infinity speakers?
Discussion in 'Audio & Video' started by rzimm001, Nov 17, 2009.
  1. Nov 17, 2009 at 12:28 AM
    rzimm001
    rzimm001 [OP] Tearmytaco
    Bobby
    Wildomar
    08 PreRunner SR5 Long-Travel
    King 10" coilovers w/ resi. 3.5" over long travel kit. Factory spindles w/ ALLPRO gussets. Total Chaos tower gussets. Energy Poly cab mounts and steering rack mounts. Glassworks fenders and bedsides. Home fabbed bed cage. King 2.5x16 bypass shocks in the rear. DMZ long travel rear end. Race radio (2meter). Removed secondary carbon air filter. Exhaust dumped before the axle / no muffler. Phram fresh air cabin filter. K&N replacement filter, After market stereo, Grillcraft grill, custom fabled roof rack with 7" HID's, PRP race seats.
    Hey guys, quick question for you. I have inifinity 6 1/2 component speakers in every door on my truck. They are the 6020 reference series. Anyway the sound is kind of hollow or I should say they they have that small speaker sound to them. I like being engulfed in sound. Any suggestions? I like the clarity and sound of the components especially for accoustic music but there is definitely a lack low mid range. What do I need to do? Different speakers? I do have a subwoofer built into a arm rest enclosure (10").
  2. Nov 17, 2009 at 3:32 AM
    jester156
    jester156 Well-Known Member
    Cumberland, RI
    2021 GMC Sierra AT4. 3.0l Duramax
    sounds like u need a better midrange for the door since u have a sub and the tweets from the component, then you can cross over your signal better and blend high, mid and low into the 3 speaker sets.
  3. Nov 17, 2009 at 5:57 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Have you deadened the door at all? Also, what frequencies are they set to play? Do you have them crossed over at all? Are they playing on headunit power or a separate amp?
  4. Nov 17, 2009 at 6:52 AM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    Curious, but what sub enclosure do you have? The JL Stealthbox? Can you take some pics/share some opinions on the sound.
  5. Nov 17, 2009 at 9:06 AM
    rzimm001
    Bobby
    Wildomar
    Well the options on the crossover only apply to the tweeter and that is 0db change or -3 db change depending on if you want the tweeter screaming or not. How do I deaden the door? What will that do for me? These speakers got excellent reviews but they seriously sound hollow and small. The tweeters sound amazing for accoustic guitar music ( way awesome). I made the mounting plates myself from 3/4 inch particle board. The speakers are amped. They have a high response rating so they actually run just fine off of the head unit, however it did not change the issue I'm having. Here's some pics of the sub enclosure.
  6. Nov 17, 2009 at 12:52 PM
    ItalynStylion
    Steven
    DFW, Tx.
    It sounds to me like you're suffering from a lack of midbass response. You've got the highs and the lows seem to be there but the punchy bit close to the sub is probably not where it should be. Try sealing up the doors and deadening them. This should give you a big jump in midbass response. You can also try using the EQ on your headunit to boost the 80-150hz frequencies.
  7. Nov 17, 2009 at 1:12 PM
    mtucker
    mtucker Tacoma addict
    Escondido, CA.
    03 Prerunner DC
    Replaced chrome badges with Sockmonkey black badges, painted billet grill black, K&N cold air intake, my corner light turn signal circuit, Speedfreek traction bars, RAAMaudio BXT/Ensolite, Stereo: Kenwood KIV-701 USB/Bluetooth deck, 10" Pioneer shallow sub behind the rear seat, Infinity 6822cf 6x8 front and rear doors, Fosgate P400-2 (sub), US Acoustics USX-4065 (four main speakers)
    2nd that ^^^^^
    I saw a big improvement in mid bass from my 6x8 in door speakers (1st gen) when I sealed up the doors (use metal flashing or similar to seal up the huge access holes in the door and put a layer of RAAMaudio/Dynamat.... to keep it from vibrating). I did the rear doors first (double cab) so I was able compare the same speakers with and without the sealed/deadened doors. Huge difference.
  8. Nov 17, 2009 at 4:20 PM
    rzimm001
    Bobby
    Wildomar
    Thank You! Sounds like its worth a shot. The speaker mounts I built don't entirely cover the opening in the sheet metal now that I think about it. That could be my problem. Maybe there's feed back coming through... Where's the best place to get this sound deadning stuff? I've heard its rediculously expensive? Suggestions?
    Hey check these out. What do you think? http://www.crutchfield.com/p_237XT65/XTC-6-1-2-Speaker-Baffles-3-1-4-depth.html?tp=2809
  9. Nov 17, 2009 at 4:36 PM
    rzimm001
    Bobby
    Wildomar
    Ehh scratch that idea. The baffles had terrible reviews. How many square feet of this dynamat stuff will I need. I'll start with the front doors. Recommended thickness?
  10. Nov 17, 2009 at 4:51 PM
    RedskinRedTaco
    RedskinRedTaco Well-Known Member
    Paul
    Virginia Beach, VA
    07 TRD 4x4 Offroad Crewcab
    Trifecta folding Touneau Cover, 275/70/16 LTX M/S, Running Boards, Dynamat, tint, Alpine W404 Video system w/ backup cam, Sirius Sat, Polk Audio Component Speakers frt and back, Alpine 4x50 amp. Billy's 5100's set @ 1 3/4, 1" rear blocks, Rear TSB, trimmed frt mud flaps 4", TRD Exhuast, K&N filter. Electric Brake.
    I installed the polk 6 1/2" components in all 4 doors, and dynamated the crap out of the doors inside and out. Even did under the hood. They sound good just need more power. I've got a alpine w404 w/ this cool little amp alpine makes. it plugs right in line with the radio harness and bumps power up to 45 watts cont power. i need a sub box for behind back seat.
  11. Nov 17, 2009 at 10:53 PM
    ItalynStylion
    Steven
    DFW, Tx.
    It's not as expensive as you think it is. Follow the steps to deadening and sealing the doors that I laid out in my recent deadening thread. You don't need to use the MLV barrier in your case unless you really want to.
    Hit up Don at sound deadener show down. His site is www.sounddeadenershowdown.com
    Tell him you need 20CLD tiles and some butyl rope; maybe like 3 feet? Use about 7 on the inside of each door and use 3 on the outside of the door to seal up the open areas. You can use the butyl rope instead of the clear silicone I used for the same purpose, it will probably smell less :D
  12. Nov 22, 2009 at 10:45 PM
    futonpimp
    futonpimp Well-Known Member
    Los Angeles
    06 Tacoma 4WD
    Hey Man, I dig your sub... couple questions for you though..
    do your seats still fold into their flat positions?
    and where did you get that box from? :)
    Thanks in advance!
  13. Nov 23, 2009 at 1:28 AM
    rzimm001
    Bobby
    Wildomar
    No, unfortunately the seats do not fold back anymore. They stop when they hit the sub enclosure. The sub box was custom built for me by a stereo shop in Temecula. He took all the dimensions and a few days later I had a sub enclosure. It fits snug as can be.
  14. Nov 23, 2009 at 7:31 AM
    atsaubrey
    atsaubrey Dealer/Sales Rep for Sundown Audio.
    california
    blue 2007 double cab
    Sundown Audio 100.4 and 1500D, Pioneer 880PRS, Zapco Refernece 6.5" comps, 2 10" Image Dynamics IDQ, 200ft of Second Skin deadener, Kicker wire
    Temecula is a ways away but if you would like some help with the install or tuning hit me up. I am well stocked in Second Skin Damplifier Pro as well. www.secondskinaudio.com. I am about 1 hour north of Bakersfield by the way.
  15. Nov 23, 2009 at 9:56 AM
    futonpimp
    Los Angeles
    06 Tacoma 4WD
    ahh cool. I guess i'll figure something out whenever I need to fold down those seats. (I have the same problem with a sub i ordered from super crew).
    Thanks for the reply!
  16. Nov 23, 2009 at 9:57 AM
    futonpimp
    Los Angeles
    06 Tacoma 4WD
    I'll definitely hit you up if I run into anything. Thanks!
  17. Nov 23, 2009 at 11:16 AM
    DaytonLax14
    DaytonLax14 Well-Known Member
    Corey
    Ohio
    98 extended cab TRD Off Road
    did you ever adjust the eq on your headunit?
