Inside roof bungee net
Discussion in 'Tonneau Covers, Caps and Shells' started by phdog, Apr 30, 2018.
  1. Apr 30, 2018 at 7:03 PM
    phdog
    phdog [OP] Well-Known Member
    Jim
    Northern Colorado
    2017 TRD Off Road
    w/Super Terrific Happy Hour Mod
    If you didn't get the net thingy as an accessory for your topper but added one later, what did you get and how did you attach it? I was thinking maybe making some paracord loops and screwing them under the inside bolt caps and then just using a net with hooks to attach and take off but not sure if it would be too loose and floppy. Probably need to find the right size to keep the loops taut.
    I married my tacoma likes this.
  2. May 1, 2018 at 6:09 AM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
  3. May 1, 2018 at 10:39 AM
    phdog
    Jim
    Northern Colorado
    2017 TRD Off Road
    Thanks. That seems more finished and stable than my original thought. I assume you only use one of the screw holes.
  4. May 1, 2018 at 10:44 AM
    phdog
    Jim
    Northern Colorado
    2017 TRD Off Road
    Yeah, that's what I'm thinking. What net is that?
    pat's taco likes this.
  5. May 1, 2018 at 10:53 AM
    spaculley
    spaculley Well-Known Member
    Boise, ID
    05 SuperWhite DCSB
    OME 885+5100s Dakar pack+B110 Tepui Tent, Prinsu
    TACOZAC and (deleted member) like this.
  6. May 1, 2018 at 7:39 PM
    Bajatacoma
    SC
    Yep the hole opposite the D ring since the plastic Yakima nut thing is too large to work with the other hole. I did have to open the hole up a little but that's no big deal, just grab it with a pair of Vice Grips and use a step drill bit. I honestly don't use it as much as I thought I might though since I like all of my head room.
  7. Jul 17, 2018 at 7:59 AM
    brvermilli21
    brvermilli21 Well-Known Member
    Knoxville TN
    Does these stay stuck pretty well? Any issues with them falling?
  8. Jul 18, 2018 at 1:49 PM
    spaculley
    Boise, ID
    05 SuperWhite DCSB
    They worked well for my shell. The ceiling carpet was thick, but I know some shells have pretty thin carpet.
  9. Jul 23, 2018 at 12:41 PM
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
  10. Oct 1, 2019 at 2:38 PM
    Bajaxr201
    Bajaxr201 Well-Known Member
    Andrew
    San Diego, CA.
    2019 Off Road 4x4 DCSB
    |275/70R17 BFG KO2's | 17" Method NV Wheels| PRO Grille | CaliRaised LED bar and Ditch pods | LED interior Lighting |PlastiDipped emblems | WeatherTech Floor mats |
    reviving this, hopefully i get an answer but are you guys just drilling into the shell to secure these?
  11. Oct 1, 2019 at 2:51 PM
    spaculley
    Boise, ID
    05 SuperWhite DCSB
    Yes, as in I used the bolts drilled through for the Yakima roof tracks.
    Bajaxr201 likes this.
  12. Oct 1, 2019 at 3:40 PM
    Bajatacoma
    SC
    Same with mine, I used the plastic nuts that hold the tracks in place. Be extra careful not to turn the bolts themselves, just the nuts, or you will need to put more sealant in place. Probably not a bad idea to reseal if they've been in place for a while but silicon is notoriously difficult to get thoroughly cleaned so that new stuff will adhere.
    TACOZAC likes this.
  13. Oct 1, 2019 at 3:57 PM
    Bajaxr201
    Andrew
    San Diego, CA.
    Ok understood. Damn, unfortunately I dont have a roof rack and am scared to drill lol so I just found some strong velcro nets so hopefully that does the job!
  14. Oct 1, 2019 at 8:51 PM
    Bajatacoma
    SC
    Is your shell lined with carpet? If not and it's the usual chopper gun fiberglass you may be able to fiberglass some hooks onto it. They probably won't support a lot of weight but should be good enough for the typical items you'd put up there like clothes you're trying to dry or maybe bedding. Even if I drilled holes for mounts I wouldn't add a lot of weight since you'd be side loading the bolts in the fiberglass; the bolts would support the weight no problem but I would worry about wearing the fiberglass since it's typically not mat but strand.
