Inside edge tire wear
Discussion in 'Wheels & Tires' started by shroth, May 31, 2018.
  1. May 31, 2018 at 10:35 AM
    shroth
    shroth [OP] I don't like Mexican food. Why do I drive a Taco??
    Kill Devil Hills, NC
    2023 Tacoma Limited
    Toyota Hard Tonneau
    I've noticed that the inside edges of my tires are wearing. The dealer checked this at the 5K checkup & I was told the alignment is on spec & that this isn't abnormal. Now that the tires have been rotated I'm seeing the same issue after 2500 miles.
    Has anyone else seen this & do they have a solution/suggestion?
  2. May 31, 2018 at 10:43 AM
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    got almost 28k on mine and even though there is probably about 3-5k left on the tread, I will probably put new ones on before Christmas when we head to PA to see family and hunt. I keep my tires rotated every 3-5k. have you checked your tire pressure? and the balance?
  3. May 31, 2018 at 10:44 AM
    Bishop84
    Bishop84 Well-Known Member
    Typically tacomas run slightly positive camber, this negates this, can you try a different dealership? You get warranty alignments for the first 2 years (not sure how many miles)
  4. May 31, 2018 at 10:59 AM
    shroth
    2023 Tacoma Limited
    Toyota Hard Tonneau
    Thanks for the immediate replies guys!!! I'll have it rechecked at 10K & ask for the printout this time. Will also share positive camber info. I'll probably go back to the same dealer I bought from as they have been perfect up to this point (previous vehicles & service)
    According to the sensors, pressures are 31 cold & haven't gone above 36 hot. Rotated a 5K. Should be issues there.
    Thanks for the advice........may take it in before 10K just to save the tires.......
  5. May 31, 2018 at 11:01 AM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    Stock tires??
    G.
  6. May 31, 2018 at 11:18 AM
    Pine State
    Pine State Well-Known Member
    Maine
    2018 Tacoma DCSB SR5 4x4
    Seems a little low but probably not low enough to cause issues. I use 36 cold which is about 39/40 hot and at 5500 miles I have no unusual wear.
    na8rboy and cblow5 like this.
  7. May 31, 2018 at 11:25 AM
    sneakyjack
    sneakyjack Well-Known Member
    I'll jump in on this - my stock tires are in need of replacement they are 265/70R 16 I have the option to buy 4 slightly used (under 100 miles) from a tacoma but tire size is - P245/75R 16 on the rims. My original thought was to pull the tires off the rims they are on and put them on my existing stock rims. I notice the size difference but if rims are both 16 should be fine ? yes?
  8. May 31, 2018 at 11:31 AM
    shroth
    2023 Tacoma Limited
    Toyota Hard Tonneau
    Yes....stock tires...Goodyear Wrangler All-Terrain Adventure 265/70R16
  9. May 31, 2018 at 12:26 PM
    shroth
    2023 Tacoma Limited
    Toyota Hard Tonneau
    Wow....that seems high but what the heck. Goodyear site says 51 is max. Gotta realize this isn't my passenger car.......
    Starting with another dealer visit...then my local tire dealer.....then pressure changes. Thanks guys !!
  10. May 31, 2018 at 12:32 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    My truck has 29 PSI on the door....I ran that for 110,000 on my 2006 and the 2016 has 29 also.....
    I'll stick to the 29 "on the door".. However, OP is having uneven wear, so I'd suggest an alignment. :thumbsup:
  11. May 31, 2018 at 1:14 PM
    shroth
    2023 Tacoma Limited
    Toyota Hard Tonneau
    My Taco says 30 on the door. I guess that's while I'll try the alignment before increased air pressure.
    You also said something I wondered about..........why does it say [OP] after my screenname?
  12. May 31, 2018 at 1:20 PM
    Pine State
    Maine
    Original Poster, you started this thread
  13. May 31, 2018 at 1:24 PM
    Clearwater Bill
    Billy
    Largo Florida
    You are the Original Poster in this thread. Thus OP.
    Tire pressure won't cause wear on one edge. Low will cause both edges, high will cause center.
    Forget the numbers and websites, just do a chalk test to see how your contact patch is working. Start with the pressures posted in your door jamb and work up or down as needed till you get it right.
    Not sure why a dealer would say the inner edge having wear was normal. It isn't.
  14. May 31, 2018 at 1:30 PM
    shroth
    2023 Tacoma Limited
    Toyota Hard Tonneau
    :amen:.........I truly respect all the opinions & am so glad for the willing nature of everyone.
    Getting a larger 2x4 & having a discussion with my dealer :)
    Thanks for the OP info too........damn I feel dumb
    over60 likes this.
  15. May 31, 2018 at 1:40 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Inner edge wear can be too much negative camber(less likely) or too much negative toe(more likely).
    Clearwater Bill likes this.
  16. May 31, 2018 at 1:42 PM
    shroth
    2023 Tacoma Limited
    Toyota Hard Tonneau
    You guys are just making me more convinced.........put it on the rack......print the results.....or keep insisting there's no problem & warranty the tires!!
  17. May 31, 2018 at 1:45 PM
    Clearwater Bill
    Billy
    Largo Florida
    Tires are a wear item. Separate warranty on tires, and only covers manuf. defects.
    Edge wear is not a tire defect.
  18. May 31, 2018 at 1:47 PM
    shroth
    2023 Tacoma Limited
    Toyota Hard Tonneau
    I understand..........but when caused by dealer neglect or refusal to help......I can at least get loud :)
  19. May 31, 2018 at 2:01 PM
    Clearwater Bill
    Billy
    Largo Florida
    I'd just find a reputable alignment shop and move ahead.
    Maybe send the dealer a thank you for helping you get into real tires sooner.
    I know there are good folks at dealers. But an alignment is all based on 3 things............
    1) good mgmt oversight
    2) equipment that is properly serviced and in spec
    3) a tech that knows how to use the equipment more than 'green light good', and isn't too lazy to do so
    4) 2 and 3 are dependent on 1
    It's hard to know these things in a dealer enviroment, unless you know someone there personally, from other life associations, and can get the full skinny on stuff.
    Same with big box shops like Firestone, Goodyears and others. They are franchises. Maybe if you know the manager or tech..........
    It's not easy to know always in an independant shop, but it is easier IMHO. I'd start by going to local car shows and asking the sports car guys for alignment shop recommendations. Ask 10 and get 5 or 6 of the same, that's a place to consider.
    over60 likes this.
  20. May 31, 2018 at 2:03 PM
    shroth
    2023 Tacoma Limited
    Toyota Hard Tonneau
    Sounds like excellent advice........
