Install the Smittybilt compressor under hood?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by skcihs, May 15, 2020.
  1. May 15, 2020 at 10:05 AM
    skcihs
    skcihs [OP] Active Member
  2. Jun 2, 2021 at 2:56 PM
    Mateoblagana
    Mateoblagana New Member
    2017 Silver Tacoma TRD OR DCLB
    2" ARB OME Lift, 285/75/16 BF Goodrich KO2 tires, Prinsu Roof Rack, Nighlight Ditch Lights, Tacorail phone mount system, Midland Radio
    Did you get it installed? Mine arrived today. I didn't realize how big it is!
  3. Jun 2, 2021 at 10:00 PM
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    I put one where a second battery would go. Had to move some hoses/bend some brake lines out if the way to allow it to fit. Made a bracket to support the weight of this massive thing. Hard wired it in with a switch and the air connection in the wheel well. Only thing i need to redo, is the hose coming directly off of the compressor as it basically does a 180 degree turn and is borderline kinked.20210403_184146.jpg 20210403_155021.jpg
    Scrat and MJTH like this.
  4. Jun 3, 2021 at 6:30 AM
    Pilsner
    Pilsner Well-Known Member
    18 TRDOR
    255/85r16 ST Maxx 6112/5160 w/ Dakar RCI armor, sliders, and rear bumper CBI hidden winch mount w/ Smity 20k
    Here is what I did for my Viair that looks extremely similar. It is all hard wired now. This summer I will be adding a distribution block and pressure shut off switch. I made the bracket out of aluminum that I had in the shop.
  5. Jun 3, 2021 at 10:33 AM
    Millhouse516
    Millhouse516 Traveling by Tacoma
    San Diego
    Silver 2019 DCSB SR5
    5100's - Icon AAL - RTT - DIY Awning - DIY Mods
    I added my Viair to my truck. Not the same compressor obviously, but may give you some alternate ideas. Been great, no issues whatsoever so far.
    https://youtu.be/jsRGuHM7ffA
    EvxnCrxss and Uthmoelleri like this.
