervous have the dealship work on my truck.
  16. Dec 5, 2013 at 9:50 AM
    #156
    acdronin
    the shop I went to didn't say anything about the bags
  17. Dec 6, 2013 at 7:55 AM
    #157
    Utard
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    What a load of shit!
    Don't those air heads know the air bags are filled with air?
    Silentshredr likes this.
  18. Dec 6, 2013 at 9:01 AM
    #158
    talisker
    Scott
    Vermont
    I'll put my two cents in here. If you do not move your axle from your spring pack, I cannot see any real change in alignment or need to re-align. Maybe I'll see a bunch of you saying I'm wrong but.....
    Do you have a front end alignment if you are going to be hauling a heavy load a long distance because you are changing the height of the back of your vehicle? I know I never have.
  19. Dec 6, 2013 at 9:47 AM
    #159
    GuapOh
    GuapOh Well-Known Member
    Nor Cal
    2011 SR5 4x4 MT
    Skid Plate, Hood Protector, Wheel Locks, Snugtop XV, Yakima Rack, Weathertechs, Sick Speed Shifter, Avid Bumper, Avid Sliders, Bilstien 5100's, TSB Spring packs
    That is a great looking truck.
  20. Feb 21, 2014 at 1:34 PM
    #160
    maxpower29
    maxpower29 Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    Getting a kit soon for my truck. I have the 5th 1.5" AAL in the rear, would you guys suggest the spacers or no? I would like to just keep the same ride height with no load and obviously keep it from sagging so much under huge load
