Info and weight difference TRD Pro SEMA wheels
Discussion in '3rd Gen. Tacomas (2016-2023)' started by c21df, Jan 5, 2021.
  1. Jan 5, 2021 at 2:01 PM
    c21df
    c21df [OP] Member
    DF
    2016 Tacoma TRD Sport, V6, auto 4X4 LB, (7566) Super White
    none
    So ive been wheel shopping, searched pages and pages here. Thought i had come to a decision PTR20-35110 GR, the grey 4Runner Alloy wheels. Then i saw the PTR20-35110 G4, an aluminum Wheel. Slight color diff between the two. I could not find weight of the alum wheel, the Alloy is 24-25 lbs. Anyone have any info on the Alum version? Weight, quality, difference in running Alum wheel and Alloy wheel?
    They will go on my white 2016 long bed TRD Sport Tacoma. I finally wore out the Firestone station wagon tires. Thanks!
  2. Jan 5, 2021 at 2:08 PM
    Iwilltaco
    Iwilltaco Well-Known Member
    @kairo’s guest house having a water with @not_nick
    Under development
    Not familiar with that 2nd pt number
  3. Jan 5, 2021 at 2:29 PM
    c21df
    c21df [OP] Member
    DF
    none
    Its a real Toyota part number. I know these have been out for a while. My local dealer Toy of Glendora only had the black and the bronze to see/touch. I cant be the 1st to buy them.
    Shopping at BAM Wholesale.
    AMSK.505 likes this.
  4. Jan 5, 2021 at 2:33 PM
    Iwilltaco
    Under development
    Oh, ok. The gloss gunmetal. Yes, I’ve seen several people post those up. Check the sema wheel threads.
  5. Jan 5, 2021 at 2:34 PM
    Iwilltaco
    Under development
  6. Jan 5, 2021 at 3:11 PM
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    Those gloss gunmetal wheels are pretty bad ass. If it were me, I would not be worried about the weight difference.
  7. Jan 5, 2021 at 3:14 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Looks like same wheel, different paint to me.
    Junkhead, bmxtaco and philth like this.
  8. Jan 5, 2021 at 3:16 PM
    c21df
    c21df [OP] Member
    DF
    none
    Thats the thread that sold me on the Gray. I didnt see any one speak of the differences Alum V. Alloy. The Alum are a little more $$.
    BAM link not working.
  9. Jan 5, 2021 at 3:24 PM
    c21df
    c21df [OP] Member
    DF
    none
    17-In Cast Aluminum Gloss Gunmetal Gray Wheel 2020 Toyota 4Runner OEM
    Part Number: PTR20-35110-G4
    Other Names: 4RUN Gm Gray Trd Whl
    Description: This is a 17" TRD Cast Aluminum Wheel - Gloss Gunmetal Gray. More Info
    Fits:
  10. Jan 5, 2021 at 3:41 PM
    Iwilltaco
    Under development
    Yea, I considered them, but found a good deal on the original black. But the gloss gunmetal are pretty sweet. I wouldn’t worry about weight difference or anything else. Whatever grey one you like, you should get.
  11. Jan 5, 2021 at 4:01 PM
    TheCochese
    TheCochese The Bronze T4R OG
    Attempting to flee the south
    Cavalry Blue soccer machine
    Fine corinthian leather
    Look at the item description. Both are aluminum.
    It's the same wheel, different finishes, as seen by the part numbers. The bronze ends in F5.
    Stocklocker likes this.
  12. Jan 5, 2021 at 4:15 PM
    c21df
    c21df [OP] Member
    DF
    none
    Thanks for response. Why is the G4 described as a cast wheel. I had assumed the others are forged. Are they all Cast wheels?
  13. Jan 5, 2021 at 4:17 PM
    TheCochese
    AFAIK, yes.
  14. Jan 5, 2021 at 6:52 PM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    Aluminum wheels are all alloy. If they were just aluminum, no alloying metals, they would yield/crumble immediately.
    If they are both genuine Toyota wheels, is almost certain that they are the same wheels with different finish/paint.
  15. Jan 9, 2021 at 11:27 AM
    c21df
    c21df [OP] Member
    DF
    none
    Update.
    So i talked Longo Toyota into ordering a set of the G4 and GR and in person the color is the same on each. The only diff is gloss V. Matte and the price on the gloss is higher. Is gloss powdercoat more expensive? Every dealer i called within a 50 mile radius has a different price. Do your due diligence in shopping. BAM wholesale the best price i could find online but shipping kills that deal for me. I ordered at my local dealer with a buddies company invoice. $171.32 each. Thanks for all the help!!
    AMSK.505, philth and CrispyTacoLover like this.
  16. Jan 9, 2021 at 11:38 AM
    Iwilltaco
    Under development
    I imagine the gloss is easier to keep clean. And is a newer offering, so might be why they are a little more money.
  17. Jan 9, 2021 at 12:02 PM
    jerkwithkeyboard
    jerkwithkeyboard Well-Known Member
    Western suburbs Chicago, ILL
    2016 TRD Sport DCSB Inferno 4x4, loaded /JBL/Tonneau Cover/ Roof Rack
    17" Black TRD rims Tacoma Stainless Steel Rear Tailgate Letter Inserts Brake light flasher Center LED 110v and 2-3amp USB plugs mod in back seat center 400w on all the time mod SSR-610-40 SumoSprings 32 INCH 180W CREE LIGHT BAR (5D ) AUXBEAM BedStep and Pop & Lock Power Tailgate Lock Blue LED glove box light (fix no light) Bed light Blue LED's Wired to turn on when Gate is opened Tempered Glass Center Touch Screen Protector Rear Camera anytime Navigation Bypass ( a must) Rexing V1 3rd Generation Dash Cam hard wired in OXILAM 912 921 LED Reverse Light 2000 Lumens TRD Pro Grill TRD Skid plate
    Dont forget to order color matching lug nuts also. or black
    :woot:
  18. Jan 9, 2021 at 12:41 PM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Gloss is way harder to keep clean in my opinion. I have the matted finish and they are great, look new still after 3 years.
  19. Jan 9, 2021 at 12:45 PM
    Iwilltaco
    Under development
    Maybe, I was just going by the glossy black on my sport wheels were easier to keep clean than my matte sema. But who knows
  20. Jan 9, 2021 at 1:10 PM
    VaToy
    Parts Unknown
    The gloss will show more dirt.
